Question about Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 700 does not power on
I have a Magellan Roadmate 700 and it does not power on anymore whatsoever. I plug it into the car cigarette lighter and the green light on the plug come on but the unit itself does not turn on. What could be causing this problem?
  • 20 Answers
Hello, Rafster! Cigarette lighter plug problems are not uncommon, and - hopefully - this is the source of your problem. Because the green LED on your plug is lit, it would suggest that the FUSE inside is okay. Still, it's worth checking! The plug is easy to open, and the fuse easy to inspect/replace. IF the fuse is okay, the cord itself or the plug end that attaches to your Roadmate could be damaged. In order to determine this, you would have to check for voltage at the output end. But, you'd need a circuit tester and a wee bit of electronics knowledge to test it. If you don't have access to a tester, then the easiest test is to simply purchase a NEW cigarette lighter cord. You can get them at most retail discount stores (BestBuy; Circuit City; WalMart; etc.); RadioShack; or directly from Magellan. They're generally less than $10.00!
Posted on Jul 24, 2007
SOURCE:
When i power up my roadmate 700 a message comes up that saysTemperature below safe level. mTake several minutes to warm up. but nothing happens even when its warm
Had the same problem with my MRM 700 back in 2005, only 2 months after I purchased it. They changed the connector, and it worked. BUT, few months later I had the same problem again. I haven't used it anymore since then (moved to another country), now I am trying to fix it but no warranty anymore..
Jan 28, 2010 | Magellan RoadMate 700 GPS Receiver
Repair Roadmate 700
You can try first updating the firmware of the unit and reset it after that..
Hope that helps.......
Jul 17, 2008 | Magellan RoadMate 700 GPS Receiver
Broken RoadMate 700
Here are a few tests you can do. Bear in mind if the unit has not been charged for some time and the internal battery is completely flat, you will need to leave the unit on charge for some time even to get a charge light from the LED. Leave it on charge for at least 2 hours. First, check the LED is lit when the cable is plugged in to the cigarette lighter socket and/or mains charger? If it is not, the fuse in the cigarette lighter adapter may be faulty or the charger may not be working. If the fthe LED is lit, then is power available at the end of the cable that connects to your unit? Use your DC voltmeter to check this. If no power is available here, then your cable/charger is faulty - obtain a new one. If there is power at the connector, then the unit may be faulty.
Jun 10, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan 700 dropped
Creepys Dad,
What's the symptoms? Is the screen cracked? Does it not power on anymore? I'll need further information prior to a response or any response that could possibly fixya.
-Daniel
Nov 08, 2008 | Magellan RoadMate 700 GPS Receiver
All navigation units are GPS Receivers - that is - they receive satellite signals. So, no there is no difference.
Apr 19, 2008 | Magellan RoadMate 700 GPS Receiver
Power wont come on
get a new unit like any magellan mastreo series 4000 or higher or roadmate 800 or higher,i had a 700 they start having alot of problems after i did my research on here.i have the mastreo 4000 and the roadmate 800 both work great.
Feb 23, 2008 | Magellan RoadMate 700 GPS Receiver
No power to unit, but powers on okay in house with AC power adapter
Not sure if you'll see this post, as you asked the question back in Nov, but I
thought I'd tell you what I know anyway.
I and my parents bought the same exact unit within a week of each other.
There's works, and mine does not.
I took their cradle, and hooked it to my GPS, and it came on, no problem.
I took my cradle, and hooked it to theirs, and boom, nothing.
So, with that, I was able to isolate that the problem is definitely in the cradle.
I went to the manufacturer website, registered my Magellan Roadmate 700,
and then I was able to contact customer support. I am writing to you as
I wait for their reply. Here's their website.
https://www.magellangps.com/users/registrationHelp.asp
Hope this helps!
Nov 12, 2007 | Magellan RoadMate 700 GPS Receiver
Roadmate 700 wont power up anymore
I had the same problem. At first intermitant and then permanent. The power connector inside the based that the head unit snaps onto had the center post fall out. You need to removed the 4 small screws located in the threaded reseases. Then using a knife I pried the plastic halves apart. You need to break the ultrasonic bonding on the plastic, but everythign seperated where it should. Now you have access to the circuit board. I soldered in 2 wires which I brought our and soldered to a cigarette outlet cord. Then I screwed it all back together.
Sep 13, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 700 can't power up 2nd time in car
Are you willing to part with it, I may be able to use it for parts [email protected]
Jun 19, 2007 | Magellan RoadMate 700 GPS Receiver
Yes, get a new car connector. -Daniel
Apr 23, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 700 GPS Receiver Logo
385 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Ekse
Are you a Magellan GPS Expert? Answer questions, earn points and help others
