Question about Dell Inspiron 1501 Notebook
Custome paper size with DMP
I have to print some custom report using Dot Matrix Printer;
Tell me how to it. each time the paper ejected from printer is too larger then its actual size
  • 53 Answers
What operating system are you running?
What is the specifics on the printer?
Open the document in your editor (Word etc)
Then hit ctrl+p (this means to hit the Ctrl key and the p key at the same time) you get a pop box
Select the Properties box located in the upper right hand side of the box
Select the Effects tab
Check the Fit To Page check box and select the paper size you want
Posted on Jan 27, 2009
Stop Ejection of printing paper roll after printing in dot matrix printer
I assume you are printing on roll paper, but printer acts like it is printing on cut sheet paper. When finish the page, it ejects it, but it is not a page, it is a roll and the paper keeps unrolling, right? There have to be a lever that swithes between cut sheet paper and roll paper. Turn it to the oposite direction and the problem should be fixed.
May 18, 2015 | Matrix Office Equipment & Supplies
Custom size doesn''t present on your driver on Form to Tray Assigment in
Hi, I can't understand what "Custom size doesn''t present on your driver " means. the drver is just the piece of sofware used by windows to make your printer work. Custome size setting should have nothing to do with the driver.
Feb 23, 2008 | Epson LX-300 Matrix Printer
How to add custome page size to tallygenicom 6306 printer with windows xp i have to use width 15in height 12 please rplay soon
Ok, I think the problem you are having is when printing from a version of Windows, basically the problem is the 6306 can only print 13.6 Inch Wide, it looks like you are trying to define a paper size 15 inches wide.
As the paper size defined is wider than the capability of the printer, you do not see this paper size within Windows.
The solution to the problem may be much easier than you might imagine as it is very unlikely you actually want to print 15 inches wide, you more than likely want a paper width of less than 13 inches but are including the sprocket holes and margins at the side of the paper.
Simply define a paper size the width of the printable area of the paper, so long as this is less than 13.6 inches you will then be able to select this within Windows.
Sep 21, 2011 | TallyGenicom 6306 Matrix Printer
Hi, One of our client using epson lq-300+II dot matrix printer to print their invoices in custom defined paper (using crystal report). It was working fine when they were using windows xp. Now they...
Hello, Please, if you can change back to the former operating, is either the printer type is not compactable with the new windows(Windows7). But first you have to check the net to see if you can try upgrading the software of the printer. Please if you've done this let me know what happened next.
Mar 26, 2011 | Epson LQ 300+ Matrix Printer
Custem size paper are not creat
am using an Epson LX-300+II dot matrix printer in Windows XP. I am
trying to print checks that are tractor feed 8.0" x 3.66". I added the cusotm
paper size in the print server and it is saved correctly, however, when I try
to print, the print properties dialog does not show the paper size. In fact,
there are many paper sizes in the print manager that do not show up in the
list of available paper sizes.
Apr 13, 2010 | Epson LX-300+ II Matrix Printer
I have limited option for my TVSE HD-745 Dot
Paper size and pagelength are normal set by the incoming print datastream.
You can usually set this up from within the application you are using to generate the print datastream.
Let me know if I can assist you further.
Don
Jan 13, 2010 | OKI MICROLINE 320 Turbo Matrix Printer
EPSON LQ - 2180 paper settings
I HAVE CUSTOME SIZE OF PAPER WHICH IS NOT AVILABLE IN THE PRINTER LIST .WHEN I DEEL WITH WINDOS XP
BUT WHEN DEEL WIHTH WINDOS 98 ITS OK
NO I DONT HAVE WINDOS 98 . MY QUESTION HOW I CAN ADJUST PAPER TO CUSTOM SIZE
Oct 28, 2008 | Epson LQ-2180 Dot Matrix Printer
PRINTING ON CUSTOM SIZE PAPER
you need to change the page lenght on the printer. to do so...
  1. turn off printer
  2. press and hold the tear off button while turning on the printer
  3. a menu of the setting will be printed
  4. just follow the instruction
  5. you need to set the page lenght for tractor feeding to 8inchs
turn off the printer it willsave the setting
Jan 01, 2008 | Epson LX-300+ II Matrix Printer
Bizhub 200 printing custome envelopes
Do not know if this helps, but I could not print Com 10 envelops until I said the type was "normal" - Type "envelope" would tell me I had the wrong size.
Dec 12, 2007 | Minolta bizhub 200 All-In-One Printer
Dell Inspiron 1501 Notebook Logo
54 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
