I have a hp laptop model no dv 2046 tu...the problem i m facing is that my keyboard's ctrl key is stuck...whenever i press any key....a combination of that key wid ctrl is is taken...example....if i press a, it selects all....which has a shortcut of ctrl a...please help me out...thanks in advance
  • cwhong_jorda Apr 17, 2009
    I have the same problem but sticy keys option was not selected in the first place. Can anyone help?
  • Anonymous May 17, 2009
    Have the same problem. So far only a restart will get the damn Ctrl key to unstick.
    @Dragonrdrz - Nice idea, but I don't think it fits here. I suspect this is a BIOS problem: HP have a BIOS upgrade fix for a similar problem with keystrokes being missed, and it may have caused this. When the Ctrl stuck mode comes on, NOTHING will cause it to unstick, and that doesn't fit the Sticky Keys operation.
    Problem Solver:
  • 16 Answers
This solution is for Windows XP.
If you see no physical sticking, then you may have "Sticky keys" on.
To look to see what your "Sticky Keys" Settings is at do the following:
In "Control Panel" double click "Accessibility Options"
A new window will pop up. The first tab is "Keyboard".
The first box at the top is "Sticky Keys" make sure that is unchecked.
"Sticky Keys" can be automatically turned on if you hold down certain keys for a predetermined length of time. Usually a box will pop up asking if you want to turn it on.
Thank you.
Please rate me.
Posted on Jan 27, 2009
My keyboard wont type
Restore a Laptop Keyboard b> When a keyboard stops working, has odd key letters, stuck keys and non-functioning keys for no reason at all, the laptop may have an easy fix solution. However, if liquid spilled on the laptop or the laptop was dropped and as, a consequence, the keyboard doesn't work, or the keyboard device has simply failed, fixing the problem may require a more involved laptop keyboard replacement.
Click start control panel keyboard hardware make sure you have the right keyboard selected or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers Click start control panel administrative tools computer management device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! or a red X right click update driver if your computer came with a motherboard disk the drivers could be on it. If its still not working Tap the "Alt" and "Shift" keys simultaneously if you are pressing one keyboard key and getting a different symbol or letter. This will reset the keyboard defaults on some laptops. Press the "Ctrl" key and tap the "Shift" key simultaneously if the procedure in Step 1 did not work. Press the "Fn" and one of the "F" keys to disable the "Num Lock." Different laptops use different "F" keys to disable the "Num Lock." Toggle each "F" key and press the "Fn" key at the same time to find the right key combination. Check your laptop manual to find the right key combination. Press the "Fn" key and the blue "NumLock" key simultaneously if the keyboard is typing numbers instead of letters or wrong letter keys and the above steps did not solve the problem. b> Keyboard Maintenance b> Blow compressed air in the cracks and crevices of the laptop keyboard. Sometimes dust and debris can cause keys to lock, making such keys non-functional. Disconnect the laptop from the power outlet and remove the battery. Make the tip of a cotton swab as thin as possible by rolling it between your finger tips. Dip the thinned cotton swab in rubbing alcohol and clean the crevices of the keyboard with the cotton swab. Continue cleaning between each key of the keyboard with the alcohol-dipped cotton swab. Use a new cotton swab whenever necessary. Slightly tip up one side of the laptop so dust will move from under the keys to the crevices so you can clean. Blow compressed air into the keyboard again as you did in Step 1 of Section 2. Reconnect the computer to the power and check to see if the issue is resolved. Insert the flat edge of a flat-blade precision screwdriver under a keyboard key and gently pry it up and off. Remember where the keys go, so you can easily replace them. Remove three keys at a time and clean with a cotton swab dipped in alcohol. Replace the keys and remove the next three. Do this until the entire keyboard has been cleaned. Disconnect the laptop from the power outlet and remove the battery again. Turn the computer so the rear is facing you. Remove the screws that hold the plastic hinges in place. Insert a small flat-blade precision screwdriver in the plastic hinge seam and pry the hinges up. Turn the computer back face forward and open the screen as far back as it will go. Continue lifting the plastic hinge and power plate until it comes off. Remove the screws you see holding the keyboard with a precision Phillips screwdriver. Blow compressed air under the keyboard. Lift the cable connector levers slightly and remove the data cable. Clean the cable pins with an alcohol-dipped cotton swab. Replace everything, power on the computer and try the keyboard again to see if the issue is resolved. b> Keyboard Replacement b> Connect an external keyboard to the USB port on the laptop and verify its working condition. Disconnect the external keyboard and verify that the keys on the laptop are still inoperable. Disconnect the laptop from the power outlet and remove the battery. Remove the laptop keyboard as you did in Step 3 of Section 2 by removing the plastic hinge and power button plate, the keyboard screws and disconnecting the data cable from the motherboard connector. Replace the keyboard with a new laptop keyboard for your laptop make and model.
b>
Jan 11, 2013 | Samsung N145 Plus 10.1 inch Netbook -...
Tip
How to turn on Wireless Switch on your Laptop or Notebook PC
How to turn on the wireless switch on the laptop or notebook
If you have issues in finding the wireless switch on the laptop to turn the wireless on you can refer the below list
1. Dell D600 & D610-Key Board-Fn+F2
2. HP NC4000 & NC4010-Button-Above Keyboard
3. HP NC4220-Button Left Side of Laptop Near USB Port
4. HP NC6000 & NC6220-Button above Keyboard
5. HP NX9010-Button in front side of laptop
6. HP Omni book 6200 Button on Left side of laptop
7. IBM T43 & X32 Keyboard combination Fn + F5 then Click "Turn On"
8. Toshiba M1 & M2 Switch Left side of laptop towards
front
9. Toshiba R100 Switch on the Right side of laptop
10. Toshiba TE2000 Switch on the left side of laptop by Volume ctrl
11. Toshiba Tecra 2100 Switch Left side of laptop by Volume ctrl
12. Sony Vaio - switch on front left
13. Dell - FN,F2 or FN,F8 or FN,F12
14. Acer - FN,F5
15. IBM / LENOVO
IBM General - Some models have the wireless slide button on the side of the laptop.
IBM DV series - use the antenna-like button found on the upper section of your keyboard.
IBM R40 - Use the FN+F5 key-combo.
IBM ThinkPad (General) - Most have software switch or button on Left hand side.
Lenovo T-61 - Slide button on the front of the laptop
16. MEDION
General - Fn+F1 or Fn+F2
17. MSI
General - Antenna-like button close to the power switch
U100 - Fn+F11
18. PACKARD BELL
Easy note B3600 use the Fn+F1
Easy Note E2/MV46/008 - Fn+F1
Easy note W7730, Antenna-like wireless button on the side of the laptop.
MZ36-U024 - Fn+F2
19. PHILIPS
General - Fn+F2 key combo
X54 - Antenna-like button close to the power switch.
20. SAMSUNG
General - Blue button found in the middle section of the keyboard
on Dec 03, 2009 | Computers & Internet
What is the function key to turn wireless on
How to turn on/off Wireless in various Laptop Models ------------------------------------------------------------------------------------
Vendor/Model-----------Type----------Location
Dell D600 & D610-----KeyBoard-----Fn+F2
HP nc4000 & nc4010-----Button-----Above Keyboard
HP nc4220-----Button-----Left Side of Laptop Near USB Port
HP nc6000 & nc6220-----Button-----Above Keyboard
HP nx9010-----Button-----Front side of laptop
HP Omnibook 6200-----Button-----Left side of laptop
IBM T43-----Keyboard combination-----Fn + F5-----Click "Turn On"
IBM X32-----Keyboard combination-----Fn + F5-----Click "Turn On"
Toshiba M1 & M2-----Switch-----Left side of laptop-----Towards
front
Toshiba R100-----Switch-----Right side of laptop
Toshiba TE2000-----Switch-----Left side of laptop-----By Vol ctrl
Toshiba Tecra 2100-----Switch-----Left side of laptop-----By Vol ctrl
Sep 09, 2011 | Computers & Internet
How do i turn my wireless on my laptop
front
Hope it helps !
Jul 14, 2010 | Advent Netbook
I don't know how to turn on wierless
> front
Or you can do that from device manager.
May 31, 2010 | Dell Latitude D610 Notebook
Hi, I have an IBM Thinkpad T41 2373 XGX. The number keys, function keys and other top keys of my keyboard have stopped working. Also, shortcuts like ctrl C, Ctrl V etc. are not working. It is not a...
sounds like a faulty keyboard to me, I recommend removing the keyboard, and blowing out the connector with a can of air and reinstalling the keyboard. if that does not work I would connect a USB keyboard to make sure it is not a setting. If a USB keyboard is working fine, replace the keyboard.
May 19, 2010 | IBM ThinkPad T41 Notebook
How to turn off blue keys for an Compaq mini cq10??
if you are refering to the blue letters or alphabets which are present on the keyboard. HP designs keyboard with a billingual layout in some Notebook models.
The HP "Blue" keys are indeed the "French" input keys or other language keys.
How to use the Blue Symbols or keys on a HP Notebook:
We can activate them by pressing Ctrl+fn+right Shift.To deactivate, press Ctrl+fn+right Shift twice, i.e. Ctrl+fn+right Shift then let go off Shift while still holding Ctrl and fn, then press Shift again.
When you press Ctrl+Fn+Right Shift it will switch to the the billigual layout. That means the blue characters become prioritie.
For example, if you are in the billingual layout, when you press shift+6 you will get a '?' but not the '^' sign.
Mar 19, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Ctrl key electrically stuck
that happens if you ever spilled water or some king of liquid you may need to clean the key witch needs to be taking out i recommend taking it into a pc shop and get a quote
Jan 27, 2009 | HP Compaq Presario F750US
Malfunctioning keyboard
Must be the CTRL key that is stuck...
May 15, 2008 | Dell Inspiron 3500 Notebook
KEY BOARD
It's possible that your numlock is stuck on. I believe on those notebooks you hit FN + Scroll (You should see Numlock in a box underneath the Scroll text on that key).
Feb 18, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Computers & Internet Logo
640 people viewed this question
David Payne
David Payne
