Question about Oasis Hunter 54' Ceiling Fan
What is wrong when I replaced the ceiling fan pull string switch and now I do not have speed control
3 Suggested Answers
Coleman37
  • 337 Answers
SOURCE: remote lightswitch won't work.
This may be obvious but you may need to turn the light on with the string and leave it on. Then the remote should work. Sorry if this doens't work or is too simple.
Posted on Mar 01, 2010
SOURCE: I can't find a replacement fan 3 speed switch for
Hi azwaverid!
I just had a similar problem with my ceiling fan, not sure if I have the same model as you (the fan was in the house when I bought it). I do have the exact same pull chain switch (K.T.E 2035080).
I went to a big home improvement store and the salesman gave me some 3-way switch and guaranteed it would work. The switch had only 3 wires, not 4 like the original. Can you guess what happened next? That's right, their part didn't work.
Being an engineer, I could not admit defeat. I consulted with other engineers I work with, and they pointed me to a "mom & pop" electronics store close to my house. I went to Centennial Electronics in Colorado Springs, CO. The sales staff didn't have experience with this problem, but at least helped me and offered suggestions.
I ended up buying a Philmore Pull Chain Switch for $2.51 after tax. This worked perfect! Just be sure to place the wires in the right slots. On my fan, the following positions and wire colors were: L - Orange, 1 - Yellow, 2 - Purple, and 3 - Blue (I just matched them up the same as the K.T.E. switch colors & positions).
Hope this helps!
Bob
P.s. The exact part I used was:
Philmore No. 30-9152 (UPC code: 0 38975 39152 6). The box says (everywhere you see a semi-colon is a line break): Philmore PULL CHAIN SWITCH; L-1-2-3, L-2-3, L-1-3, L-1-2, PUSH-IN TERMINAL; 6A-125V AC, 3A-250V AC; Made in Taiwan No. 30-9152; LKG Industries - Rockford, IL
Posted on Jul 09, 2010
Where can I purchase a Jin you e70469 ceiling fan switch.
ebay 14 bucks
Jin You E70469 Pull Chain Switch for 3 Speed Ceiling Fan 4 Wire 1 2 ...
https://www.ebay.com > ... > Lighting Parts & Accessories
item 2 ze-208s ceiling fan pull chain speed control switch for zing ear 3 speed 4 wire -ze-208s ceiling fan pull chain speed control switch for zing ear 3 speed 4 wire. ... item 3 OEM ZING EAR ZE-208S 3 SPEED CEILING FAN PULL CHAIN CONTROL SWITCH E-89885 DR73 -OEM ZING EAR ZE-208S 3 ...
Exhaust Ceiling Fan Switch 2 Speed Pull Chain Blower Jin You ...
https://www.ebay.com/itm/...Ceiling-Fan-Switch...Jin-You-E70469...-/132376583704 Replaces Jin You E70469, Santa, Gardner Bender GSW-33. The control module provides two speed setting for your fan. 2 Speed Pull Chain Switch. 3" (7mm) Brass Chain. Spark Electric Components LLC. Width 11/16" (18mm). ' eBay!
Jin you e70469 ceiling fan switch Google Search
Dec 12, 2017 | Dryers
Trying to find manual for a Hampton Bay ceiling fan. I have two. Tag on fan says model: AC-552AL, Item# 154620 NN, Another sticker on fan says 05/02 E192641 UL Listed CEILING FAN 47BF
You should find what you need here:
http://www.homedepot.com/b/Lighting-Ceiling-Fans-Ceiling-Fans-Accessories-Ceiling-Fan-Parts-Remote-Wall-Controls/Hampton-Bay/N-5yc1vZbvmuZp4
Apr 03, 2017 | Hampton Bay Dryers
I have a harbor breeze ceiling fan on a dimmer
You have 3 options. You can connect the fan blue and the fan black to the red ceiling wire. Then you will need to control the fan and light with the strings. The wall switch will turn off everything. Option 2 is make sure that there is a switch wired to the black ceiling wire. If there is a switch I would check to make sure the switch is working. Option 3 is to purchase a remote control unit for both and leave the wall switch to shutoff the whole unit. Hope this helps.
Oct 11, 2013 | Speed Ceiling Fan 3-speed Switch By...
I understand that the black and blue wire can be connected to the black wire in my ceiling. ok fair enough. However, in my new bedroom, there is 2 switches on the wall that apparently control two black...
A ceiling fan requires a neutral wire (white), a ground wire (green), a hot wire for the fan (black), and on fans with light kits a hot wire for the lights (blue). These examples will assume that a lighting kit is going to be used, but if it is not terminations to the blue wire are not required and the circuit is greatly simplified The ceiling fan and light can also be wired through switches. When a single switch is used to connect to the ceiling fan and light the ceiling fan (black) and light (blue) would both be connected to the switched black wire. In this configuration turning the switch on would power both the light and ceiling fan. In order to turn just one off, the pull strings would have to be used. The problem with this approach, is that when the pull strings have been used to turn the light or ceiling fan off, turning the switch back on will not work until the pull string is pulled again .
The ceiling fan and light can also be wired through two switches. This would generally be two separate switches, one for the fan and one for the light. This would generally be a 3 conductor w/ground coming from the switch box. The ceiling fan (black) wire would connect to the switched black wire from the ceiling fan switch, the light wire (blue) would connect to the switched red wire from the light switch and the neutral (white) and ground (bare) would connect to the their associated wires..
Jul 07, 2011 | Heritage (5BFW52NK4KG) 52'' Ceiling Fan
Remote lightswitch won't work.
Feb 28, 2010 | Oasis Hunter 54' Ceiling Fan
My fan is several years old and, as of today, only the fastest speed works. Supposed to have 3 speeds. Now it's fast or off!! What can I do?
Generic comment:
There is a switch somewhere that controls this. It might be the pull string or it might be on the fan itself. You must find it. If you know where it is and if, after you manipulate it, there is no change, perhaps the switch is bad.
Can you check these things and let me know what you discover?
a
Sep 24, 2009 | Hunter Low Profile III 20807 Ceiling Fan
I just purchased and installed a Hampton Bay palm beach 48' ceiling fan (close to ceiling mount)Problem is when turned on I hear an annoying hummmmmmmmmmmm, more of a hum at high speed and it graduates...
You have a rotating dimmer switch on the wall to control speed right? If so, it is the wrong type switch. The missed matched switch will cause the humming. Use a regular on/off switch and control speed with the pull string
Apr 29, 2009 | Madison Avenue 04317 Hampton Bay Ceiling...
Only have 2 speeds on a 3 speed ceiling fan- replaced switch, no
no no the problem is with the switch u need to re programm the wires check the old switch
and make the same conection.
Feb 08, 2009 | Monte Carlo (5LCR52MW) Fan
Ceiling fan stuck on high
Try removing 120 volt power from the fan by turning offf the house circuit breaker or removing the fuse from the fusebox that supplies power to the fan. Wait 30 seconds and restore power. This may reset the fan speed control in the fan itself.
May 21, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Oasis Hunter 54' Ceiling Fan Logo
26 people viewed this question
Top Oasis Dryers Experts
Are you an Oasis Dryer Expert? Answer questions, earn points and help others
