Question about Craftsman Air Tools & Compressors
Model #919158210 Craftsman sprayer/compressor manual
I purchased a used Craftsman 2 HP 20 Gal air compressor, model # 919.158210. I'm looking for a copy of the user manual, Sears # SI-30-00-4. This item is no longer available from Sears.com and doesn't seem to be available on the manual websites that I've looked at. Where can I find a copy of this user manual?
2 Suggested Answers
krb55
  • 604 Answers
SOURCE: I purchased a used Craftsman
Since the exact model number manual is not available go to Sears and look at the compressors they have on the floor (or in the catalog). Find one that looks like the one you have and note the model number (these devices haven't changed much over the years). order the manual for the one that matches your machine the best.
Posted on Mar 22, 2011
I recently purchased a 20 gal/1.5 HP, model 921.166420. The reset button on the side of the motor, (thermal overload Protector?) cuts out repeatedly. The few times where the motor did run and the pr
Could be weak thermal cutout or actual problem with unit. Thermal cut out easy to check with amp meter. Connect meter as required to monitor draw as unit fills and make sure that it stays at or below usage stated. If amp draw stays below stated usage and thermal cuts out, replace the part. If amp draw goes over amount stated turn off compressor and listen for air leaks (usually check valve will leak back pressure to pump causing extra load on motor).
Nov 29, 2011 | Craftsman 150 PSI Air Compressor
I want a operators manual for a coleman powermate air compressor 20 gal tank
You should be able to download a manual from this site:
http://www.powermate.com/productmanuals.php?cat_id=1
The VLF1582019 is a 20 gallon model but you should confirm if this is the model number of your unit.
May 23, 2011 | Coleman Powermate 02 - Gallon Air...
I purchased a used Craftsman 2 HP 20 Gal air compressor, model # 919.176220. I'm looking for a copy of the user manual, Sears # SI-30-14-4-C. This item is no longer available from Sears.com and doesn't...
Mar 22, 2011 | Craftsman 15 gal Air Compressor 3 hp UMC...
Psi does not go above 20
Check drain as it might not be closed all the way, you may have to set the regulator and there could be a bad switch diaphragm.....
Feb 04, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Need owners manual for devilbiss pro 4000 air compressor
Craftsman compressors are model numbers starting with a 919.xxxxxx Find this number and look it up on searspartsdirect.com. Some manuals are available for viewing without purchase.
Eric
Jul 30, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Owners manual ruined. what type of oil do i fill w before use
you should be able to find the manual online if it's available if not Sears would I'm sure be able to tell you.
Dec 19, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
160 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
