Question about MSI 865PE Neo2-V Motherboard
Changed bios setting will not let me enter setting again or boot
I have a 865pe Neo2 MSI mobo 1 GHz of ram 600 watt power supply nvidia geforce 7300 gt card audigy 2 card pentium 4 3.00 GHz cpu.
I changed my bios settings to allow to boot from a CD b/c i had just run a kill disk on the system. I accidentally changed bios to where it will not boot from CD's anymore for some odd reason even though the cd drive is first in line of boot order. Now the pc just gives me the Vclass screen or thePOST screen but will not let me load bios settings or boot from a cd.... any ideas????
  • vangelispoli Apr 14, 2009
    I LOAD ALL BIOS SETTINGS TO ITS DEFAULTS RUN THE WINDOWS SET UP AND WHEN FINISH THE LOADING ASK ME AND I PRESS ENTER AND APPEAR THIS MESSAGE : SET UP DID NOT FIND ANY HARD DISKS IN YOUR COMPUTER.
    Sniper:
  • 96 Answers
Look at the motherboard's manual to see how to clear CMOS. This means how to load all BIOS settings to it's defaults. The detailed instruction you can find here.
http://www.pcguide.com/ts/x/comp/mbsys/cmosClearCMOS-c.html
Read it carefully
Posted on Jan 27, 2009
    Champion:
  • 203 Answers
Try boot from floppy disk if there is one floppy
MSI 865PE Neo2-V Motherboard does not boot to BIOS. It just powers up and the drive lights are on continuously. Is there a replacement MB that uses essentially the same BIOS and won't require re-formating...
This one is pretty much identical
http://cgi.ebay.com/MSI-865PE-Neo2-P-Motherboard-P4-socket-478-EMS-/180572214688?pt=Motherboards&hash=item2a0af155a0
This one is similar but you will need to reinstall a new audio driver
http://cgi.ebay.com/MSI-865PE-NEO-2-Motherboard-Processor-/200552149636?pt=Motherboards&hash=item2eb1d6f284
Dec 09, 2010 | MSI 865PE Neo2-V Motherboard
What is the max ram that I can install in the 865pe neo2-p board
The MSI 865pe motherboard can use up to a maximum of 4GB of PC1600/2100/2700/3200 non-ECC DDR RAM
Apr 04, 2010 | MSI 865PE Neo2-V Motherboard
Can prescott 800 mother support p4 2.4ghz/1m/533 processor
The MSI 865PE Neo2-PLS
Supports Intel® P4 Northwood/Prescott (Socket 478) processors.
FSB 400 (for Northwood only), 533, 800MHz.
Supports up to 3.2GHz or higher speed.
See page 1-2 in your manual. Also see page 2-3.
MSI supported CPU list; http://www.msi.com/index.php?func=prodcpusupport&maincat_no=1&prod_no=569#menu
Main link for 865PE Neo2 platform; http://www.msi.com/index.php?func=searchresult&keywords=865PE+Neo2
Cheers'
Mike
Jan 20, 2010 | MSI : 865PE Neo2-PLS P4 Prescott FSB800...
Ethernet LAN not detect
Hello download the lan driver from here:
http://www.msi.com/product/mb/865PE-Neo2-P-Platinum-Edition.html#/?div=Driver&os=XP%2032
Try to renew the driver and install the new one.
And check your bios settings for the lan.
Good luck
Jun 02, 2009 | MSI 865PE Neo2-PFS Motherboard
POST problems or XP Stop 0x8E
run memtest 86, test each ram stick, if it shows both as bat, then your mobo;'s memory controller is bad. if neither is bad, then it is your graphix card
Apr 13, 2009 | MSI PM8M-V Motherboard
I am having problems installing xp on MSI865PE Neo2-S, I am now at BIOS, how do I get my computer to boot from the boot disk?
you have to select the boot order anf the first boot device should be floopy drive then save and exit from bios
Dec 19, 2008 | MSI 865PE Neo2-S Motherboard
Is MSI 865PE Neo2-V motherboard support graphic work?
Most of the applications that you have specified above use high amount of the memory. If you are using vista this makes it even worse. Get another 512MB RAM and install it in the next DIMM slot and it will be alright. 512MB Ram should cost you around 500-700Rs.
Nov 13, 2008 | MSI 865PE Neo2-V Motherboard
Bios may be flash, blackout total
remove the ram &u can hear beep
May 08, 2008 | Intel Motherboard
MSI 865PE Neo2-V Motherboard Logo
335 people viewed this question
Top MSI Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
