Question about Sewing Machines
How do I adjust the timing on my SINGER CG590C
The needle is hitting the bottom plate that rotates under the bobbing casing instead of going down into the hole to catch the bottom thread, it's breaking and bending the needles.. I know it has something to do with the timing and what makes it slip out of time?
    Problem Solver:
  • 5 Answers
If you have a zig-zag machine check to see if the needle is set to the correct position. If you are trying to zig-zag, be sure you have the wide holed throat plate on.
Posted on Feb 27, 2009
Singer serger 14u
Sounds like your needle is hitting the needle plate instead of going through the tiny hole down to the bobbin. Try using the handwheel slowly and watch. Or perhaps the needle is hitting the bobbin case. Something has been knocked off the straight I think. Has your machine been dropped or dmamaged?
Oct 15, 2013 | Sewing Machines
I have a Confidence 7470 purchased in May 2009. I was sewing tulle today and the thread kept snapping while sewing. I assumed it was catching in the tulle. The last time it snapped, the thread jammed in...
Sounds like your machine is off timing, When the machine is properly timed, you should see the hook passing behind the eye of the needle when the needle is on it's upward stroke. If this is not correct the machine will not pick up the bobbin thread. You may have to take it in for adjusting, unless your a bit machnical.
May 11, 2011 | SINGER 7470 Sewing Machine
The needle hits the bottom of the plate, instead of going to the hole in the plate. So, it seems that the plate was shifted a little. how can i get the plate to shift back to its normal position or to get...
Actually, first make sure you have the needle in properly... take it out, then replace it taking special care to hold it straight up and down. If that doesn't work, then the screws on your plate may be loose or one is missing, so manually shift the plate back to where it needs to be and tighten screws.
Dec 17, 2008 | Singer Inspiration 4210 Mechanical Sewing...
Needle is hitting plate under the bobbin
ure needle is too long. They sell differant size needles
Nov 18, 2008 | Singer 7422
Singer 6038 needle issues
That sounds like the needle is not in straight or is bent.
Oct 13, 2008 | Singer 6038 Mechanical Sewing Machine
I have a singer 5817c
1.Remove the machine needle plate.
2. Remove the bobbin case.
3.Insert a new needle.
4.Turn the handwheel towards you by hand, and watch the
needle going down.It should go down all the way, and start coming Up again, WITHOUT TOUCHING ANYTHING.
Check, and let me Know.
Jun 09, 2008 | Singer 5050 Mechanical Sewing Machine
Needle hitting bobbin plate
Is the needle inserted correctly with the flat side at the rear and fully up into the holder ?
If yes, take off the needleplate, remove bobbin case and slowly rotate the handwheel towards you watching the relationship between needle, and the "hook" of the moving "race".
Set on wide zig zag........when the needle is fractionally past it's lowest point, and starting to rise, the hook should be level with the left side of the needle when on the right hand stitch of the zig...the eye of the needle will be below the hook, and ready for thread to be picked up for the stitch to form.
Any other result will mean your timing needs adjusting.
Feb 09, 2008 | Singer 7422
Singer 7442 - Needle hitting bottom
FIRST DETERMIN NEEDLE BAR POSITION TURN STITCH REGULATOR TO LARGEST STITCH, THEN TURN HAND WHEEL TIL' NEEDLE IS ABOUT TO ENTER NEEDLE PLATE.
AT THIS POINT THE FEED DOGS SHOULD BE JUST AT OR JUST UNDER PLATE. IF SO NEEDLE BAR IS, IN CORRECT POSITION,AND TIMING WILL BE SET AT THE HOOK.
TO SET TIME REMOVE NEEDLE PLATE TURN HAND WHEEL SO NEEDLE IS IN LOWEST POSITION. USING A SMALL RULE RAISE NEEDLE BAR 3/32 OF AN INCH ( OR 3 MM FOR A METRIC RULE) .HOOK POINT SHOULD BE IN CENTER OF NEEDLES WIDTH. LOOSEN THE 2 SHAFT SCREWS
SLIGHTLY,TURN HOOK TIL CENTER OF NEEDLE. TIGHTEN SCREWS. IF NEEDLE BAR IS OUT OF TIME. BRING HOOK TO CENTER OF NEEDLE AND LOOSEN SCREW IN LEFT COVER. RAISE OR LOWER NEEDLE BAR TO SET 3/32OF AN INCH. THE 3/32 MUST BE VERY VERY CLOSE.
Nov 26, 2007 | Singer 7442 Mechanical Sewing Machine
Sewing Machines Logo
455 people viewed this question
Top Sewing Machines Experts
Irene Tulloch
Are you a Sewing Machine Expert? Answer questions, earn points and help others
