I have a Ritetemp gas stove, can I convert to LP ?
bigg t
  • 640 Answers
SOURCE: convert from lp to natural gas
you need to change the gas regulator (if installed on back of oven),pilot and burner orfice your ready to go.happy new year.
Posted on Dec 28, 2007
MNTECH
  • 1543 Answers
SOURCE: Converting a GE Profile Gas Range from LP to natural gas
GE ships gas ranges set for natural gas, with the LP orifices included, usually on a metal tab held with one screw right near the regulator (where the gas connects to the range). If the range was converted to LP, the person who did the conversion was suppose to put the natural gas orifices back in that holder. If they are missing, comment back on the exact model number and I can look up the part number(s) for you.
Posted on Jan 06, 2009
  • 5 Answers
SOURCE: How do you convert the oven to lp gas on ge xl44 range
if this is a new stove need to change the pin in the regulator ,
then need to replace the stove top orifices from gas to l.p.
check under the stove for pieces they tape them under there by the regulator -- that how i found mine under my new jenn air
check the stove companies web site for a users manual also
Posted on Mar 22, 2009
buxbud2
  • 3 Answers
SOURCE: Vermont Casting Radiance Gas Stove (RUVSOD) NG to Propane (LP)
Unfortunaletly, due to the delicate nature of vent-free appliances, you'll find that most are not field convertable. If the vent free appliance were to lose its efficiency, you would be subjected to high levels of CO, carbon monoxide, and could likely die. Therefore, field conversion is not recommended and in this case, not possible. Vermont Castings does not provide parts to convert and if they did you would be essentially replacing the entire unit short of the outer cast shell. I wish you luck.
Posted on Apr 18, 2009
freetek
  • 5568 Answers
SOURCE: Want to convert from LP to Natural Gas
Typically, the only thing required is changing any and all jets since energy content and pressure are different. The only source for these is probably the manufacturer; check their website.
Posted on May 20, 2009
Recently acquired an older Hot Point Cooking stove with self cleaning oven. Need to know if I can convert to propane and how to do so. There were no manuals with the stove..
Stove conversion natural gas to Lp - YouTube
? 6:08
https://www.youtube.com/watch?v=iXX2mS6FrxI
Sep 2, 2014 - Uploaded by Clay Rogers
If anyone can do it so can you. ... Stove conversion natural gas to Lp ... How to Convert Your Natrual Gas ...
Nov 15, 2015 | Kitchen Ranges
Gas stove need to switch to propane
Hotpoint supplies the orifices and instructions with each range for converting. It is just that it is hidden, they attach it to the gas regulator. The regulator is near the bottom back typically. Here is a cut out from your use and care manual.
CONVERTING TO LP GAS (or converting
back to natural gas from LP)
This range leaves the factory set for use with natural
gas. If you want to convert to LP gas, the conversion
must be performed by a qualified LP gas installer.
The conversion instructions and LP orifices can be found
attached to the range next to the pressure regulator.
Keep these instructions and the orifices in case you want
to convert back to natural gas.
May 13, 2010 | Hotpoint RGB745 Gas Kitchen Range
Feb 19, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Converting a stove from natural gas to lp
Crank down the orifices and flip the regular nut.
Jan 05, 2009 | Kitchen Ranges
Convert natural gas stove to LP
Nothing is imposible but this stove was not made to be converted. It is a not a classic crank down and flip model. Your best bet would be to get your LP gas supplier to do it.
Dec 15, 2008 | Kitchen Ranges
Flames are extremely uneven and high
okay, DO NOT USE THIS STOVE ON LP GAS.
It's not intended to be used with LP gas, because LP gas requires a smaller orifice than natural gas. Call your propane supplier IMMEDIATELY...DO NOT USE THIS STOVE UNTIL IT IS CONVERTED TO LP GAS (if it's even possible)...this is extremely dangerous and you could hurt yourself if you continue to use LP gas on a stove that was designed to run on natural gas.
Dec 06, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Stove Top Burners
was the stove design for LP????
you need to get a convertion kit form the manufature, if you convert the natual to LP gas.
Oct 22, 2008 | Hotpoint RGB745 Gas Kitchen Range
Conversion
call the dealer and get a converter.
Apr 24, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Change from lp to propane on my whirlpool stove
Propane is LP...(i.e. Liquid Petroleum)
The burners are working only as a fluke. It is extremely dangerous to operate a natural gas stove on propane. STOP USING IT IMMEDIATELY. Call your local propane supplier and ask them about converting it to LP/Propane.
Jan 15, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Low flame
so you stove was converted from natural gas to LP using WB28K10043 KIT-CONVERSION L.P. ? is this correct?
Aug 23, 2007 | Hotpoint RGB745 Gas Kitchen Range
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
