Question about Sony MDRRF960R Consumer Wireless Headphones
Can i use the sony mdr -rf960r without the transmitter ?
I lost the transmiter ... can i use them with bluetooth or something ?
A2dp pairing problems
The Victsing unit states that it is a receiver. This will receive the wireless signal from a device and output sound through the headphone jack. A bluetooth transmitter would input sound into the headphone jack from your tv or other source and transmit the signal over bluetooth to a paired receiver. Two of the same type of unit will not pair with each other.
May 10, 2014 | Victsing New White Black Bluetooth A2DP...
Sony mdr if520r
what OS, windows?
this is called blue tooth.
if the laptop has bluetooth option it will be in the device manager.
under networks.
many don't. Sony Asbuilt codes are complex.
if it is missing , add one, they cost $5 (yes a dongle ,do-hickey)
for fun run bluetooth radar, now you can see all bluetooth in home.
if not, its not a feature set of you laptop.
blue tooth is a simple wireless, for 10 to 100 meter rage,
class 2 is 10 meters, class 1 is 100 meters.
it's a radio/ transmitter.
Sep 04, 2013 | Audio Players & Recorders
WILL TWO SONY HEADSETS RECEIVE THE SAME SIGNAL
go on use IR transmitter...
http://www.amazon.com/Sound-Storm-Laboratories-SHP-IR-Transmitter/dp/B0015C1RKE
THANK U...
Nov 23, 2012 | Sony MDR-RF970RK Headphones
Describe your Sony MDR-NC20 replacement cable Problem: have lost cable that connects to headphones--strange, unique jack. I need an adaptor to mini jack. Where to find?
Overpriced, yes, but available:
https://servicesales.sel.sony.com/ecom/accessories/web/viewItemDetail.do?operation=getItemDetail&itemID=67362&searchOperation=modelSearch&searchText=MDRNC20
Dec 29, 2009 | Sony MDR-NC20 Consumer Headphones
I recently dug up a pair of Sony cordless headphones from amongst my electronics - MDR-IF0230. How do I get this to work? It must use a transmitter of some sort but I do not know what to look for.
I have MDR-RF800RK which use a small transmitter with about 8cm of sick ariel. I suspect that IF indicates that you should be looking for an infra-red transmitter. You should be able to get the full info on sony.com
Sep 25, 2009 | Sony Audio Players & Recorders
Lost my manual. how do i get the battery out?
Click Sony Support to download instruction manual copy of MDR-RF960RK and check page- 4 for battery replacement.
Thanks.
Aug 18, 2009 | Sony MDR-RF960RK Consumer Headset
Failure to sync
hi, there maybe interference with the signals try in a differnt area.
Aug 04, 2009 | Jwin iLuv i903 Consumer Headphones
Replacement pads for sony headset MDRCD6
Hi Hifi-fans.
The MDR CD6 is still my favorite, since more than 35 years. My feeling was right, I would never find a better headset than this. This was the reason, time ago I bought a second set. You can imagine meanwhile I may have to replace the x-generation of ear-pads. The first ones I ordered for a lot of money at our Sony-HQ in Colone, Germany. Meanwhile I had found a better, more flexible solution. I had checked at our electronic storehouse, which headset from another manufacturer the pads are removable without damaging. I did select the Genius HS-04S ones for the PC and they are really cheap and you may use them without the pads. At the MDR CD6 the pads does not sit much strong, but this not really a lost.
All the years I did not use the second headset, the spare one. Nevetheless the ear-pads were damaged. The covering rubber was harded and broken like old plastik. Just some minutes ago I replaced the pads by the Genius ones.
So far, good luck and I am quite sure you may find the Genius in your country.
Nov 27, 2008 | Sony MDR-V6 Professional Headphones
Sony MDRRF960R Consumer Wireless Headphones Logo
60 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
