Question about Maytag MGR6772BDS Gemini Gas Kitchen Range
Gas leak, but part number 74007408 has been discontinued
How do I get part number 74007408?
Whenever I start my oven It doesn't get warmed up and leaks Gas. We have to restart it over and over again but it doesn't increase heat. And Could I get an online manual?
If it's leaking gas, you need to discontinue using it and call a repairman immediately.
We cannot direct you to a manual without knowing the make and model. Enter that info into Google and you can find a manual.
Sep 03, 2016 | Ovens
Need discontinued burner valve for GCV36G
You can try an appliance parts supplier. There might be a crossover to a current part
May 08, 2013 | Thermador Kitchen Ranges
I need to know the inside diameter of the fl;ywheel
Go to the Dewalt service website at http://servicenet.dewalt.com/ and you will find your flywheel, part number 5130128-00, is available but is currently on back order until the end of August. It is highly unlikely Dewalt will discontinue this flywheel as it fits on a large number of their compressors. If you still need the hub's inside diameter, it would have to be the same or a couple thousandths bigger than the diameter of the crank shaft where it mounts on the pump.
Aug 08, 2012 | Dewalt D55270 gas powered air compressors
I was looking for the manual for the Char Broil "charcoal" grill, not the gas grill...
Unfortunately, the model number you listed is for a gas grill. There is not Char-Broil Charcoal Grill, that comes even close to that model number. If may have been discontinued. In any event, contact Char-Broil Customer Service 866-239-6777. If there's a manual available, the will email it to you.
Sorry for the confusion, but I based everything on the Model Number you provided.
May 11, 2011 | Char-Broil 461630208 Charcoal Grill
Need to know how to switch off hot water by combi boiler worcester bosch 240 to be able to fix leak on pipe downstairs
its the vavle 3 one in from the left its a 15mm pipe and there will be a iso vavle what you can turn with a flat point screwdriver and that will turn off the main water to the boiler these are the manual
http://www.worcester-bosch.co.uk/homeowner/literature/discontinued-boiler-literature/discontinued-gas-boiler-literature/240-bf-discontinued-december-1997-literature
Jan 23, 2011 | Heating & Cooling
Gas Valve is leaking
I am a Nordyne dealer and you can replace your gas valve with a generic valve of your choice. You can try and find a supply house in your area that sells them or you can visit www.myhvacparts.com to find one.
Apr 05, 2009 | Intertherm P3RA-048K Air Conditioner
Free Online repair manual for Snow blower
No brake down on gear box for auger, part #740013 and its DISCONTINUED, belt # 700035
sheer pins 700104 , this was made in 1988 lawnboy bought gilson this was a gilson, many parts are
now discontinued .
Be careful when buying a new 2 stage there are many out there now that engines are made in china
even on Mtd, look for briggs or honda tecumseh went out this year .
good luck
Feb 01, 2009 | Garden
Obsolete Thermador
Hi Iniro
It is true that thermador has permanently discontinued some of its models - alternative supplier have not beeen identified
Regards
Sep 09, 2008 | Thermador SGS36GS Gas Cooktop
Maytag MGR6772BDS Gemini Gas Kitchen Range Logo
208 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
