Question about Dell E207WFP LCD Monitor
Small crack in the LCD - should there be any picture at all?
I was given the monitor with a small crack at one corner of the LCD panel. When the monitor is turned on the screen brightens a little, and won't do anything else. If the only problem is the LCD panel, then maybe it'll be worth fixing if I can ever find a cheap replacement, so... Should the screen be blank when the monitor's on, or does the monitor probably have some other problem? Or do I just not have enough data to tell?
  • Anonymous Jul 20, 2007
    The menu button doesn't seem to do anything. There is a vertical band of slightly-lighter-screen-area, about 3cm wide, that slowly moves from one side of the screen to the other, and if I press the button to the left of the menu button the band jumps to the center of the display.
    (There are four buttons - from right to left: '+', '-', a menu button, and a button that has a monitor-like box with an arrow pointing into it.)
  • 147 Answers
Ted,It sound like the LCD was Dropped,Data going to it,Should show up,How about when you Press the Menu button does it display the Menu Let me know ttech
Posted on Jul 20, 2007
SOURCE:
What does the small rotating circle on the top right hand corner of my sony bravia mean?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 19, 2014 | Sony BRAVIA KDL50EX645 50 Inch 1080p...
Cracked screen on lg lcd tv small crack 6in up an 8in from right can still see picture ok but have a 1in white line running down from small impact area and a light grey 1in line across from impact area...
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jul 22, 2017 | LG 32LD450 32 In. LCD HDTV
KDL46W4100 no picture small white crack is visible when turned on. Crack got longer and eventually went across entire screen. People have told me the lcd is broken and it's not worth fixing - ie the part...
Yes, thats correct.
If lcd tv screen got hit by some thing then lcd panel got cracked and does show distorted lines or cracks instead of picture and lcd panel have to be replaced that would cost you 70% to 80% of new tv price.
New TV is better option.
Dec 16, 2009 | Televison & Video
Can I replace the glass on a sony KDL26S2010 small crack in lower left corner. Some lines in picture. Thanks
That is a very expenxive procedure. It is actually the screen of the TV, and not just glass. You can try to see how much the whole screen cost. Also it is a challenging job for the consumer.
Nov 25, 2009 | Sony KDF-E55A20 55 in. LCD Television
Black spot is growing on my LCD Monitor
It is the LCD itself failing, no repair for the LCD itself, the screen will need to be replaced. Likely cheaper to replace the entitr monitor
Sep 20, 2009 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
How do I open a samsung 740N LCD Monitor
Lift the front frame. You must try to lift it from the inner side using your fingers (no tools , you may scratch the lcd panel). A little force is necessary especially at the corners. Once you lift the panel from all four sides then the corners will come out.
Note: A common problem with this monitor is the psu. A small number of capacitors fails. You will notice 3 electrolytic capacitors have been deformed and if there is no power you will find a small 3A fuse (looks like a resistor) blown.
Sep 30, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
On the Screen Red pixels comes in the background
hi
if you are see red pixels then your monitor haveing LCD Panel problume.
thanks
Ashok
Jan 14, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Need a new power cord
There are many configurations for power cords You will probably find the appropriate one here. http://www.mpja.com/products.asp?dept=306
They include a small diagram in the upper right corner of the pictures that is an end view of the cord to help you identify your.
Jan 03, 2008 | Hyundai L90D+ 19" LCD Monitor
Dell E207WFP LCD Monitor Logo
109 people viewed this question
Ekse
Clive
Clive
