Basic CD Operation:
1. Power the unit ON if STANDBY mode by pressing the STANDBY ON/OFF(#3).The default
mode is RADIO,so press the FUNCTION button(#8) to switch to the CD mode.
2. Open the CD door by pressing the OPEN/CLOSE door release button(#9).Inset a CD with the
label facing upwards and close the door.
3. The unit will read the disc and display the total number of tracks found on the disc on the
display
4. To begin playback press the PLAY/PAUSE/BAND button(#1).The first brack on the disc will
play.
5. To pause playback press the PLAY/PAUSE/BAND button(#1) once more.Pressing again resumes playback.
6. Press the STOP button(#2) to stop playback.
7. Use the AL 1/VOL- or AL 2/VOL+ buttons(13,14) to adjust the volume level. Advanced CD operation
1. Press the FWD/TUN+ button to skip to the next track.Press and hold to fast forward the
current track.Release the button to resume normal playback.
2. Press the REV/TUN- button to skip to the previous track.Press and hold to fast rewind the
Random playback
1. Press and hold the SLEEP/RDM button(#15) either during playback or in STOP mode for 2
seconds and then release.You will see the letters RDM appear on the display to indicate the
RANDOM mode in active.
2. If you enable the RANDOM function in STOP mode,press the PLAY/PAUSE/BAND button
to begin playback.If you enable the function during playback the next track will begin the
random order
3. To cancel the RANDOM playback mode,press and hold the SLEEP/RDM button(#15) for 2
seconds and release again.The letters RDM will disappear from the display to indicate the
function has been cancelled.
Repeat function
1. Before or during playback press the REPEAT/PROG button(#6) to repeat a single track
indefinitely.You will see REP appear on the display when active.
2. To repeat all tracks on the disc,press the REPEAT/PROG button(#6) twice(or once more if
you have already activated the repeat once function).You will see REP on the display blinking
to indicate the repeat ALL function is active
3. To cancel any repeat modes,press the REPEAT/PROG button(#6) once more(if in repeat all
mode or twice if in repeat once mode).The letters REP will disappear from the display.
CD program playback.
NOTE:You can only program a playback sequence while the disc is in STOP mode.
1. Press and hold the REPEAT/PROG button(#6).You will see P01 appear on the display to
indicate the program function has been initiated.
2. Use the FWD/TUN+&REV/TUN- buttons to select the track you want to play in slot No 1.
3. Press the REPEAT/PROG(#6) to store the selected track in slot 1.The display will now
display P02 to indicate your selecting the track for slot 2.
4. Repeat steps 2 to 3 for every track you wish to program up to a maximum of 20 tracks. If you
try to program more than 20 tracks the display will revert back to P01 and will overwrite the
first slot again.
5. Press the PLAY/PAUSE/BAND button(#1) to begin the programmed sequence playback.
6. Should you wish to cancel the programming you can press the STOP button to resume normal
function.
Keyboard Shortcuts
Space
Toggle play & pause
Decrease volumePlay next trackIncrease volumeRepeat playing track
M
Mute volume
Play previous track
Seek forward
P
Navigate to playing track
Seek backwardLike playing trackSeek to position
R
Repost playing track
S
Search
On fornt of the player you have the buttons for opreation.You can use these buttons to operate your DVD player with out remote.
I have attached a image for your BD-P1600 player so your reference
1.DISC TRAY :Opens to accept a disc. 2.DISPLAY :Displays the playing status, time, etc. 3.Remote Control Sensor :Detects signals from the remote control. 4.OPEN/CLOSE BUTTON :Opens and closes the disc tray. 5.SEARCH/SKIP BUTTONS :Goes to the next title/chapter/track or goes back to the previous title/chapter/track. 6.STOP BUTTON :Stops disc playback. 7.PLAY/PAUSE BUTTON: Plays a disc or pauses playback. 8.POWER BUTTON :Turns the Blu-ray Disc Player on and off. 9.USB HOST:A USB memory flash stick can be connected here and used as storage when connected to BD-LIVE. It can also be used for firmware upgrades and MP3/JPEG playback.
Thanx
This player has essentially the same guts as my Pioneer PDR-509, so this is what it means...
'Repair' means the player lost power in mid-recording without commiting the track memory to a table of contents. It would likely take up to 40 minutes for the player to reconstruct it from the disk.
There is NO reason the player need be turned off (if that's where it took you) for a track pause.
Just press Pause, flip the LP over and hit Play or Pause again when you wish to continue recording.
Perhaps you don't know how to Finalize the disc either. It's not that intuitive. Press Finalize, after a while it will display a time, like 4:07. That means how long it will take to do the operation. Now press Pause and it will count down to 0:00 and be done. Then you can play it on any other CD player.
it's very easy. attach to PC and drag and drop albums in folders to the player (probably shows as drive 'E' or 'G'.
safely remove from PC and then insert headphone. press the pause/play button on the back to play.( a blue light will show-make sure to charge it up well on the PC!!)
press the track forward or track back to change tracks. hold these to higher and lower volume.
will turn off automatically on pause after a while( blue light will go out)
If there is a "PROGRAM" button, then you just turn on "program", rotate the knob to what track you want and then hit ENTER. Then when you hit 'play' it will only play back that track. You'll have to repeat this for every track or manually hit the PAUSE button between tracks if you program more than one.
Hold down the Display/Menu function button (one of those three buttons on the left of the unit) for about 3-4 seconds until the display reads "t set". When this appears, push the track forward button once (>>|) so the display reads "beep"; now press the play pause button (>||) once. The display will now say "on", push the track forward button (>>|) once to make it read "off"; now push the stop play button. You're done. Enjoy the silence.
