Question about Dishwashers
Maidaid Error 02
Maidaid C1025WS What does error 02 mean on the digital display?
michiganfan9
  • 179 Answers
SOURCE: washer stops mid cycle and displays F 02 error code.
it means that your pump is clogged you need to take that bottom panel off the washer and twist the white cap slowly so it can drain put plenty of towels down once it is done draining pull the cap and clean the trap behind it
Posted on Dec 26, 2008
raklein62
  • 360 Answers
SOURCE: Sony UVW-1800 error message: 02-274 -- What does this mean?
I found a site where the error code are.
http://z.baidu.com/question/97641503.html
02-274 Failed to detect the T reel FG during threadingI hope this helps
Posted on Sep 26, 2009
  • 3 Answers
SOURCE: what does error code E1
This happens to my LG dishwasher every 6 months or so. It also makes a groaning sound as if the system is starved for water. I resolve the problem by removing the dishwasher and laying it over on it's right side. I then remove the two plastic assemblies (they are translucent enough that it is obvious that they have some gunk build up)supro7.jpg that are on the left side and I remove them from the dishwasher (you will need a vice grips to remove the hose clamps from behind them, you will also need to remove the round circular water intake plastic disk that is on the inside of your dishwasher on the left hand side right in the middle of the left wall) and clean them. Once the water can run freely through these plastic parts you will get a good water flow and you should be fine. Until you have time to do this I recommend putting a few quarts of hot water into your dishwasher once you start to hear the groaning problem. This solution should be very easy for anyone who is comfortable doing their own oil change. Oh, and turn off the power supply first. I think the origin of the problem might be too much food on the plates and too strong of a dishwasher gel detergent so the food is turned into gunk which coats the channels of the plastic assemblies. supro7_0.jpg
Posted on Nov 07, 2010
  • 6277 Answers
SOURCE: error displays "02...F". drum does not drain. what
Hi from retired Englishman in SW France @16:30 Mon afternoon.
Although I do not know your particular model I suspect that either-
1) the drain motor lint tray/filter is blocked (VERY common problem and worse in 'hard' water areas- lots of calcium) or
2) the drain motor is malfunctioning.
I would go for the filter. Your machine may be programmed to check for a blocked filter- not all are.
Take off the lower front cover, probably held in by some plastic screws which turn 90 degrees anticlockwise to remove or the panel simply pulls away.
NOW- REMOVE POWER FROM THE MACHINE AND HAVE A WATER RECEPTACLE (TO GO UNDERNEATH THE FILTER AREA) AND/OR LOADS OF RAGS TO SOAK UP THE (EXPECTED)WATER.
The filter should be removable by its round cover. If it will not come out easily you will need to spend some (patient) time maybe squirting anticalc fluid around it and gently working it out.
The drain motor should be visible and be able to be turned by hand/finger and not jammed by detritus. If it is -clean it! The same goes for the filter of course.
I hope this cures your problem- and that it is not the drain motor itself. Although relatively easy to change, a motor is another expense- and another delay!
Best of luck,
John C
Posted on Jan 31, 2011
  • 253 Answers
SOURCE: Maidaid dishwasher is in safe mode how do I change this
it may vary depending on the model number. if you google "maidaid dishwasher xxxx manual" where xxxx is your model number you can find the manual that should tell you how to fix that issue.
Posted on Apr 01, 2016
My sharp copier AR-5316, is showing error message E7. How do I clear it and solve the problem. Please I need urgent assistance.
For proper understanding of the error meainig it is necessary to obtain a Subcode of the error by pressing START at the moment of displaying error. E7-02 and E7-16 means Laser unit problems, E7-01 problem with memory, E7-10,11,12 Scanner problems Posted on Aug 16, 2016 -2017
Jul 29, 2016 | Sharp Ar 5316
Apr 01, 2016 | Computers & Internet
My washer is displaying an "F02" message. What does this mean?
If the drain time exceeds eight minutes, the water valves are turned off
and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the “Sud” error will be displayed, then four
minutes later the “F/02” error code will be displayedfc2323f.jpg3830f06.jpg 600f261.jpg
Your tech sheet? GHW9150PW0 Tech Sheet # 8182277 Rev #
Duet service manual and codes
Rate it or hate it:
Sep 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Getting a H then a F error when the washer is washing a load.... I ended up turning it off. I've also received a F 02 error and a SUD error.
Hello, the H and F error means no water is detected entering the machine or the pressure switch trip is not detected. If the control has turn the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valve will be turn off and the error code will be display.
So try the following steps
1. Check drain pump operation
2. Check the pressure switch hose to see if it's in good condition and properly connected to tub and pressure switch
3. Check is it is not a siphon problem
4. Check wire harness connections to: inlet valves, pressure switch, drain pump,flow meter, and central control unit(CCU)
5. Check all hoses for possible leaks
6. Check pressure switch operations
7. Check flow meter operation
8. Check CCU operation
F-02 ERROR: Means "Long Drain" that is if the drain time exceeds 8 minutes, the water valve are turn off and F-02 is flashed. Check the following
1. Check the drain hose and make sure it is not plugged kinked.
2. Check the drain pump filter for foreign objects
3. Check the electrical connections at the pump and make sure the pump is running.
And for the SUD error means after 4 minutes of the draining process the "sud"error will be display and 4 minutes later the F-02 will be displayed. So apply the solution for the F-02 to these.
Thanks
Jun 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Sep 26, 2009 | Fuji M321SP Betacam Tape
I receive an f 02 error on delicate cycel and it won't finish the load
Hi!
Error F 02 means the drain time is taking longer period then normal. If the drain time exceeds 8 minutes, the water valves are turned off and “F/02” is flashed. To resolve the issue you are facing with you need to follow these steps---
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the ‘sud’ error will be displayed, then 4 minutes later the F/02 error code will be displayed.
To clear this error code—
Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
If still the error code exists then you need to replace the pump.
Thanks for using FixYa and revert for further assistance.
Thanks
Rylee
Jul 19, 2009 | Whirlpool Duet 4.0 Cu. Ft. 14-Cycle Ultra...
Gestetner-2412Z copier-error code UF
UF is a panasonic code,the u means user fix.If you have an users guide it will tell u what to do.
Mar 03, 2008 | Gestetner DSm515pfd Digital Copier -...
Dishwashers Logo
100 people viewed this question
Top Dishwashers Experts
