Question about Samsung NP-N102SP 25.7 cm 10.1inch LED Netbook - Intel Atom N2100 1
How long charging time of samsung n102sp
Cause i charge almost 24hrs ,but she did not fully charge. my charge its functionally win i flag in to my laptop,
SOURCE: samsung e900 - battery life
replace the mobile phone charer and then try
Posted on Feb 07, 2008
  • 1550 Answers
SOURCE: Samsung s1030 will not retract lense
Try hard reset . Remove the batteries and insert new batteries . Sometimes this may work
Another chance is that lens is struck
* Carefully inspect around it for dirt or debris
* If you see any dirt or debris around the lens, use canned air to gently blow it away
* After removing dirt and debris, turn the camera on and off
This should work.
Try this alternate solution (got information from HP )
  • Turn off the camera, if possible.
  • If an SD memory card is installed, remove the card.
  • Remove power from the camera as described below:
  1. If you are using only batteries for power, open the battery/memory card door and remove both batteries.
  2. If you are using only the AC power adapter, disconnect it from the camera.
  3. If you are using both batteries and the AC power adapter, remove both batteries and the power adapter.
  • Wait for 15 seconds. Then reinsert the batteries and close the battery/memory card door or reconnect the AC power adapter to the camera. If you are using both batteries and AC power, try each method separately.
  • Turn the camera on and off. If the lens does not retract correctly or the camera does not turn on,
You need to take to service center .
Thanks for using FIxya
SAM ANDERSON
Posted on Dec 09, 2008
  • 3 Answers
SOURCE: samsung L200 10.2
I called 1-800-samsung, and they sent me a new battery. After the problem insisted, they asked me to ship the camera back to them (still under warranty). The concluded that the cable was defective, and they shipped me a new one within 1 week. That was fast!!!
Posted on Mar 14, 2009
SOURCE: i'll charged everyday my samsung mobile phone
change battery or check the network mode
Posted on Apr 09, 2010
toy_ladi
  • 484 Answers
SOURCE: Battery depleting way to fast
The cause is that the phones battery terminal head is faulty so it is draining the battery.
The terminal head is the metallic link that connects the battery to the phone.
The terminal is also connected to the board of the phone, so to fix this, you have to be very careful as it requires you soldering some components on the phone.
Get the appropriate screwdriver, unscrew the phone,use a flat object and apply a little force on the line that goes round the phone to split it open.
You will see the terminal as it is connected to the board of the phone, carefully use a pin tip soldering iron to remove the terminal head, then replace it with the new terminal head you acquire for it.
Ensure you do not tamper with the board of the phone.
Couple the phone back together, and turn it on with a fully charged battery.
Take care
Posted on Jun 15, 2010
Have bought 2nd hand casio TE 8000F. 'operator mistake' constantly appears. when i remove the slip cover this message clears and new instructions INIT appears with 1.Flag Clear or 2. Init 2. What should...
Make sure flag clear is highlighted (use the arrow buttons) then press yes button. It should check files then place you in REG mode. It might have had a flat memory battery so make sure you leave it on for 24hrs to charge
Nov 23, 2013 | Casio Parts Cash Register PC Desktop
Samsung N102SP doesn't boot
Sounds like a Ram or processor failure. Any beeps?
Take the battery out and pull the power. Wait 2 min and put the power back in and try to boot. That is a start.
Nov 16, 2013 | Samsung NP-N102SP 25.7 cm 10.1inch LED...
Mouse is not working in samsung n102sp i need help to fix
If your touchpad has stopped working it may be because you have deactivated it by pressing a small button near the touchpad. it may also be activated by pressing one of F keys (F5 for instance) in conjunction with the Fn (function) key usually found at the bottom left of the keyboard.The button combination will look like a finger pointing to a square.
Aug 04, 2013 | Samsung NP-N102SP 25.7 cm 10.1inch LED...
The cursor is not working
samsung n102sp plug charger it off solution plz
Samsung gt-b7320 drains battery charge while charging. why?
hello there!
the battery of your phone is not functioning well. meaning, you have to replace a new battery for your phone.
tip:
don't use the phone while charging. let it be fully charge. and not to overcharge it too. because using the phone while charging will reduce the life span of the battery.
thank you for choosing fixya and kindly rate this post.
Jan 25, 2012 | Samsung Cell Phones
My dad has a new scooter. he did not use it for some time the battery died... when i charge it back it won't charge... what would i do?
please rate my answer as a thumbs up 1 to 4 please,im disabled myself & do this cause i care not for profit.If the batteries are [AGM or GEL] you could have ruined them by letting them run down.Start again with the charging & follow the guidelines as to charging.& go from there,have the batteries tested,if they are ok,ur mobile again.Also you could visit:www.alldatasheet.com & download as a PDF File the info on your product,you can keep in Adobe Reader or Print for future.I have an electric scooter myself & the charging of the batteries is really important,if i just go 1/4 mile i will put them on charge.i have a trickle charger,mine can be left on for 3 months if im right.But IF BATTERIES ARE NOT USED WHEN FULLY CHARGED,BEST TO DISCONNECT THEM,SO THEY KEEP THEIR FULL CHARGE.HOPE I WAS OF HELP COLIN.
Aug 02, 2010 | Electric Mobility Power Electric Scooter...
Palm Charging
Synchronize your E2, then work on draining the battery all the way down in order to reduce the effect of battery memory. Memory happens when we repeatedly partially charge a battery. Over time the battery will forget how to keep a full charge, but will remember how to be partially charged. That's usually when users realize there's a problem. The first step is to drain the battery and FULLY charge it at least fully on the battery's indicator, but if you can, let it sit for 24hrs. The second step is to try to use the battery more before charging it and let it charge fully (ie-overnight) before using it when you need to charge it.
Good luck and let me know how you make out.
Jan 09, 2008 | Palm Tungsten E2 Handheld
Samsung NP-N102SP 25.7 cm 10.1inch LED Netbook - Intel Atom N2100 1 Logo
21 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
