Question about Yamaha ATS-1010BL Sound Bar Front Surround System - Refurbished
How do I sync my Yamaha ATS-1010BL soundbar to my DISH remote?
How do I sync to DISH remote
Setup my sound bar?
Contact any service technician. He might have a solution to this problem. Electro help
Dec 01, 2014 | VIZIO M801i A3 80 Inch 1080p Smart
Remote control code for Logic 3 Tx101 soundstage 5.1
Your Yamaha soundbar may work only with its own remote. Otherwise, the soundbar signals could interfere with the TV remote signals. You can try searching with your universal remote to find a code that will work.
Aug 10, 2014 | Yamaha YAS-101 Front Surround Sound Bar...
Dish network code for receiver 722 for bose soundbar
Traci Pogue,
I would be happy to provide additional assistance on that. Unfortunately the only codes I am able to locate for that equipment are 761, and 780. This link http://www.mydish.com/support/apps/remotecodes.aspx may have additional codes you can look up or try.
If none of the codes work, and you have a 20/21.0 remote, you can utilize the learning feature to teach the remote the buttons. You can find full instructions at http://www.mydish.com/support/teach-learning-remote-20-21 . If you still need any assistance after that, let me know here. I would be happy to see what else can be done.
Tommy Faust
DISH Social Media Representative
Jul 22, 2013 | DISH Network Televison & Video
Yamaha soundbar
Remove the batteries from the remote. Push all the buttons to eliminate a stuck button as a cause. Reinstall the batteries or install new batteries. Disconnect and reconnect the soundbar. Check operation. If the problem remains, you may need to replace the remote
May 24, 2013 | Audio Players & Recorders
Need codes for setting up my Dish VIP 612
Ed Fox,
I can definitely understand the concern. Below I will give the steps to program a remote to an auxillary device, a link where you can look up codes, and the steps on how to preform a Power Scan if the codes don't work.
Codes: http://www.mydish.com/support/apps/remotecodes.aspx
Addressing Remote:
1.) Press and hold the clear DVD button until all mode lights light up.
2.) Release and DVD light will be blinking.
3.) Press 1 for a VCR/DVD, and enter the code. (if DVD code is 617, enter 1617)
4.) Press pound (#)
5.) Try functions (Power, Play, etc..) and see if it is working.
6.) If no function, repeat steps 1-4 with another code.
On the steps above, to program your sound bar, repeat the same steps but instead of DVD hold AUX, and instead of 1 before the code, press 2.
To Power Scan the remote, with the desired equipment on, press and hold the DVD or AUX mode button (about six seconds) on the top of the remote until all mode buttons light up, then release. Press 1 for VCR/DVD, or 2 for other equipment, then press STAR (*)
Press the Up arrow button once per second while pointing the remote at the equipment. If the code for it comes up, the equipment power off.
When it does, press the POUND (#) button. If the code entered is valid for the remote, the mode light will flash three times. To verify the code works try several different functions for that equipment.
Let me know if you have any other questions!
Tommy Faust
Mar 05, 2013 | DISH Network ViP 612
Need dish remote code for Haier Slim Evoke Soundbar
If your DiSH remote is programmable, you should be able to get the code from DiSH
Dec 16, 2012 | Haier SBEV40-SLIM 40" 2.1CH Slim Evoke...
Comcast remote with yamaha sound bar
This works. Re-program the sound bar.
http://faq.yamaha.com/us/en/article/audio-visual/digital-sound-projector/ats-1010/7727/6639/
May 27, 2012 | Yamaha Ats-1010 Sound Bar Front Surround...
Need Dish remote code (6.4 IR/UHF) for Vizio VSB200 Soundbar...
There are no codes available for a 6.4 remote on a Vizio Soundbar. Below are the steps to Power Scan the remote control. This will search all codes 1 by 1 until it finds a code that works, or exhausts all available codes.
Power Scan:
1.) With the Soundbar on, press and hold the AUX mode button (about six seconds) on top of the remote until all mode button backlights come on, then release.
2.) Press 2 then press STAR (*)
3.) Press the Up arrow button once a second while pointing the remote at the Soundbar. If the code for the Soundbar comes up, it will power off.
4.) Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times. To verify the code works try several different functions for that equipment.
Tommy Faust
Feb 12, 2012 | DISH Network IR Remote Control
Yamaha ATS-1010BL Sound Bar Front Surround System - Refurbished Logo
69 people viewed this question
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
Electro Med Services...
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
