Trio stealth pro 7 won't stay on when power cord is pulled out
leecom72
  • 4806 Answers
SOURCE: Toshiba Satellite C655-S5082. Won't power
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Posted on Jul 16, 2011
luis_david
  • 407 Answers
SOURCE: ACER ASPIRE ONE D255E POWER CORD WON'T CHARGE
Hi: Acer chargers have a very short life time, in the past 2 years I had bought 2. Just buy a new one from amazon they're very inexpensive. Here's the link: http://www.amazon.com/Laptop-Adapter-Aspire-AOA110-AOA150/dp/B0028LK6IU/ref=pd_bxgy_e_text_b
Regards,
Posted on Sep 25, 2011
  • 5382 Answers
SOURCE: pixma ip1600 won't turn on. No power cord just a cord from printer to computer. I unpluged the entire system and waited 15 minutes and it still won't power up. Any suggestions?
You need the power cord which has a polarized plug on one end. The other end (a figure 8 like shape) will fit into the printer. See http://gdlp01.c-wss.com/gds/7/0900005347/01/ip1600esi_us.pdf . Amazon and other sites have replacement power cords for Canon inkjets and inkjet multifunction printers. One source: http://www.amazon.com/Canon-ip1600-ip6600d-ip6700d-Printer/dp/B003XT2LKC .
I hope this helps.
Posted on Apr 06, 2012
SOURCE: pull cord pulls hard won't start
Remove the top engine flywheel & pull cord cover
Most likely dirty,as well as worn out. or the cord
is in the wrong place,you will see that,once apart
You can work on it some & down the road
get a new one if you have to
Posted on Jun 12, 2012
  • 430 Answers
SOURCE: Hello I have an echo pb-500T, my cord won't pull.
Remove the impeller and check for loose motor mount screws. With the impeller off and the spark plug removed and the pull start functioning properly; if it still wont pull then its likely internal and due to be replaced.
Posted on Oct 25, 2012
Trio Stealth G2 HYpe tablet will not connect to wifi. Had been working but now can't get the wifi to turn on.
I had intermittent trouble with connecting my Trio Stealth Pro 7" tablet to my secure wireless. I have since upgraded my DSL modem / Bridge and have not had an issue since. You should contact your service provider if you have had the same equipment for a number of years.
May 28, 2014 | Mach Speed Trio Stealth Pro Trio Stealth...
Trio stealth pro wont connect to pc
trio tablet ge wram when chargeing and want power up
Feb 26, 2014 | Mach Speed Trio Stealth Pro Trio Stealth...
What number do u do if ur trio stealth pro is not working
More then likely you powered the unit on before it had enough of a charge to operate, Chargers for these types of tablets are way to little power for these things, will hold the charge when you use it but will not charge the unit when you use it, needs to go into standby to charge. Hold the power button and see if you can get a reboot screen or a turn unit off screen. Turn the unit off fully let it charge up alll the way then powere the unit back on. Should reset it. If not look for a small hole in the unit that says reset. push this and see what happens.
Nov 28, 2013 | Mach Speed Trio Stealth Pro Trio Stealth...
Where can I find the serial number on the trio stealth pro 9.7 in tablet?
the serial number is beside on your power input , its stick with colorless plastic.
Oct 15, 2013 | Mach Speed Trio 4GB 7" Trio Stealth Pro
Trio stealth pro frozen
Try this factory reset from androidtablets.net, (Pressing Vol (-) and Power together). The first time I held them down with the machine on, the light changed color then went off. The second time I held them down with the machine off and it started as normal. I'm not sure which worked I'm just glad it did.
Mar 31, 2013 | Mach Speed Trio 4GB 7" Trio Stealth Pro
Trio Stealth pro 7 inch tablet will not boot up
http://www.slatedroid.com/topic/41611-rooting-procedure-the-trio-stealth-pro-97/
javascript:void(null);
Mar 05, 2013 | Mach Speed Technologies TRIO TRIO-STEALTH...
My Trio Stealth Pro 7 in. Internet Tablet will not connect to my wi-fi.
I HAVE AN TRIO STELTH PRO.I AM ON RR INTERNET.I CANNOT CONNECT TO INTERNET NOR WI-FI AT HOME BUT I CAN TAKE IT TO MY DAUGHTERS & IT WORKS FINE.ALSO MY LAO TOP WORKS OK ON MY WI-FI.IT IS BLOWING MY MIND.THANKS TROY PRUITT
Jan 30, 2013 | Mach Speed Trio 4GB 7" Trio Stealth Pro
Is there an operator's manual for the trio stealth 9.7 tablet?
Hope this helps: Link HERE
I was looking for the same things with little to no help.
Jan 21, 2013 | Mach Speed Trio Stealth Pro Trio Stealth...
Computers & Internet Logo
David Payne
David Payne
