Question about Barnett Outdoors Tomcat Jr Compound Bow
How to adjust draw length - Barnett Outdoors Tomcat Jr Compound Bow
What is the actual draw length of a crossbow prod / recurve, fiberglass 175 lbs draw weight?
They are all manufacturer specific. Never had anyone ask that before ?
Mar 27, 2013 | Archery
How do I adjust the draw on a Bear Warrior III Bow
look in the manual and you will see what number coinsides with which draw length. On each cam there is a module with numbers on them. You set these to adjust draw length.
Jan 12, 2013 | Bear Warrior 3 Compound Bow Kit
How to adjust string draw length for a bow madness
You have to reset the modules on the cams. Look in the manual for adjustment process.
Nov 15, 2012 | Archery
Why does the bow length need to match my draw length?
The bow length needs to match your draw length because the bow limb is designed to be used at a particular draw length range. For instance if you use a bow with limbs too long for your draw length, you won't be able to flex the limbs enough to make them efficient.
Aug 26, 2012 | Betsey Johnson Archery
What is draw weight?
Generally, the draw weight is the amount of force to pull the bowstring to a certain draw length. The industry standard is measured in pounds at 28 inch draw length.
What is draw length?
Draw length is the distance you can pull bowstring from the resting (start) position to the shooting position. This is different for each archer due to physical length of their arms.
What's the best bow for beginners?
You can findlots quality bows in different prices, but the best bow I advise you to get,the bow I actually purchased myself, is the Parker Sidekick. This bow isdesigned for beginner archers as it comes in 18- to 28-inches of draw lengthadjustable at 0.5 inch increments. Draw weights are available from 20- to40-pounds and 40- to 60-pounds with a comfortable 80 percent let-off.
Jul 30, 2012 | Archery
CYCLING TO OFTEN
You need to adjust the heat anticiptor on the thermostat. Not knowing your furnace control amp draw ..... I would set the anticiptor somewhere between .3 & .7. The slight adjustment should make the cycling run better. If not adjust it the other way. If this does not solve the problem the heat anticipator might be bad (change the thermostat). If you have a digital stat read the manual most are preset at the factory. Sometimes you can reset it by following the directions.
Mar 25, 2009 | Honeywell Electronic Programmable...
Barnett Outdoors Tomcat Jr Compound Bow Logo
83 people viewed this question
Top Barnett Outdoors Archery Experts
Andre De Beer
Andre De Beer
Level 1 Expert
Tom Chichester
Are you a Barnett Outdoors Archery Expert? Answer questions, earn points and help others
