Question about Olympus VN8100PC Voice Recorder
Recorder is full - Olympus VN8100PC Voice Recorder
Olympus WS-802 will not allow me to record, gives "memory full" message
try scanning it for viruses and errors. you can also try to format the device
May 26, 2014 | Olympus WS-802 Digital Voice Recorder
Instant dvd recorder software 'not responding'
Hello Joshua,
Instant DVD Recorder 2.6.1 UPDATER
  • Please install the Instant DVD Recorder 2.6.1 UPDATER if you are using the Dazzle DVD Video Recorder, Dazzle Video Creator or Dazzle Video Creator Platinum with a previous version of Instant DVD Recorder. This updater also includes the hardware drivers.
  • If you are using a Dazzle product already that includes Instant DVD Recorder version 2.6.1, then you do not need to install this update.
New with this version:
  • added support for Windows Vista 64 bit and Windows 7 (32 & 64 bit)(
  • Includes Windows Vista and Windows 7 drivers (for both 32 and 64 bit) for the DVC 100, 101, 103, 107 hardware NOTE: DVC130 and DVC170 don't have 64 bit drivers and can only be used with Windows XP and Windows Vista 32)
  • 16x9 detection
  • PCM Audio (already included with Instant DVD Recorder ver. 2.5)
Supported Hardware:
  • Dazzle Video Recorder ( DVC90) - Windows XP and Vista 32 bit only
  • Dazzle Video Creator ( DVC130) - Windows XP and Vista 32 bit only
  • Dazzle Video Creator Platinum ( DVC170) - Windows XP and Vista 32 bit only
  • Dazzle Video Creator ( DVC100 and DVC101) - Windows XP 32 bit, Windows Vista and Windows 7 (32 bit and Vista 64 bit)
  • Dazzle Video Creator ( DVC103) - Windows XP 32 bit, Windows Vista and Windows 7 (32 bit and Vista 64 bit)
  • Dazzle Video Creator Platinum ( DVC107) Windows XP 32 bit, Windows Vista and Windows 7 (32 bit and Vista 64 bit)
  • and other compatible hardware
Installation Instruction:
  • To be able to install this version, you must own an Instant DVD Recorder Version 2.x full version
  • To install this Instant DVD Recorder version not as an update but as a full version you need to enter your Instant DVD Recorder Version 2.x serial number during the installation process. The serial number was included in your Dazzle product.
  • With Windows Vista 64 bit or Windows 7 64 bit, you need to install Instant DVD recorder 2.6.1 as a full version.
  • If you own an Instant DVD Recorder Version 1.x full version, to only install Instant DVD Recorder 2.6.1 full version.
  • If you use this Instant DVD Recorder Updater to update the Instant DVD Recorder included with Studio Version 12, 11 or 10, please make sure that Instant DVD Recorder is already installed on you system. Please note that the version of Instant DVD Recorder included with Studio Version 12, 11 or 10 can't be installed under Windows Vista 64.
For Windows XP
http://apps.pinnaclesys.com/cdb/register/enter.aspx?checkRegistration=1&langue_id=7&supportFileID=35261&productid=2250
For Windows Vista 32 Bit
For Windows Vista 64 Bit
For Windows 7
Sep 15, 2011 | Pinnacle Dazzle DVD Recorder
My WS 100 says FULL and won't either let me put it
The recorder should be formatted only by using the internal FORMAT function found in the recorder's Menu. Using a computer to format the recorder may corrupt or delete system files needed to run the recorder, so formatting via the computer is not recommended.
Individual files can be deleted from the recorder while it is connected to a computer without negative effects.
Feb 04, 2010 | Olympus WS-100 Digital Voice Recorder
Memory Full
Go to the menu and go to the format option and press enter. This worked for me :). Make sure you have everything backed up.
Dec 26, 2008 | Sony ICD-MX20 Digital Voice Recorder
WS-110 memory full but no files
well, i resolved this myself by going to the sub-menu, and formatting the recorder to its original state. thankfully, i backed up the files on my computer first, so i didn't lose any data, although i did have to go in and re-set all my preferences on the recorder.
lesson: don't MOVE files from recorder to computer. copy them instead, and do the actual erasing from the physical recorder itself.
i don't know if this was the most elegant solution, but at least it did get my recorder up and running again. i'd love to hear if there is a better resolution out there.
Nov 28, 2008 | Olympus WS-110 Digital Voice Recorder
Sony ICD-UX70/UX80 digital recorder...memory full problem
If you press and hold down the "menu" button scroll down to the FORMAT selection and press enter. This will reformat the device.
I had the same problem - I think it arose after disconnecting the IC Recorder when it became unresponsive with the computer.
Make sure you transfer all your files first to a computer or back up source.
Nov 19, 2008 | Sony ICD-MX20 Digital Voice Recorder
I get a "full" message but it is not full
Try this:
4 Formatting the Recorder (FORMAT)
If you format the recorder, all function settings will return to their defaults.
All files stored in the recorder will be deleted.
If you have important files that you want to save, connect the recorder to a computer and
transfer those files from the recorder to the computer before formatting the device.
1 Press the MENU button.
2 Press the FF or REW button to choose “FORMAT”.
3 When the PLAY button is pressed, “nO” is displayed.
4 Press FF or REW to select “yES”, and press the
PLAY button.
After “ARE yOU SURE” is displayed, “nO” will be displayed.
5 Press FF or REW to select “yES”, and press the
PLAY button.
“DONE” displays when formatting ends.
s It may take up to several tens of seconds to finish the initialization. Do not remove the battery or detach
the battery compartment from the recorder during that time. Otherwise data may be damaged.
s Never format the recorder from a PC.
s When the recorder is formatted, all the stored data, including locked files, are erased.
May 28, 2008 | Olympus WS-100 Digital Voice Recorder
Extended recorder
how can i REINSTAL MY N72 NOKIA SOFTWARE
Apr 28, 2008 | Nokia N72 Cellular Phone
Recorder says "PLEASE DOWNLOAD FILES," but there are no files to download
The DS-2 has a format option in the menu under submenu. After you choose start you will see a progress bar and it should return to full record time. Use on a MAC seems to cause the reduced record time more often than on a PC.
Dec 11, 2007 | Olympus DS-2 Digital Voice Recorder
Olympus VN8100PC Voice Recorder Logo
16 people viewed this question
Top Olympus Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
