Question about Ovens
I have a kenmore gas wall oven it will light and heat up after about 10 minutes it shuts off and shows F13 what is wrong with it
    Sergeant:
    Champion:
  • 249 Answers
What is your model number is then we can start to fix your error code about that
Posted on Jan 22, 2013
  • 146 Answers
SOURCE: jmw8527AAb Jenn Air Electric Wall Oven
Has anyone done any repairs to the oven lately? It sounds like it's working in reverse. The fan is supposed to come on about 10 minutes after the oven is turned on. The reason I ask this question is if someone did work on it they could have wired the fan relay wrong. If not you have a problem with the oven fan relay. They occasionally short and it wll cause them to run the opposite way they are supposed to.
Posted on Dec 21, 2007
TheMobilian
  • 8220 Answers
SOURCE: Kenmore gas oven won't heat up
If your ignitor is coming on that means the oven control is supplying the power to the ignitor and gas valve. So the gas valve is ok because it is allowing for a complete circuit so what the heck is wrong? The ignitor MUST draw 3.5 amps in order to open the gas safety and allow the gas to come out. The ignitor must be very bright, if it is dim then it is bad. (MORE)
Posted on Feb 09, 2009
jumptrout51
  • 3361 Answers
SOURCE: Wall oven will not light
Remove the flame spreader panel to access the ignitor.
Place a clamp on amp meter on the ignitor wire and turn the oven on.
If you read less than 2.9 amps, replace the ignitor.
If you read 2.9 to 3.2 amps replace the gas safety valve.
Posted on Mar 28, 2009
  • 22 Answers
SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Posted on Apr 25, 2009
SOURCE: my oven turns off on me after only a minute never heating up fully
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turning then replace fan. If mains voltage is not present then its the thermal switch.
Posted on Sep 17, 2009
My gas oven won't ignite, takes several tries to ignite it.
All gas appliances have a thermal cut out this will shut the gas off if the flame goes out the down side is when the thermal cut out becomes faulty it can shut the gas of when you are using the cooker the only fix is to replace the thermal cut out
Jan 18, 2015 | Kenmore Ovens
Code (numbers/letters) are shown when trying to use oven (F13)
Try shutting the power down for a couple minutes and this may reset the control If it continues then you will need an error code guide to see what is causing the problem. Sometimes there is a little mini manual on the back or inside the control panel. If not you may need to call for service.
Sep 01, 2014 | Kenmore Ovens
Kenmore oven shuts off before preheated
On any gas appliance there is a high and a low limit temp stat which could be indipendant or on the gas valve it's self, that is faulty.
When the oven reaches temp, it cuts out. sounds like faulty over heat stat.
Mar 21, 2014 | Ovens
Kenmore elite dual fuel range model # 790.75503- My power was cut off and since my oven won't heat (display shows on, but doesn't heat - stays at 100 degees) - also my burners won't ignite (unless I t
It could possibly be you are not getting 240 volts to the range. The top igniter may be getting a current back through the other side of the 240 circuit and that is why it works when the oven is turned on but the oven will not be getting power to heat. Have the 240 circuit checked or make sure the circuit breakers are reset correctly.
Feb 09, 2014 | Ovens
My Maytag CWG3600 AAB still will not light after following your suggestion that the safety valve was stuck and bought a new one. So now the ignitor and safety valve are new. I removed the regulator and...
Its old tech2332 again. I know its a dumb question but did you disconnect the gas inlet from the regulator and see if their is gas flow into the safety valve. With a new ignotor with proper amp draw from it into new gas safety valve their is no reason what so ever that oven shouls not be heating. That the only possibility that thier is go gas to valve
Aug 12, 2011 | Maytag 27" Built-In Double Electric Wall...
Why does the Oven take so long to light?
It sounds like it might be a sticking gas control valve for the oven or the hot surface igniter for the oven might be weak. You will need to turn the oven on and off completely several times until the problem happens. When I say completely I mean turn on the oven control and watch the igniter start to glow. Then when the oven burner comes on(should within a minute) shut of the oven control and wait for the igniter to stop glowing completely and burner to shut off completely. Then repeat the process again. If you try it about 10 times and nothing happens then the problem will be difiicult to identify. If you turn on the oven control and the igniter comes on but the gas burner does not then try giving the gas control valve(located in brolier/storage compartment) a tap with a wrench. If the burner suddenly comes on then the control valve was sticking. Try repeating the shut down/turn on process again. If it does not do it again you may have fixed the problem...if it does you will need to remove the igniter and test it with an ohm meter(should read at least 500 to 800 ohms). If the igniter is testing good and glowing brightly then the gas control valve would be the suspected problem. And remeber to be very careful when doing these testing procedures so you do not hurt yourself.
Nov 12, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
I replaced the igniter (glow bar)on our Kenmore
IF THE UNIT IS 14 YEARS OLD BE CAREFUL THE GAS VALVE MAY BE GETTING TO THE POINT WHERE IT IS NOT SHUTTING OFF AS QUICK AS IT USE TOO, YES THIS WOULD CONCERN ME ,YOU DON'T KNOW IF ONES OF THESE TIMES THE GAS VALVE MAY NOT SHUT AND GAS BUILD UP COULD BE POSSIBLE ,NOT A GOOD THING. PLEASE BE CAREFUL
Aug 31, 2009 | Kenmore 33464 / 33465 / 33469 Gas Single...
Put in new wall oven , turned on power and set
my kenmore double oven model 41165 has no power....its hardwired 40 amp....it stopped working when it was cooling down after the slf cleaning cycle..we had a storm and had a minute power outage. Finakky got the door open but it wont turn on at all. Tried the breakers but i stll get no power....no even the bulb.......thanks....
Jun 07, 2009 | Ovens
Kenmore stove oven does not shut off
Wow, this post is going to be extremely late. Actually, I was able to get a new control unit for my Kenmore gas range from Sears Parts Dirext for $156.06. That includes shipping and tax. The burners work without it. We just cannot use the oven until the new board comes in. It's very easy to replace. Remove the panel screws on the back (just the top) and you have access to unplug the unit and remove the 4 screws holding the assembly in.
Jun 05, 2009 | Kenmore Ovens
Slow oven lighting....bakes for 20 minutes than stops heating
Hi, The oven should ignite within 20 to 30 seconds. The most common problem is that the ignitor gets weak and will not open the gas valve like it should. This would be my first part to change.
May 09, 2009 | Frigidaire FGB24S5A Gas Single Oven
Ovens Logo
53 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
