Question about JVC Car Audio & Video
How do I setup bluetooth function on my JVC KD-X50BT
MPetro302
  • 298 Answers
SOURCE: is jvc kd-g335 blue tooth compatable
If it is a "Ready for BlueTooth" model you will need this adapter JVC KS-BTA20
Posted on Jun 04, 2009
etirbynnor
  • 655 Answers
SOURCE: bluetooth turn on
Hello imback2009,
The JVC KD-G140 does not have a Bluetooth option, either built-in or with an adapter. And as far as I can tell, it doesn't have a "mute" or "phone" wire which would allow installation of a generic bluetooth adapter, such as the Parrot. If you want to connect your cellphone, I'd recommend you look at an upgrade here.
Hope this helps.
Posted on Sep 11, 2009
Testimonial: "The information was very helpful and Im grateful for the quick response. I still dont understand why there is a bluetooth icon. But, Im satisfied"
  • 14 Answers
SOURCE: how do you use bluetooth on the jvc kd-g230
That model does not have bluetooth installed on it unless you buy an aftermarket bluetooth adapter.
Posted on Nov 15, 2009
SOURCE: How do I switch the
How do I sinc my iPhone to the cd player or how do I sinc cd player to my phone
Posted on May 27, 2011
  • 5481 Answers
SOURCE: How to use jvc kd-hdr20 car stereo. I need to know
To pair a bluetooth device with the radio, turn on the Bluetooth function of the device. Then press the SRC (source) button on the receiver. Select BT Audio or BT Phone, depending on the device you want to pair with the radio. Use the up/down arrows to select New Device and press the down arrow. Select Open and then press the down arrow. Then enter the PIN by using the left/right arrows to select a digit and turning the volume knob until the correct digit is entered. (For some devices, you need to enter a specific PIN. Consult that device's manual.) Press the down arrow to set the PIN. Enter the PIN in the device you are pairing to the receiver (if it doesn't have a required PIN). Wait for the message "Connected" to appear.
To use the device in the future, press SRC and choose the appropriate Bluetooth type. Then use the right/left arrows to select the registered device. Press the down arrow and then use the right/left arrows to select Connect and press the down arrow. (See the manual, link below, for setting the autoconnect or autoanswer.)
To adjust the sound system balance, press and hold Menu to open the menu and then turn the volume knob to Audio. Press the center of the Volume knob. Then navigate to balance and adjust the unit as needed.
The manual for the KD-HDR20 is available from JVC on the product support page: http://support.jvc.com/consumer/product.jsp?archive=true&pathId=54&modelId=MODL028465 . The direct link to the instruction manual is http://resources.jvc.com/Resources/00/01/14/LVT1960-001A.pdf .
I hope this helps.
Posted on Oct 13, 2011
Bluetooth feature is available or not in Jvc Kd-R504
The KD-R504 does not offer Bluetooth functionality.... Sorry.
Jun 19, 2016 | JVC Car Audio & Video
I have a jvc kd s88bt car audio system need info. About how to use it.set up , commands, settings adjustment buttons how to use them to st up Bluetooth
The instruction manual can be downloaded from http://books.jvc.com/booklist.asp?Model=kd-s88
You may research on http://www.jvc.net/cs/car/bluetooth/index.php for bluetooth compatibility.
Feb 19, 2015 | JVC Car Audio & Video
Jvc kd-x250 bt installed in my son's boat will not work on the water except in reverse or in the driveway.Never came up on a problem like this before.There was a radio tied in prior,just used the same...
Doesn't work is one way of telling the symptom. In detail, it can also be said " powers on, cannot change channel, etc..). That may help troubleshooting
Oct 07, 2013 | JVC KD X50BT - radio / digital player
My JVC KD-G340 says its bluetooth capable but when I hit the source button it doesn't show up do I have to turn it on somehow what am I doing wrong and also will I be able to play my music through...
Your Stereo requires a bluetooth adaptor (KS-BTA-200) for the bluetooth to function. Here is a link to the owners manual for your particular device:
http://resources.jvc.com/Resources/00/01/13/GET0487-001A.pdf
The information you require is on page 10... Bluetooth device operation.
Sep 28, 2012 | Car Audio & Video
Bluetooth turn on
Hello imback2009,
Hope this helps.
Sep 11, 2009 | JVC KD-G140 Car CD Player
Is jvc kd-g335 blue tooth compatable
Jun 04, 2009 | JVC KD-G340 Car CD/ MP3 Player
Where to get manual for JVC kd-lhx501
Hi - You can download the manual from the link underlined in blue below:
kd-lhx501
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 13, 2008 | JVC KD-LHX501 CD Player
JVC KD-NX5000 NOT WORKING PROPERLY
I had the same problem, where the Sat radio, the bluetooth and the ipod were all non-functional. Turns out, they all go through one central hook-up, so you have to make sure that connection is good.
When mine did not show up or function, I looked at the install under the foot board of the front passenger seat that the installer did, and nothing looked out of whack. Upon closer inspection, one of the cables was had been pressed out of it's proper place and loosened enough to cause a bad connection.
I don't care for the install, but there was no problem with the equipment, so check all of your connections. Even to the point of pulling them out and reconnecting them to see if that fixes the problem.
Robert
Jul 08, 2008 | JVC KD-NX5000 Car Video Player
Car Audio & Video Logo
75 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
