Question about Canon imageRUNNER C3220 Color Copier
I have a canon 3220 N copy machine it copy in black an white very good but in color copying the colors and figures appears oblique! please what is the problem and how can we fix it?
  • andzulisv May 11, 2010
    how many copies on it ???
  • 149 Answers
Firstly, you will need to perform an auto gradation adjustment.although the chances of it curing this problem are slim. Enter the additional functions mode by pressing the head key, then select 'COMMON SETTINGS' then select 'ADJUSTMENTS/CLEANING' then select 'AUTO GRADATION CORRECTION' then select 'FULL ADJUST'. The machine will print out a chart and ask you to copy it from the glass, repeating this several times. Now, this is just a measure- your real problem is your ITB assembly (intermediate belt) - the belt can slip as the rollers are dirty when turning. Problem is, you can't do this yourself unless you really know what you're doing. This ITB assy may need servicing or replacing it entirely or in parts if it has done it's life.
Posted on Jul 07, 2009
How to change the power on default copy mode form color to black & white.
Hello Gary
On the main copy display your device is probably set to the factory defaults which means that when you press reset the device is in "AUTO COLOR". Touch the "AUTO COLOR" tab on the screen and a drop down menu will show. Select "BLACK AND WHITE". Now press the "ADDITIONAL FUNCTIONS"key. Select COPY SETTINGS located at the top right. Scroll down till you see STANDARD SETTINGS and select it. Press STORE. You are fixed!!! Please let FIXYA know I helped. :-) SPINAL
Jun 17, 2011 | Canon imageRUNNER C3380i Color Copier
How to set the default copy mode on a Canon irc3380 so that it starts up in black & white copy mode rather than color?
First adjust main screen as you want if to be (ie black and white mode). Once you have your default selected go to additional functions. Go to the copy selection and with in that list there is the section to save default settings. Now when you restart machine B/W and all other setting will be default. Good Luck
Jun 16, 2011 | Canon imageRUNNER C3380i Color Copier
My cannon mp258 cannot print, message show that ink to slow,and the ink indicator appear the Colored ink is almost empty .and also i try to photo copy black and white document but i cannot photo copy even...
Yes. You cannot use the printer even in black and white, until the color cartridge is replaced. They are designed to check the levels of the both black and color cartridges.
Oct 18, 2017 | Computers & Internet
How can i set black instead of full color to my canon 3220
Hello Laney,
Please go the operator control panel. Touch the icon that allows you to select full color, single color black and white. Select black then go to the :additional functions button located to the right of the screen. It is a "hard "buttin as opposed to the on screen "buttons". When u select additional functions you will get a menu of tabs . At the upper right top is copy settings. Select it. Scroll down to the "STANDARD SETTINGS " tab select it You now can store or initialize. Press store. You will see a confirmation of the settings you are about to store. Press ok. Baby you be fixed. Take care. Let "FIXYA " know I helped you please.
Mar 14, 2011 | Canon imageRUNNER C3220 Color Copier
We have Xerox Machine Canon IR C5800. the problem is while copying after more than 200 or 500 copies the machine copying is slow down i.e., may be 45 copies per minute. why? can u please sugest...
This model is 58 pages / minute in B&W mode, but If you print color prints it takes longer because the machine is built that way. Because the machine only have one drum unit instead of four, all four colors have to share the same drum unit, you can probably hear it when you take a color copy *chunk chunk chunk*. That is the sound of all the four developing assemblys spinning on a giant "revolver like" construction. And when taking color copies the machine have to calibrate it's colors now and then to ensure good color quality. So, once again, the machine is slower when taking color copies, nad faster with B&W.
Dec 18, 2010 | Canon imageRUNNER C5800 Copier
Copies made are totally black. what do i do? i changed cartridged, put in new paper then copied. it copied fine after 20pages, copy sounded like it was jamming up, paper came out with some parts black....
Hello limay_uera
Please check your Printer setup. or options ( I am not familiar with this printer. what terms they use- I'm not sure) Ther will be options for Print in Color or Black. Make sure the radio button for COLOR is checked. This way, black and color both will print in the correct color. So leave it on color even when you want to print in Black. The black radio button is there for a different reason.
Hope this will help you.
luciana44
Nov 19, 2009 | Canon FAX-L800 Plain Paper Laser
Need to set default for black/white copies not autocolor
set the machines control panel to the settings that you want and then press the PROGRAMS button and choose set as default and the screen will always be as you set it.., Good luck
Apr 30, 2009 | Canon imageRUNNER C3200 Copier
I have a xerox dc12 with error message please turn machine off and on again 9-363 have tried several times but no good! what else can I do?
That's a process problem with that machine.
May require a service call .ON and OFF is pretty much all a customer can do and wait for it to setup.
NOTE: The problem occurs because of the trickle development system in the machine, making extended lengths of black and white copies / prints does not allow the black developer housing to purge itself of excess waste Toner (Dry Ink) and Developer. There are two solutions for the problem:
  • Make 1,000 copies / prints of a black and white job, then make 150 copies / prints of full color. Continue making 1,000 copies / prints of the black and white job, then 150 full color, and so on, until the entire black and white job is complete.
  • Make extended jobs in groups of 100 by making 100 copies / prints of the black and white job, then allowing the machine to cycle down (return to 'Ready') and making the next 100 copies / prints. Continue in this pattern until the entire black and white job is complete.
Apr 28, 2008 | Xerox DocuColor 12 Printer
Canon Imageclass MF6530
the imageclass MF6530 cannot print in color it can only print in black and white. the only thing that this machine can do with color is to scan color documents to your computer otherwise it is a black and white copier and printer with color scan.
Jan 02, 2008 | Office Equipment & Supplies
or
  1. Power OFF the machine.
  2. Wait 30 seconds.
  3. Power ON the machine.
Dec 04, 2007 | Xerox DocuColor 12 Printer
Canon imageRUNNER C3220 Color Copier Logo
352 people viewed this question
old marine
old marine
