Question about Boss AUDIO SYSTEMS BV9455 Car DVD Player
Need to know witch rca oiutput on the back of my boss bv9455 i need to hook to my amp
    Scholar:
  • 116 Answers
Depending on the model, if there is a "subwoofer" pre out and yu want subs, use that one. If not and you want it for a sub amp, use the rears, leaving the frints open in case you ever want to hook up an amp for your mids and highs.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
How to connect an boss amplifier
Assuming you have an aftermarket radio. You must remove the radio so you can attache your RCA cables and the remote turn on. Run these down one side of the vehicle back to the amplifier. Run the power wire from the battery back down the other side of the vehicle to the amplifer (remember to place your fuse within 12 inches from the battery connection. You will need to find a grounding point. I recommend removing one of the side carpeted panels to do this. You will be able to find the frame. Make sure to sand around where you will be connecting the ground. Hook wires to the amp (RCA to correct color RCA wire inputs, Ground wire to (-), power wire to (+), and remote wire to it's screw terminal. The other end of the amplifier should have the speaker outputs for your subwoofer(s). Hope this helps. If you need more information visit www.mobileinformationlabs.com
Aug 28, 2011 | Boss Car Audio & Video
Hi i just got a ava1202 boss eq it didnt have instructions this eq has rca inputs and high level speaker inputs can i use this eq with out an amp can smeone plz help me thnk u
Yes you can use the equalizer without an amplifier. That is what the high level speaker inputs are for. You simply take the positive and negative from a speaker and hook it up to the positive and negative high level speaker inputs on the equalizer.
Jun 04, 2011 | Boss AVA-1404 7-Band Car Equalizer
I need help my new BOSS BV9560B display Warinig please stop watch video player when I'm play DVD
It's because the pink wire (brake system) is not connected to anything. It is a safety feature to make sure that you are not watching the DVD while driving. I just installed my BV9990 today and had the same issue (before taking care of that pink wire).
Nov 05, 2010 | Boss AUDIO SYSTEMS BV9455 Car DVD Player
I dont know how to get my Boss Audio BV9455 to play from the USB slot how do i get it to work?
Refer to Manual Setting.... Go on Google.. then Exemple: ( download Boss audio BV9455 DVD player manual... then take the manual you need ..good luck
Sep 30, 2010 | Boss AUDIO SYSTEMS BV9455 Car DVD Player
I have a BOSS BV9455 that keeps on seeking then goes around the stations and comes back to the one it was on, this goes on and on, What to do please????
Turn the manual seek option on. Typically you need to hold the seek button down for a couple seconds and then something like an M should flash and then you go through and push the seek button one by one.
Sep 24, 2010 | Boss AUDIO SYSTEMS BV9455 Car DVD Player
My stereo stop byself i dont now is a fuse?GOT A FUSE IN THE BACK OR INSIDE
its on the back of the deck, there is also one on your fuse panel that is for the power source sent to thedeck
Aug 24, 2010 | Boss AUDIO SYSTEMS BV9455 Car DVD Player
My friend jus bought 2 10 inch kicker l5s and when we hooked them up to his boss 1100 wat amp and hooked everything up they are moving but are not producing any sound. boss amp i do not know any thinbg...
it must be reversed polarity in coil voices of speakers check + - wires from amplifiers fit on coil voices of speakers try to get each speaker to 8 ohms wiring in serial the two coil voices n'd put in paralel both speakers in bridge mode output from amplifier to get most stable power ,
Nov 04, 2009 | Kicker Solo-Baric L5 Car Subwoofer
Stays illuminated wen shut off.
Sounds to me like the (+) wire that is supposed to be hooked to the dashboard light circuit is instead hooked to something that is on all the time, such as Battery (+).
Mar 02, 2009 | Boss AUDIO SYSTEMS BV9455 Car DVD Player
Vedio
you need to ground the brake marked wire
Jan 02, 2009 | Boss AUDIO SYSTEMS BV9455 Car DVD Player
Channels Not Playing
i had afriend who is atechnician. his boss amplifier stopped working on one channel,so what he did is openened the amp,tested the mosfet transistors and it showed signs of failure.then he went shopping for same type of mosfet transistors and with no luck in buying the right type, he put the amp away for acouple of weeks. then one day he hooked it up and strangely it worked again. he told me that while it was hooked up itwent into protection mode and for some reason it worked later. so i would not open it because of static discharge i would disconnect the amp for maybe acouple of weeks then hook it back up.... its worth a try & good luck
Nov 10, 2006 | Boss C350 Car Audio Amplifier
Boss AUDIO SYSTEMS BV9455 Car DVD Player Logo
172 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
