Question about TallyGenicom 2280 Matrix Printer
Hello, I have characters printing trouble, so that I would like to restore the factory default settings for my printer Tally 2280. But I do not know the procedure to do so. I need Helps, very important. Thanks.
  • dennen_tradi May 11, 2010
    austin
    you need to delete the printer programmed driver and restore it again follow up the setting well
    it will be ok.
    Michael
    Novelist:
  • 169 Answers
You can reset the menu on the 2280 to factory default settings, but I would strongly recomend first printing a menu print to ensure you know how the menu is currently set up.
The menu can be printed in the follwoing way;
Switch the printer power on.
Press the Setup key to enter the menu settings.
Press the key under "Menu",
Then press the key under "Print" and your current configuration will be printed.
If the menu is locked power the printer on holding down the setup button, this will unlock the menu.
To restore the factory defaults within the printer,
switch the printer off.
Press all four keys beneath the printer display and switch on the printer.
Keep the keys pressed until "Initializing" is seen in the printer display.
Your printer is now set to the factory default configuration.
Posted on Aug 24, 2009
How to delete previous owner WiFi data and security code
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
Mar 26, 2015 | HP LaserJet 4500 Printer
How to change Tally T2240/24 Matrix Printer character and line spacing
This sounds like an Microsoft Excel issue. The Windows printer driver controls how printing is done regardless of your printer settings.
Excel controls the format of your page with column widths and line height. Depending on your version of Excel, after selecting your print range and your margins, you will need to go to Page Setup and select "Fit to" -- select 1 page wide and a larger number of pages tall.
Jul 25, 2014 | Tally T2240/24 Matrix Printer
Reset printer
On your printer, go to the settings menu -> factory defaults.
Do not restore - this is the factory default setting. Do not restore keeps the user defined settings.
Restore - returns all printer settings to the factory default settings except the Network/Ports menu settings. All downloads stored in RAM are deleted.
Jun 04, 2012 | Lexmark X204n Multifunction Printer,...
Hai , i have tally 2280 sprintpro printer.now it
problem with aga gear open the printer & check the white gears situated left upper of aga motor .......
or
may be aga flag missing or misalinged
Jun 29, 2010 | Tally Matrix T2280 Printer
I would like to know how to reset the Lexmark E260dn to factory defaults. The printer was set with a static IP address and no longer exists on THAT network. I need to set it up as a DHCP client again to...
Restoring the factory default settings
Do one of the following:
• If your printer is on a network, access the Embedded Web Server:
1 Type the printer IP address into the address field of your Web browser.
Note: If you do not know the IP address of the printer, print a network setup page and locate the IP address in the TCP/IP section.
2 From the Settings screen, click General Settings.
3 Under Factory Defaults, select Restore Now, and then click Submit.
• If your printer is connected to a computer by a USB or parallel cable, use the Local Printer Settings Utility for Windows or Printer Settings for Macintosh.
1 Open the utility.
2 Do one of the following:
– From the Local Printer Settings Utility menu bar, click Actions Restore Factory Defaults.
– From Printer Settings, click Factory Defaults.
Warning—Potential Damage: Restore Factory Defaults returns all printer settings to the factory default settings except Network/Port menu settings. All downloads stored in RAM are deleted. Downloads stored in flash memory or on a printer hard disk are not affected.
Or please download the user guide from this link and follow the instructions
http://static.tigerdirect.ca/pdf/Lexmark-E260D-Series-Mono-Laser-Printer-Manual.pdf
Hope this will help you
thanks
Oct 01, 2009 | Lexmark E260dn Laser Printer
Default printer factory settings Lexmark X8350
Please follow the steps given below:
1. Press "Fax Mode" button.
2. Press "Menu" button.
3. Use the "Down Arrow" till the display reads "Maintenance."
4. Press "Select."
5. Use the "Down Arrow" buttons till the display reads "Reset Defaults."
6. Press key pad "1."
7. Press "Select."
Please let us know the results.
This will restore to factory default
Apr 27, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
Tally2250 printing characters and ckd the config on control set
by the default of the printer baud rate is 9600 , 7 1.. just power on the the printer by pressing all four buttons, then it will automatically go to default settings.
Apr 01, 2009 | Tally T2250 Matrix Printer
Tally 2280+ printing in small font
The 2280+ can be reset to factory default settings by;
Start with the printer Powered OFF
Hold down the 4 buttons under the LCD display
Power the printer ON, keep the 4 buttons held down whilst the printer initializes, release the buttons when the printer shows 'Loading Defaults'
Prior to resetting factory defaults I would recommend printing a menu print on the 2280+ so you know how the printer is currently set up just in case there are any problems.
Mar 20, 2009 | TallyGenicom 2280 Matrix Printer
Paper width error on tally genicom 2280+ printer
Power ON printer holding down ONLINE button, release it after TESTMENU is on display. Press NEXT few times, enter APM or somthing like that (or APW? cant remember), switch it to OFF. Press ONLINE. Thats it! Greetings.
ps. this is procedure direct from polish division of tallygenicom servicedesk. it works for me perfectly!!
Mar 12, 2008 | TallyGenicom 2280 Matrix Printer
TallyGenicom 2280 Matrix Printer Logo
183 people viewed this question
Top TallyGenicom Office Equipment & Supplies Experts
Kolbrun...
Raj Patel
Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
