Question about Konica Minolta bizhub 420
How do i reset error c4701 bizhub 420
After replacing write unit, c4701 still appearing on my screen
firecontrol7
  • 6161 Answers
SOURCE: Bizhub 420 Photocopier
Have you check the Printer control board. Also does the toner bottle turn? You can force it in 47 Mode. to turn the bottle motor CW or CCW
Posted on Aug 04, 2009
SOURCE: How do I reset the Unit Life after replacing black imaging unit?
Just reset the chip. More details you can find here: http://www.chipreset.eu
Posted on Aug 23, 2009
  • 1297 Answers
SOURCE: Minolta Bizhub C253 - C-11C3 finisher error
The 11XX code refer to the printer and hard .To reset push the reset button or open the front door and close.
Posted on Dec 11, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: I have a konica Minolta bizhub C250 and the screen
I can only tell you they are definately resettable as I do it all the time.
The fuser "fuse" is located in the connector wiring. Once you get the fuser out just look in the area where the large connector is. It is a very small fuse similar to a resistor, green, and is encased in shrink wrap.
The Transfer belt fuse is behind a small black cover. If you pull the transfer belt unit out of the machine about 6 inches, it is located on the front right corner. In other words standing in front of the copier with the belt unit partially out it is on the corner closest to you. You have to remove a screw, a c-clip, a small metal plate and the small black cover is held on with a very small phillips screw.
He is the parts availablitity and part number info.
Fuses are available at http://www.digikey.com/
Transfer Belts
Replace glass fuse 80ma , counter resets automatically.
Item # 507-1218-ND
Fuser Units
Fuse is wrapped in shrink wrap. Cut it out and splice in a 1/16 ma fuse.
Item # F2307-ND
Good Luck and Thank You for using Fixya.
Posted on Oct 08, 2010
SOURCE: bizhub 420 error code c-2801
konica minolta bizhub 420
error code 2801 plesce relese the code prectical met
Posted on Dec 12, 2010
Bizhub error code
Have the fusing unit replaced. One attempt only to reset if you continue to get the code the machine can catch on fire! That would ruin a perfectly good day. If the code comes back after this procedure have a qualified Konicaminolta Service tech look at it.. First power off the machine with both switches. Wait 10 second turn on the switch inside the machine then holding down the Utility/Counter button turn on the second power switch on the control panel keep the utility /Counter button down until you get Trouble reset then touch get a OK then power off the machine wait ten seconds power back on.
Jun 26, 2013 | Minolta Office Equipment & Supplies
How do i reset error C4701 of bizhub 360
4701=index sensor abnormality, turn off main switch turn back on.
Jan 21, 2013 | Konica Minolta bizhub 420
Bizhub C451 error C-3924
c7ff0589-2c1c-428b-8214-5be985c427d0.jpgkonica minolta c451 printing problem
Jul 16, 2012 | Konica Minolta Bizhub C451...
I brought a bizhub 420, how do i reset password
I had an older Minolta a couple of years ago. I'll try adapting what worked for it to this machine. Hopefully this will work.
Press the "utility" button. Then hit "admin settings". Enter a password of 12345678. Then hit "user authentication" and put in "off". Hit panel reset from the main menu.
Again, I'm not entirely sure this will work for the 420 but its worth a shot. Good luck!
Apr 26, 2012 | Office Equipment & Supplies
How do you clear error code on a bizhub C350. A piece of paper was fused on the fuser unit and we were able to get the paper off. Now we have no access because the panel is locked.
while powering up machine hold down utility/counter key until trouble reset appears on screen. select it and ok should apper under it. power down machine for atleast 10 sec and turn machine back on.
Jul 22, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
How to reset fuser unit for konica minolta bizhub 420
In Tech mode :
System 1
Initialization
Counter data fixing unit
Start button
Power cycle the copier
Jun 22, 2011 | Konica Minolta Office Equipment & Supplies
I have a Konica Minolta bizhub D2510F it gives me this error C0501. after searching around I found out that this error is a Fuser error. I replaced the Fuser and the PhotoConductor but I still get the same...
The error has to be manually reset. Here is what I found from the official procedure. Hope it works. How to clear a fuser error code (C0500, C0501, C0510, C0511, C0520, C0521). Solution To clear the fuser error code, perform the following after correcting the cause:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
Note: It is not in the same location as the models 7915/7920.
2. Insert a suitable object into the hole to actuate the reset switch .3. The code should clear and a message to close the front door should appear.
Feb 03, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
C5201 error konica minolta bizhub 420 i removed fuser unit after that coming like this error ple help me
reconnect again your fusing unit. then before you ON your machine you long press utility/counter then press the small circle black, then press trouble reset.off/on
Mar 15, 2010 | Konica Minolta Office Equipment & Supplies
Bizhub 420 error code c-2801
Feb 08, 2010 | Konica Minolta Office Equipment & Supplies
Error code c0-510 come on a konica bizhub 350
Fusing error
1. Press the Warm Restart switch, and “●” appears at the center on the left end of the screen.
2. Enter “3” from the 10-Key Pad.
3. Type the 8-digit service code and touch [Enter]. (Default value: 00000000)
NOTE
• When [END] is touched after a wrong service code has been entered, the Basic screen reappears.
• At the fourth access after entries of three wrong access codes, [END] is not available on the screen. It is therefore necessary to turn OFF and ON the Main Power Switch.
• If you forget the service code, it becomes necessary to replace the RAMS Board with a new one. Take necessary steps not to forget the service code.
• The RAMS Board is not available as a replacement part. If it requires replacement, contact Office Printing Support Division by way of CSES.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
Jul 23, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 420 Logo
37 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
