Question about Samsung YP-T10 Digital Media Player
It fell in the sea and doesnt work
The buttons lighten up when plugged into the computer and the computer acknowledges it but doesnt turn on
    Problem Solver:
  • 5 Answers
If you have a warranty on the player then you should call customer service and see if they can repair it for you.
Posted on Feb 01, 2009
Sea escape above ground pool reset button want come on
if the reset button wont come back on un plug pump if it comes back on bad pump motor if it still doesnt work bad gfci
Jul 15, 2014 | Pool & Spa
Hi, my iphone fell out of my pocket, now its not coming on
remove the battery, wait 30 seconds, press on off button once, put battery back and turn it on, if doesnt works needs to diagnose it using a computer.
Jul 18, 2011 | Apple Computers & Internet
My computer is not acknowledging the numeric keyboard because I had to have another hardrive installed. What can I do? My keyboard came with my computer and is much better than the computer acknowledged...
If the keyboard has a round plug (PS/2) then it must be plugged in BEFORE you turn the computer on and make sure none of the small pins are bent or broken. PS/2 plugs are keyboard and mouse specific so make sure it is the keyboard port. Typically it is color-coded purple.
Make sure the Numbers Lock is engaged. There should be Num Lock button and many keyboards have a Num Lock light that turns on.
Try the keyboard on a different computer, it might been damaged when the hard drive was replaced.
Buy a replacement keyboard, the are really inexpensive online. I recommend www.newegg.com
If this helps please vote for my solution. Good luck!
Feb 03, 2011 | Computers & Internet
My comp shut off and wont turn on anymore.. lightening bolt comes
Please remove the battery and ac adapter and then press and hold the power button for 25 - 30 seconds after that connect the battery back and then try to turn on the machine. if not remove the battery and just plug in the adapter and then try to turn on the machine. If still not working then try to swap the ram. or else your system motherboard requires to be replaced.
Jul 15, 2009 | HP Pavilion dv6000z Notebook
Pc struck by lightening. it was on a surge protector and plugged straight into the cable internet service, another pc in the house was on a SP but used a router/adapter for internet serv...it survived but...
There is NO WAY to tell everything that has been damaged on your computer without testing. You might replace the power supply only to find your motherboard does not work. You may find your DVD drive works, but not your hard drive. You may find that slot 3 no longer functions but slot 2 works fine.
Jul 12, 2009 | Gateway Computers & Internet
Hp pavillion will not turn on, took battery out and put back in still not working. blue light around power cord on and blue lightening bolt flashes
Hi Iceprincess5
The three flashing lights indicate the battery is dead. Since it still wont power up with the cable plugged in I'd say the port has gone. Try wiggling the adapter about in the port to see if it begins to charge. If not then you would need to take it to a laptop repair centre to get a new dc port soldered on or buy a docking station.
May 15, 2009 | HP Pavilion dv2700t 2.5GHz Intel Core 2...
Sansa clip 2 gig computer doesnt find
This is the method that will force Windows to recognize the Sansa: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 29, 2008 | SanDisk Sansa Clip MP3 Player
Motorola h700 wont work...
well mine fell too,there is an inside trigger that turns on, off the headset when you unfold ,fold the boom.the trigger fell out when i dropped it.you can see the tiny hole near the boom under the headset where the trigger is or was,but is mostly viwable from the inside.so now your headset doesnt have a trigger to turn it on.i touched with a knife the metal inside button(the one tregger presses)and now its always on.sorry.
Dec 24, 2007 | Motorola Mobility H700 Wireless Headset
Its not working
Maybe the hold button got knocked on the opposite side of the power button. try moving that and try to turn on again
Dec 11, 2007 | SanDisk Sansa m240 MP3 Player
AC Adapter
Hey thats one of two things your (internal charging unit) if so your SCREWED if not its the sowtware issue witch means you gotta tweak the settings especially if you just upgraded your OS if tweaking doesnt work then re-install your OS then set your OS setting Correctly to the best of your knowledge have fun...it take a bit of patience and a couple hours i had the same prob.....seeya
Oct 28, 2007 | Dell Inspiron 2200 Notebook
Samsung YP-T10 Digital Media Player Logo
24 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
