Question about Ingersoll Rand Ingersoll - Rand IR125 Needle Scaler
How do i disassemble an ir model 125 scaler - Ingersoll Rand Ingersoll - Rand IR125 Needle Scaler
Starting problems
first: buy a brand new battery
- this might solve the problem with starting without disassembly of anything....
Feb 02, 2014 | 2009 Vespa LX 125
We have a IR model UP6-25-125 Constantly unloading like it has a stuck solenoid. Any suggestions?
Hi rejohnson964...
Repair or replace your unloader valve...it is causing your trouble.
Please take time to rate me
Sep 19, 2011 | Ingersoll Rand Air Tools & Compressors
Toshiba 50HP66 Plasma TV Problem - TV comes on but no picture. OSD shows up as vertical stripes on black background. picture sometimes black, sometimes multi-colored verticle stripes. Should I change the...
Generally this problem is in your signal board. You may also know it as the scaler board, as you mentioned. I have not repaired this particular model. But I would first suspect the the signal board (scaler). If you are not sure what this is, it is the board with all the RCA Jacks and RF connections. The problem in this area are bad or failing capacitors. Thanks for asking and show all hands of support!
May 02, 2011 | Toshiba 50HP66 50 in. Plasma Television
Can the psi be adjusted to lower than the preset 125 psi?
Not that I have read up on. But if I remember right you can go to IR home page and get a number to call a tech or even order a book on it.
Jan 30, 2010 | Ingersoll Rand UP6-25-125 120 Gallon...
IR 125 needle scaller not hammering or when it
put a couple drops of oil where the air line connects the tool......drain water from compressor
Nov 25, 2009 | Ingersoll Rand 125 Standard Duty Needle...
Hi there was petrol on top of one of the pistons of my 125 dragstar
it could be a jet has come loos in the carb or a plug is miss firing if the bike ir running ok whats the problem?
Nov 22, 2009 | 2001 Yamaha XVS 125 Dragster
Need to disassemble a Honda NXR Bros 125 clutch
you need to use a large air impact wrench
Sep 07, 2009 | 2004 Honda XR 125 L
Grundig LCD TV Picture Disappears
give me the model no of your monitor
Aug 01, 2008 | Televison & Video
Ingersoll Rand Ingersoll - Rand IR125 Needle Scaler Logo
50 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Eddie Tucker
Level 1 Expert
John Trevino
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
