Question about Bosch 30 in. NET7452UC Electric Cooktop
Bosch error code 42 - Bosch 30 in. NET7452UC Electric Cooktop
2 Suggested Answers
SOURCE: net7552uc bosch cooktop error codes 26 and 42
This may be malfunction of the main electronic board.http://www.ifixit.com/Wiki/Edit/Bosch_NET7452UC_cooktop
Posted on Oct 07, 2012
I have a Bosch 30" induction cooktop that has stopped working with no error codes.
Dear Ed,
Sounds like you have a short, perhaps in the cooktop control panel. Please do not even try to get it to work again until it is checked by an electrician, so you do not find your self fighting a fire somewhere between the circuit breaker box and the cooktop.
God bless your efforts.
Jun 01, 2018 | Bosch Cooktops
PIC645F17E (Bosch) electric cooktop show error code er22. What does it mean ? How to repair ? Please help me ! Thank you !
The error code you posted is not listed anywhere. There is the error code "Error" for the oven which means oven overheating. If that's true then the problem is a bad oven power relay board.
This part has been discontinued. Bosch probably replaced it with a different part but I was not able to find the correct part number. You can talk to APP CSR and they will help you to locate the correct part.
Sep 05, 2016 | Cooktops
I have a Bosch Schott Ceran Induction Hob model number ********** and need the manual. Where do I get one please
Try to do a search on the Internet, something like: Manual Bosch + your model number. I have usually had good luck finding a free download. Sometimes there are downloads also available directly on the manufacturer's website as well.
Feb 28, 2016 | Bosch Cooktops
Whirlpool error code e2 f3
The error codes are in the operating instructions if you don't have it ask Bosch to email the error code page to you.
Apr 10, 2014 | Bosch Cooktops
Bosch NET9652UC STOVE TOP shows Er 42
Er42 constantly slashing on my stove top, sometimes lasted for hours. When that happened you can't use the stove top until it stops. What should I do to stop the slashing?
Feb 20, 2013 | Bosch 30 in. NET7452UC Electric Cooktop
Bosch cooktop net 7552uc parts
http://www.bosch-home.co.uk/store/spareparts/search
Feb 07, 2013 | Bosch Cooktops
Error code er26 & er42 for a bosch cooktop
Do this and follow the common sense. God bless you
Lower motorized latch will not lock; Defective or jammed lower oven door or latch switches; Defective latch motor or its wiring. 1. Check P24 connector on the power board.
2. Ensure door latch switches are operating properly.
3. Check that neither latch switch nor common wires are pinched to the appliance chassis.
4. Check P10 connector and check if latch motor wire pinched to the appliance chassis.
5. If F42 persists, replace power board.
Sep 25, 2012 | Bosch Cooktops
NET7452UC Electric Cooktop shows errors 26 and 42. What do they mean?
Problem: Error codes 26 or 42 after turning on too many heating elements.
Potential issue: Damaged main electronic board
Specific case: Error code 42 after turning on more than 3 elements, then already after 2, 1 until none of the cooking element could be turned on, over a period of a few weeks.
Root cause: Dying/blown electrolytic capacitor on the main electronics board.
Solution:
1) Turn off power (circuit breaker) - caution high voltage inside the cooktop
2) Lift the cooktop out of the hole in the countertop and slide it on a flat surface
3) Remove all screws around the metal housing using a torx screwdriver
4) Carefully tilt the glass top out of the housing on the front, noting that there are electrical connections in the rear, and place the rear end of the glass on a stable surface. You may need someone's assistance here.
5) After double-checking that there is no power, record the color coding of the four wires connected to the glass assembly (green for ground, white, black, red from left to right)
6) Next open the black plastic cover by removing four Torx screws.
7) Carefully remove from the connector on the left the the plastic strip connecting to the display board.
8) Carefully remove the circuit board with relays and capacitors that is held in place by plastic tabs.
9) If one of the capacitors is bulging out or showing sings of damage on top, replacing it may fix the appliance. De-soldering a bad capacitor requires some tools and skill. Replace the capacitor with at least the same capacity, voltage and use high-temp. 105C version) Alternatively, instead of replacing a $2 component you will have to replace the entire board.
10) Reassemble and done.
May 04, 2012 | Bosch 30 in. NET7452UC Electric Cooktop
Bosche cooktop nht 725 a uc 1999 need conversion kit to go from natural gas to propane, hate to toss a good stove top need model kit order numbers
I spoke with Bosch customer service who said there is no natural to LP gas conversion kit available for the NHT 725.
Oct 05, 2010 | Bosch 30 in.NGP746UC / NGP742UC Gas...
Bosch 30 in. NET7452UC Electric Cooktop Logo
47 people viewed this question
Top Bosch Cooktops Experts
Paul Carew
Jay Finke
Jay Finke
Narinder Chhina
Narinder Chhina
Are you a Bosch Cooktop Expert? Answer questions, earn points and help others
