Question about Tatung " TAC-06KN 6 cups Rice Cooker & Steamer, Stainless Steel"
Tatung rice cooker not heating - Tatung " TAC-06KN 6 cups Rice Cooker & Steamer, Stainless Steel"
Tatung rice cooker #TAC 10 CUP. The cook/warm switch button constantly pop up during cooking time. Do anybody knew how to fix the problem?
SWTCH IS DIFFECTIVE AND ONLY EXPERIANCED TECHNITIANS CAN REPLACE IT.REPLACING THE SWICH WILL SOLVE YUR PROBLEM.IF NOT CHECK THERMAL SWITCH.
Nov 04, 2013 | Tatung Kitchen Appliances - Others
The cooker clicks over to "keep warm" before the
You're probably using too much water. Rice cooks primarily while sitting in hot water, not while its boiling. That's why the cooker switches to Keep Warm so quickly. The correct way to cook rice is to pre-soak the rice for about 30 minutes, drain to get rid of the excess starch, combine the rice and cold water and bring the water to a boil and turn off the heat and let it stand for 15-30 minutes. That's why*- rice cookers take 45 minutes or more.
Sep 06, 2011 | Aroma ARC-914 8-Cup Rice Cooker
My toyomi rice cooker model trc56,when plucked in nothing works???
The heating element is probably bad...
Here is a tip that I wrote about rice cookers and the amount of rice and water needed...
How much Rice and Water go in the Cooker
http://www.fixya.com/support/r5396567-much_rice_water_go_in_cooker
heatman101
Aug 10, 2010 | Kitchen Appliances - Others
Can you boil in a slow cooker?
Generally, with enough heat and good insulation, water will boil. Boiling is caused by non-uniform heating - some spots are hotter.
My wife's slow cooker boils even on the low setting -slowly, but it boils.
Our rice cooker never used to boil until I burned tomato rice in it (OOPs). Don't make tomato rice in a rice cooker.
Mar 21, 2010 | Nutritionist 10 Cup Rice Cooker RA10NR
RC4 6 CUP RICE COOKER
There is a sensor that regulates how hot the cooker gets and shuts it down to the warm setting when it senses that the heat is too high...meaning that all the water has cooked off....my guess is that the sensor failed and as far as I know it is not replaceable.
heatman101
Jul 13, 2009 | Black & Decker RC4 6-Cup Rice Cooker
Cooking PLAIN rice
Here is my recipe - enjoy and please rate my answer as a fixya!
Raw Rice - 2 Cups (400 gms.)
Water - 6 Cups.
(The ratio of rice to water is 1:3)
PROCEDURE
Step 1:First wash the rice in water thoroughly and drain the water.
Step 2:Take a vessel ,the capacity of which is double the quantity of raw rice that is to be taken.
Step 3:Now,add the washed rice into this vessel and pour 6 cups of water into it .
Step 4:Now, place this vessel containing rice with water in a pressure cooker and add the pressure weight on the cooker top.
Step 5:Heat the pressure cooker for 20 minutes only.
Rice has been cooked.
NOTE:
*After heating the cooker for 20 minutes,donot open the cooker immediately.Wait for 15 minutes and then open ,otherwise the cooker would burst open.
Feb 16, 2009 | Wolfgang Puck 5-Quart Electronic Pressure...
Farberware 10 cup rice cooker blows fuse after replacement
yeah it has a short in it or just a wire lose from the heater.
open up and check. If you have an ohm meter check the heater. It should not be infinit
Jun 17, 2008 | Rival RC160 16-Cup Rice Cooker
Tatung " TAC-06KN 6 cups Rice Cooker & Steamer, Stainless Steel" Logo
35 people viewed this question
Top Tatung Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Tatung Kitchen Appliances - Other Expert? Answer questions, earn points and help others
