Question about Breville TG400XL Indoor Grill
Floating hinge on Breville model TG425xl has disconnected
2 Suggested Answers
award462
  • 395 Answers
SOURCE: Need Instruction Manual for model TG425XL
http://www.fixya.com/support/r4964670-get_manual_most_any_electronic_device
Posted on Jun 03, 2010
I need a replacement turntable for my brevile combination microwave model brcm2516 where can I get one
First4Spares Glass Turntable Plate For Breville Microwave Ovens ...
https://www.amazon.com/First4Spares-Glass-Turntable-Breville-Microwave/.../B007B...
Shop First4spares at the Amazon Small Appliance Parts & Accessories store. Free Shipping on eligible ... BREVILLE MICROWAVE TURNTABLE Glass Plate 245mm 9.5". $29.99. Next ... Container for Microwave Oven · Add to Cart · Add to ...
Amazon.com: BREVILLE MICROWAVE TURNTABLE Glass Plate ...
https://www.amazon.com/BREVILLE-MICROWAVE-TURNTABLE-Glass.../B00COP... Quality replacement glass turntable for your Breville microwave. ... Small Appliance Parts & Accessories > Microwave Oven Parts & Accessories > Turntables
Breville Shop ' Partmaster
www.partmaster.co.uk/breville/microwave/catalogue.pl?shop=breville&path... Find your Breville products and repair your appliance yourself for less. ... Connects the microwave motor to the glass turntable Suitable for select microwave ...
Breville Canada
https://breville.ca/ Breville designs and engineers small kitchen countertop appliances to deliver commercial quality performance that look great and are easy to use.
Breville Microwave Parts & Accessories ' eBay
https://www.ebay.co.uk > ... > Breville Microwave Parts & Accessories BREVILLE Microwave Glass Turntable Plate Roller Ring Support Stand 3 Wheel ... Turntable Turn Table
Plate MOTOR for BREVILLE Microwave Oven ...
Breville Parts -Google Search
Jul 03, 2017 | Microwave Ovens
Cub cadet LXT 1054 Riding mower
as with all floats there is a pin that goes through the hinge of the float. normally goes in one way unless the bowl holds it in. just pull it out and the float and the needle will come out.
Jun 13, 2013 | Garden
Im going to need to drop my fuel tank in my 1986 camry. I have never done it before but I am capable. So If anyone knows how to do this please help. I dont want to break anything. First Im going to open...
First disconnect the negative terminal of the battery. Next left out the back seat. It is spring clipped in with two clips on the bottom left and right front of the seat. Pull clips forward and lift seat front up. I hooks in at the back so rotate the front up to unhook and lift out. In the middle under the seat is the gas gage float. Disconnect the wire connector and remove floor cover with Philips screwdriver. Then remove float from tank. This step must be done so you do not break the wire to the gas gage float. It is also the best place to siphon off the gas in the tank. Then you can remove the tank. You may have an exhaust shield to remove. The tank is held in with two straps hinged in the front and bolted in the back. Loosen the brake line clamps attached to the straps so that the clamp will slip when the tank straps are hinged down. There are several hoses and a gas connect to open. Open hose clamps. Disconnect fuel pump connector at back of tank. The fill hose needs to be worked off as you pull the tank down. There is one hose on the top back edge of the tank that needs disconnect after the tank is tipped down some. There is a rubber/plastic tank holder connected to the back flange of the gas tank. Remove the two corner screws but leave the guard connected to the straps. Remove the two strap bolts and hinge down to pull it out and disconnect all hoses. Mark with tape or some mean which hose when were.
Jan 25, 2013 | 1986 Toyota Camry
Float in carb.
Hi Stan,It sounds like you are missing your float needle. There is no reasonable explanation for it to disappear if the float was not removed.The float needle is typically made from aluminum with a black conical gasket tip to create the seal when the float is in the raised position to stop the flow of fuel. They are fairly inexpensive to replace. Seeing that your generator is a Powermate 5000, if it is an older unit using a Tecumseh engine you will have to be very specific with serial and model numbers, since Tecumseh has gone out of business. Replacing the float needle is fairly easy. Some carburetor bowls are formed with an uneven bottom to allow proper travel of the float and they must be re-installed in the correct orientation. If the bowl is round and completely flat on the bottom the orientation doesn't matter. After the bowl is removed the float needs to be removed also. Where the float hangs on its hinge there is a stainless steel pin that needs to be removed, some carburetors have a nub on one side that allows the pin to be removed in only one direction. A finishing nail that is smaller than the pin will push it out with little effort. On the top of the float as it would be oriented in its installed position there will be a horse shoe shaped receiver that the float needle slides into, there also might be a small spring in the replacement, be careful with this spring it is easily damaged and easily lost. The float needle is placed into the receiver on the float, then carefully take the assembly and slide the float needle into the orifice while the float is lined up to go back into its hinge. Align the float to receive the hinge pin and slide it in. Make sure that your bowl gasket is in good condition and replace the bowl keeping in mind if the bowl is formed for float swing travel. Add a little gas and check for leaks. If leaks are present the causes will be bad gaskets either on the top of the bowl or the bottom by the nut. Another cause could be that the bowl is rubbing on the float and keeping the valve open, loosen the nut and rotate the bowl until the float swings freely then re-tighten and check for leaks. Last but not least you have the wrong float needle and it is not long enough to seal correctly when the float has risen to the full position. Good Luck,Michael Burke
Nov 26, 2011 | Coleman Powermate Powermate 5000W...
My Breville fresca BES860 cleaning cycle won't start - I hold the three buttons in for 3 seconds and nothing happens. The light has been on for days, and I haven't been able to resolve the issue. Any...
From the model number I guess that you're in Australia? I'd recommend calling Breville themselves on 1300 139798 or speaking to someone at a Breville Service Centre.
Also, is the machine under warranty? I'm pretty sure that's a reasonably new model. Check your receipt and refer to http://www.breville.com.au/care_warranty.asp as it has 12 months warranty.
May 23, 2010 | Breville BES400 Espresso Machine
I have a 2 barrel carb off a 283ci 1967 chev carter carb
no spring poss small wire from needle to float! the way it works is float is up needle close because float bowl full--when fluid or gas goes down valve opens lets fluel in.ck full pump disconnect line at carb crank over with guage should have apprx 7psi of press not less then 5psi carefull gas flameable
Aug 30, 2009 | Chevrolet Chevy Cars & Trucks
Breville TG400XL Indoor Grill Logo
29 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
