Audio somehow stopped working on my Sansui TV . I've tried resetting the tv, using both the cable and regular remote and I've went to the audio settings and tried changing things . I'm not sure what's
Audio somehow stopped working on my Sansui TV . I've tried resetting the tv, using both the cable and regular remote and I've went to the audio settings and tried changing things . I'm not sure what's the problem here. Please help!
    New Friend:
  • 4 Answers
Had a jensen that did the same so i bought a surround sound and hooked up through sat box hope this helps you save some money and get better sound
Posted on Jan 23, 2013
SOURCE: Remote won't work
I would try 'waking up' the remote-Take the batteries out,press each button once then put the batteries back in.See if that works.
Posted on Dec 31, 2006
techman
  • 3130 Answers
SOURCE: Changing the Recording speed from SP to EP on TV/VCR Combo using universal remote?
I am sorry to have to tell you this, but the only way to change the recording speed is with an original remote. If you look on the original replacement remote link I posted here you will see the SP/EP selector, this is to change the recording speed. Good Luck. http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=DS13TVR90&brand_pn=FISHER_DS13TVR90&mode=large&uid=11755283300930
Posted on Apr 02, 2007
SOURCE: unlock apex tv model # AT2702
i need to unlock my tv
Posted on Dec 05, 2008
  • 905 Answers
SOURCE: TV audio too low with converter box
leave the volume up on the tv to 50% - 80%, then adjust it from the volume on the box's remote control
Posted on Jan 09, 2009
SOURCE: CODE FOR COMCAST REMOTE FOR HCT TV
I was told by the folks at HCT that the TV uses remote control code 1226 but you can also use NEC or LG brand codes as well. Hope this helps. BTW, their number is 1-866-500-3020.
Posted on Apr 16, 2009
Need sansui 076k0ut011 led tv remote codes to program an rca tv
reset sansui tv remote control 076k0ut011 Questions ... - Fixya
www.fixya.com > Forum > Tags
...your help in advance. need code for a one for all URC-2060B06 sansui tv try these ... ...sansui tv with a RCA 704 remote control I have sansui tv and a RCA 704 remote ... URC-3021 Remote Control: How do i program this remote to a sansui tv? ... TV Remote Controls Sansui Remote eBay NEW Orion Sansui JVC LED TV ...
reset sansui tv remote control 076k0ut011 Flat Panel ... - Fixya
www.fixya.com > ... > Tags > reset sansui tv remote control 076k0ut011
Flat Panel Televisions reset sansui tv remote control 076k0ut011 questions and answers. ... ...sansui tv to program rca remote to it model # HDLCD1955C need tv code for this model ... Question about Contex 39-inch 1080p LED TV LE39D3.
Original Sansui - Orion TV Remote Control 076K0UT011 ...
? 1:00
https://www.youtube.com/watch?v=mPbRsUI0xnk
Dec 21, 2012 - Uploaded by ElectronicAdventure
Original Sansui - Orion TV Remote Control 076K0UT011 - Save $5 with ... have the New Original Remote ...
[PDF]Operating Instructions For 4-Function Cable
Dec 16, 2015 | RCA Televison & Video
My sansui tv has an interuppted sound. How do I fix it
It's all electronics so unless you call the sansui customer care not much can be done. If you have a audio system then connect the audio out from TV to aux.in of your sound system. That way you can still hear the TV audio. I hope the audio out of TV still operational!!
Mar 02, 2015 | Sansui Televison & Video
Hmdi input has lost audio
several things could cause that:
1. hdmi cable is no good.
2. receiver and TV are not fully compatible. I noticed few times that philips tvs had problems with denon receivers. Some times you need o unplug hdmi cable and plug it in back to get sound.
3. firmware issue. depends on model of your receiver there could be a software upgrade to resolve the problem.
4. somebody (kids) accidentally pressed some buttons and reassigned video input for that video source (video select button on a remote control), etc. Resetting the receiver usually helps.
5 Receiver (hdmi board is no good) or TV is no good.
so next time when it happens check video source, video input assign then try to swap hdmi cable and TV
Nov 28, 2011 | Denon Audio Players & Recorders
I hooked up the new digital box Comcast sent, but it has no audio. I disconnected the box and tried it by itself and it still has no audio. I went through the menu manually as the remote for the TV does...
I suspect you mean by disconnecting the box and running it by itself you mean you tried to run audio from your TV by itself? Somehow you need to go through the menu on your TV setup to see if the audio output isn't either turned off or muted. THere may also be a switch on the back of your TV near your output jacks which gives a option of Speaker on or off. If the speakers are on and your TV audio works I would suspect a issue with either your patchcords or the Cable Box. I am not familiar with the Comcast Digital Cable box (I have analog). But you may want to refer to the manual or to them to see if something in the menu may turn on audio for that as well.
After doing all that (whew)... and if nothing works you may have a issue with the TV amp. If nothing is hooked up to the tv (as if you were just watching "On Air" with an antenna and no stereo connected can you hear audio?
Let me know.
Kindly, DAVID
Mar 09, 2011 | RCA F27676BC TV
The tv is a Sansui HDLCD1909A I can't find a
The only audio output on the HDLCD1908 and 1909 series of Sansui tv's is the coaxial audio out jack. It only works when the tv is tuned to a digital station on the tv's internal tuner. If this won't work for you try getting your audio from your cable or sat box, etc. I hope this helps you.
Jun 24, 2010 | Sansui HDLCD1908 19 in. LCD TV
How do I hook up dvd player
It should hook up like a regular VCR does. A short cable from the OUT on the back of the dvd player to the cable hookup on the back of the tv.
You can also use audio/video wires (3 wire cable). Somewhat same method...connect 3 wires to audio/video OUT of the dvd player to COMPONENT section on the back of the tv. Should be color coded to match colors on the 3 wires.
Hope this helps some. It is difficult to explain. Good luck!
Jul 31, 2009 | Sansui DTV3200 32" TV
No surround sound
Your not goingto achive true dobly sound you need a HDMI solution for this and hence you dvd player is rather old since it does not use HDMI if you want true HDMI sound you need to purchase a DVD with HDMI outputs to the TV
May 24, 2009 | Sansui 19 in. LCD TV
Hooking up external speakers to Sansui HDLCDVD320
I'm sorry, but the Sansui HDLCDVD320 has no analog audio out jacks. If you have a cable or sat box, etc, you might be able to get audio from their outputs. I hope this helps you.
Dec 14, 2008 | Sansui HDLCDVD320 TV/DVD Combo
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
