Question about ASUSTeK COMPUTER Asus P5k-vm/p3-p5g33/dp_mb Intel G33 1333fsb Micro-atx Motherboard For P3-p5g33
P5g33 power cycles - ASUSTeK COMPUTER Asus P5k-vm/p3-p5g33/dp_mb Intel G33 1333fsb Micro-atx Motherboard For P3-p5g33
Windows could not start Error 1068
http://answers.microsoft.com/en-us/windows/forum/windows_vista-networking/windows-could-not-start-error-1068-the-dependency/79
63d72a-5d73-44fe-8316-058c462
READ IT.
Apr 05, 2013 | ASUS P3-P5G33 Motherboard
Fisher and Paykel 7.5 washing machine keeps powering off during rinse and spin cycles
The pump has a thermal safety cut out on it.
If the pump gets too hot it cut out.
Just put a new pump in and your all going again.
Aug 05, 2012 | Fisher and Paykel Washing Machines
Pc is not booting after cpu replacement
Have you ever used overclocking of cpu? Sometimes incorrect values change CPU/DDR/PCI frequences that may cause damage of motherboard in case of incorrect pci and ddr frequences.
May 03, 2012 | ASUS P3-P5G33 Motherboard
Without doing the minimal setting test to see if a time clock works how do you test a time clock with defrost termination the x terminal
8145-20 is 240Volt defrost timer:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#8045
You are testing the 8145-20 timer.
The timer dial should rotate continuously. Trippers on dial rotate around. When they reach the trip switch, the timer starts the defrost cycle.
Terminal 3 has power during defrost cycle.
Terminal 4 has no power during defrost cycle.
With 240Volt timer, terminals 1 and 2 and N and X test for live power to ground at all times.
The limit switch is connected to terminal X and to terminal N.
During the defrost cycle, the limit switch measures the pressure or temperature.
When pressure or temperature reaches the set point, the limit switch closes the circuit and this trips the solenoid inside timer. The solenoid turns off the timer relay, and the defrost cycle ends.
At this point the timer turns off the defrost, and sends power to the refrigeration.
Terminal 3 has no power during refrigeration cycle. (The opposite of defrost cycle).
Terminal 4 has power during refrigeration cycle.
Test these terminals for power to ground. One or the other should have power at all times, but not both.
If timer will not enter defrost cycle, make sure the X-3596 trippers are not worn down.
Disconnect the wire to terminal X and see if defrost cycle will start.
Test terminals 3 and 4 again and see if removing wire from X caused a change.
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 14, 2011 | Paragon 8145-20 Defrost Timer
What is cycle power? My printer can't work!
its just a defination for ur question Power cycling is the act of turning a piece of equipment, usually a computer, off and then on again. Reasons for power cycling include having an electronic device reinitialize its configuration or recover from an unresponsive state of its mission critical functionality, such as in a crash or hang situation. Power cycling can also be used to reset network activity inside a modem. Power cycling can be done manually, usually using a switch on the device to be cycled; automatically, through some type of device, system, or network management monitoring and control; or by remote control; through a communication channel. In the data center environment, remote control power cycling can usually be done through a Power distribution unit, over TCP/IP. In the home environment, this can be done through home automation powerline communications, via IP protocols (wired or wireless), or by phone line.
Mar 12, 2010 | HP PSC 2410 All-In-One InkJet Printer
New system does not start
You'll have to enter the BIOS, with whatever key or key combination and change to boot from cd. Usually ( Delete ) Key..Put your install disk in and reinstall the system. The (MBR) Master Boot Record and system drivers are for your old motherboard and hardware. It requires a fresh install to load the proper motherboard drivers and what not. Use a different hard drive if you need to recover old saved files from your old drive. Hope this helps....
Please rate this solution if it helps.. Thank You....
Nov 02, 2008 | ASUS P3-P5G33 Motherboard
Hoshizaki KM-450MAB Ice Machine
maybe not. it could be that the heating cycle is taking a lot of time to remove the ice from the evaporator that is why the electronics is shutting off the compressor as a protection. check the heating cycle if it is working fine. check the evaporator for dirt that would hold the ice slab from falling down quickly. check the level of the unit. it may have move and now its out of level. the unit must be leveled with the ground.
Feb 21, 2008 | Hoshizaki Cubelet Ice MakerDispenser Water...
ASUSTeK COMPUTER Asus P5k-vm/p3-p5g33/dp_mb Intel G33 1333fsb Micro-atx Motherboard For P3-p5g33 Logo
14 people viewed this question
Top ASUSTeK COMPUTER Computers & Internet Experts
Steve Kozy
Steve Kozy
Level 1 Expert
Ron TheFlash Smith
Ron TheFlash Smith
Level 1 Expert
andrewcahoon
Are you an ASUSTeK COMPUTER Computer and Internet Expert? Answer questions, earn points and help others
