Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Water starts but never turns off
Whirlpool Model 35WTW5205SQ0 - as you start washing the machine starts running before water gets to right level and never shuts off. From wash to rinse water is flowing out of the drum from the top. If you turn manually to spin water pumps out and spins accordingly.
Sorry the model is not listed in the list below - the model is as above being 35WTW5205SQ0
  • 495 Answers
Could be the motor or belt, tilt the machine backwards and look underneath to inspect the belt, try turning by hand see if everything is free (will only freely turn in one direction only as brake acts in one direction). Check motor for rotation, remove the front panel for a look, to remove the front panel, at the seam between the front panel and lid push in a flat knife or screwdriver approx 4" in at each side to release the clips (one at each side). this will allow you to lift the top and then remove the two front panel fixing bolts 7-8mm to remove the front panel.
Posted on Jan 27, 2009
  • Manoj Rout
    Manoj Rout Jan 27, 2009
    Solution:
    Take the panel off right under the round door(3 screws) there is a
    white plug looking like thing(like a gas cap) take that out(water will
    run out so have a bucket or towels or something) you will see all the
    muk muk around this plug clean it off and put back in.
    Master:
  • 505 Answers
Seem like you have a faulty timer which shuts of the water
    Genius:
  • 1,550 Answers
If water is filling the tub, then the problem is with the pressure switch or the control board.
A siphoning problem through the drain hose could also cause this problem.
Make sure that your drain hose is properly installed .
Whirlpool 6th sense washing machine
All washing machines have a water level sensor, this can be a tube into the drum that leads up to a switch normally attached to the inside higher up, what happens is the tube gets clogged up with muck and gives a false reading, which needs cleaning out.
Another problem may be your input valve normally a sngle cold water input, the valve can get clogged with limescale and its just slow to switch off even when the power is off. The default is a closed position.
Try switching the machine off at the plug as soon as it finishes, if it starts filling up its the input valve, these can be under twenty pounds on popular auction websites.
May 11, 2014 | Whirlpool Washing Machines
Whirlpool GSQ9669LW1 washer. Originally Load Size was set to small. After water was filled to that level and machine started to work, wanted to add more water. Turned the Load Size knob to Medium, nothing...
You would have to start the wash cycle all over in order to get enough water for the med load size. Once the washer starts it cycle you have to cancel that cycle to start a new one. Hope this is a help to your question
Apr 24, 2014 | Whirlpool Washing Machines
Getting pe error
Whirlpool Washing Machine Displaying Fault Code PE The part(s) or condition(s) listed below for the symptom PE - PRESSURE SENSOR ERROR // Water level pressure switch error are ordered from most likely to least likely to occur. Check or test each item, starting with the items at the top of the page.
per https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/408-5--/Whirlpool-PE-PRESSURE-SENSOR-ERROR-Water-level-pressure-switch-error
b2kjqj
Dec 09, 2017 | Whirlpool Washing Machines
Whirl pool top load washing machine directly goes to aqua save mode and disable all other functions?
This is just a setting error. For troubleshooting of this error, just enter in diagnostic mode. Keep pressing Program button and then also press Water Level button. Now release both buttons. Now machine will auto run for wash-rinse-spin. After it finishes, Keep program on Normal, Keep water level low and now Start the machine. It will now work normally as before.
Nov 17, 2012 | Whirlpool Washing Machines
WHIRLPOOL DUET WASHER THE WASH LIGHT IS NOT LIGHTING UP WHEN WASHER IS STARTED AND THEN I GET "LF" CODE
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
Is water supply connected and turned on?
Are hose screens plugged?
Is water entering the tub? If so check pressure hose connection to machine/motor control.
Oct 12, 2012 | Whirlpool WFW9151YW Duet 3.5 cu. ft. Front...
Hi. My water level knob is very hard to turn and the water level is not correct when filling the washer. Any thoughts?
if it has been quite some time since you turned the knob it is possible that it is starting to sieze up, you may have to replace the switch behind the knob
May 09, 2009 | Whirlpool WTW5560SQ Top Load Washer
Just water pump start
Check the water supplies at the back, if the valve is opening, and the water is getting into the machine, it can be a faulty water level switch, or membrane sensor, depending on the model.
A faulty or clogged inlet valve can also close few seconds from opening the valve, usually becausu of a faulty solenoid.
If valve and water level switch are ok, then this is a faulty control.
Have valve and water level switch checked first.
Dec 10, 2008 | Whirlpool AWM6120 Front Load Washer
When i start wash. machi. pump starts and few sec.later led flash
Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
172 people viewed this question
Dan Webster
Dan Webster
Sal De
