Question about OKI Office Equipment & Supplies
Oki cx3641 is making a noise from back right corner on startup, what is it and how do i fix
Everything says its normal and ready to print, however when going to copy or print there is a unusual noise coming from back right corner of machine. Have taken all apart there are no jams and no visual damage.
flopez
  • 161 Answers
SOURCE: Paper Jam in OKI B4300 Led Printer
This printer is designed with a dual toner/drum chamber. Do not separate these two parts. Upon opening the lid, you will find the toner/drum assembly right in front of you. Pick it up with both hands and pull straight up. After that, you should be able to take the jammed papers. Know this: once a paper is jammed, printing another paper will NEVER take the first out. Just make sure to remove the complete papers. If they break, make sure you extract all the pieces.
Posted on Sep 22, 2007
  • 18 Answers
SOURCE: paper feed malfunction
sounds like the item in the paper path that you can not see. or it has a faulty sheet feeder or some gears have failed in the printer
Posted on Sep 25, 2007
flopez
  • 161 Answers
SOURCE: Oki C9500 makes VERY LOUD clunking noises but prints fine...
The sound is most probably from one (or more) of the drum units. You can check by taking them out and trying to run the visible gears by hand. If you have spare drums, change them one at a time until you find the defective one.
Posted on Sep 26, 2007
SOURCE: The printer is noisy when printing
all printers are noisy  ,and repetitive it could be the toner
Posted on Oct 25, 2007
PORRATEC
  • 25 Answers
SOURCE: error code 1300
THIS ERROR IS CAUSED BY POLIGON MOTOR OF THE LASER SISTEM. IF YOU CAN GET TO IT, JUST OPEN IT , LUBRICATE DE SHAFT AND YOUR PROBLEM WILL BE SOLVED. GOOD LUCK.
Posted on Oct 30, 2008
Oki cx3641
You might have to go into the service screen and reset it yourself
Oct 16, 2013 | Office Equipment & Supplies
Ink flaking off printed labels
your problem is not good fusing. try with a different fuser.
Apr 10, 2013 | Oki Brand Oki 62433501 C711n Laser...
Service Call 069: Error
My printer (Oki C330dn) experienced a hardware issue that placed it in a mode where it displays a 'Service Call 069: Error' on startup after the hardware problem was corrected. I used the following button combination at startup, which corrected my issue. Press and hold the BACK, DOWN ARROW, and OK buttons and power-on the unit. Continue to hold the buttons until you see RAM CHECK and some asterisks then release. This forces the unit to ignore all warnings and errors while placing it in an online mode. My printer came up to a ready state and worked normally. The next time I turned it on, it started up without any errors.
Aug 17, 2012 | Cisco Oki C330Dn Led Printer - Color -...
Strange clicking noise OKI C5600
it is not the toner it is the drum. just replace the drum and it will be fine. you may of noticed your printer has been printing a little streaky. i have had this problem with my c5600 and after i replaced the k drum (the noisy drum) it was fixed intill 4 months later when the blasted thing broke again
Jun 02, 2010 | OKI C5400 Laser Printer
Functional Noise
Not normal, top right back corner have inverter board and power supply board. It may be the transformer making noise. you are better to exchange it.
May 26, 2010 | Sony KDL-32EX400 32 in. HD-Ready LCD TV
Replace fuser E error
Reset Fuser counter Oki B6200 Action: Power on and wait until the ready to print message appears on the operator panel. Press "Select and the Down arrow button at the same time" The following Menu is displayed"Reset Counter Fuser U4" Press the right arrow button Operator Panel will display "Fuser U4 Use the SEL to Reset" Press the SELECT Button Operator Panel will read "Clearing" Press the Menu key to return to "Ready to Print Mode"
Apr 05, 2010 | OKI B6200 Laser Printer
OKI c3200n "COMMUNICATION ERROR"
try switch off, unplug, hold up and down & reset button at the back, swith on
Jan 30, 2009 | OKI C3200n Led Printer
I have a OKI Microline 320 printer.
Your printer has a damaged mainboard. Very sorry, for yours is a very good unit. the replacement model is the Oki ML-420, which comes with a 3-year warranty.
Be blessed.
Oct 30, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
OKI C5250 Printer
My informed guess without seeing print sample is that your oki needs fuser unit replaced. Look at orange rollers should br smooth no wrinkles.
Dec 20, 2007 | OKI C5200n Laser Printer
Connection problems for oki C5100. Eek.
Your USB cable is either too long (more than 9 feet), or too thin. This makes the connection strong enough for status, but too weak for data transmission. Install a good quality cable and let me know.
Aug 14, 2007 | OKI C5100n Laser Printer
35 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
