Question about Sewing Machines
The feed-dog on a Bernina 930 Record will not raise up. Help
  • 106 Answers
SOURCE: feed dogs
If the machine has a 'darn' facility and this is selected the feed dogs 'will' stay down.
Other than that(without looking) i would guess a good clean and a dose of lubrication would not go amiss.
Try removing the needle plate to see of there is any compacted "fluff/lint" or indeed anything else stopping the dogs rising. Take off the bottom access cover have a good clean out and oil.
Best of luck
Rob
Posted on Mar 28, 2008
  • 192 Answers
SOURCE: feed dog switch
Did you turn the handwheel? The feed teeth will not come up until the machine is operated. Run it a few stitches and they will come up.
Posted on Nov 01, 2008
  • 19 Answers
SOURCE: Bernina 930 where to put oil
There are two key points I suggest customers can do themselves to help lengthen the life of their machine. One is your hook and the other is the needle bar...
Hook - Open your bobbin door, removee the bobbin case/bobbin. On the upper left corner there is a small latch, push in the latch and your shuttle race ring will fall down forward. You can now remove your stainless steel hook. You need to keep this hook clean and the lip it fits back into clean and void of lint and debris. On the back of this hook or the "lip" that the hook fits back into apply a small amount of hook/sewing machine oil.
Needle Bar - Open up your head cover, the needle and needle bar clamp is attached to a long stainless steel rod that travels vertically inside your head. All sewing machines have a needle bar that looks like this. This bar travels thru two brackets attached to the frame of the machine. Rotate your handwheel and clean the needle bar well of debris. Rotate the handwheel so that the needlebar is in it's highest point and apply a small amount of oil to the upper and lower bracket of the frame, rotate the handwheel so the needlebar slides back down and therefore lubricating it and the inside of the brackets.
Hook oil or sewing machine oil is relatively inexpensive from all quilt, sewing machine, repair shops.
Be sure to take your machine in a minimum of every three years for proper cleaning and lubricating of all the other parts (This is of course for average home sewing machine use 8hours a week)
Posted on Jan 08, 2009
SewTechWayne
  • 186 Answers
SOURCE: Raising and Lowering the feed dog on Janome 4900 MC
These machines are known to have this problem. The feed lift cam has a groove worn in it that won't allow the feed dogs to come back up. It is on the lower shaft and needs to be replaced. You can get the feed dogs back up by taking off the needle plate and lifting them up manually while turning the hand wheel. They should stay up until you drop them again.
Some people will not replace the cam and live with it.
good luck!
Posted on Feb 08, 2009
SOURCE: feed dogs
I was having trouble with this too, but found more help online...you have to switch the dog feed back to 'up'....then turn the needle wheel toward you....the feed dog should snap back into place :)
Hope this helps :D
Posted on May 01, 2009
Bernina 1230 manual- How do you raise the feed dogs?
Perhaps the manual for the 1260 will help (pg 5, item 18):
BERNINA Sewing Systems
Sep 05, 2017 | Bernina Sewing Machines
My bernina 930 speed has basically came to zero. the wheel is turning but the needle is moving very slow and even stops moving even when the wheel is turning. what could be the problem?
Um, how long since the last clean and oil? Sounds like the machine has seized due to old dry oil preventing things from moving. Avoid using the machine until the problem is addressed or the motor may be damaged. (Do this and you will be surprised at how nicely your 930 will run!)
Wheel on right side that controls the needle up and down is very tight...
Bernina 930 Record Oil Diagram
am looking for bernina 930 service manual dropped the feed dogs and they...
Mar 17, 2017 | Bernina Sewing Machines
I am looking for a bernina 930 service manual. I dropped the feed dogs and they will not come back up.
Most likely they have seized due to lack of regular oiling. I have used the following method on several older seized Berninas with great success. Just be sure to NOT get any oil near the 930 basting stitch mechanism (about the middle of the needle bar) or it will most likely lock the machine.
This is a diagram for the Bernina 830 Record, but it will give you a good idea of what & where to look for oil ports.
I've never used this source (use at your risk):
Bernina record 930 electronic service manual
Nov 25, 2016 | Bernina Sewing Machines
I have been away from sewing for a while but have recently begun again. I have a Bernina 1010. The fabric feeder has quit working. Any trouble shooting tips? I no longer have my manual.
Hm, I'm more familiar with the Berninas older than the 1010. The old mechanicals will seize if they haven't been regularly oiled. Could be the feed dogs on your machine have seized for the same reason.
I've resurrected several seized Berninas from a 930 on down to some 530s by opening the top, side, and bottom and applying a couple drops of oil where metal rubs on metal. After the 830 Record, Bernina stopped including any extensive oiling directions in the owner's manual, even though the 930 requires it frequently. (Some say Bernina really wanted the repeat maintenance business, but the 930 also presented some special issues with the basting stitch and the electronic board.) However, I am uncertain how much a user can oil a 1010 without causing damage. Most Bernina manuals provide information for oiling the race but don't go beyond that. Something that may be worth trying is directing hot air from a handheld hairdryer into the area that houses the feed dogs to see if that loosens anything.
Whatever you do, don't use WD-40, 3-in-1, cooking oil, or anything other than fresh good quality sewing machine oil.
You can find a manual for the 1011 here. It may be close enough to your model to be of some use:
There are some Yahoo groups whose specialty is the Bernina owner/lover, ie BerninaThirtySomethings, and some others. They are a very helpful and knowledgeable group that could be of assistance to you.
Oct 30, 2016 | Bernina Sewing Machines
How to raise the feed dog to grab the fabric better
Most Berninas have adjustable presser foot pressure. The new machines are pretty obvious as Bernina has added dials that do that. The older machines, you have to look for a screw above the needle bar that will loosen or tighten the pressure. There is usually a long spring associated with it.
This is a picture of a 930 oiling diagram. But, if you look at the arrow second red arrow from the left (top picture), points to the adjustment screw on the 930. You might find something similar for your machine.
Nov 17, 2015 | Bernina 1008
My Bernina 930 does not feed the fabric through the feed dogs. Hoe do I fix this?
Did you unknowingly drop the feed dogs, as for darning? It is the lowest knob on the right, the silver dial in the center raises and lowers the feed dogs.
Feb 27, 2015 | Bernina Sewing Machines
Sewing Machines Logo
35 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
