Question about Blaupunkt Louisiana DJ32 Cassette Player
Cd shuttle ejects when power to head unit is turned on
Blaupunkt Louisiana
Whenever I push the power on button to the head unit or by turning on the car ignition key which in turn, turns on the head unit the cd shuttle will eject. With the cd shuttle pushed back in and the car running it will regulrarly eject itself again after about 3 minutes.
With the car engine off, the head unit on and then pushing the cd shuttle back in it will play cd's fine.
With the head unit unplugged and the cd shuttle plugged in I can turn the cars engine on and off fine without the shuttle ejecting.
This is a recent problem and had all been going fine for anumber of years.
Though I'm not sure it could well of come about with the cd player on when the cars battery was disconnected.
Any help appreciated.
Adam.
  • adrowley Feb 04, 2009
    Hi Larry
    I have spent the last week trying different scenarios out on when I shuttle ejects. For the majority of the time it happens when the power to the head unit is turned on or the cars ignition key is turned. After pushing the CD shuttle back in it will play fine.
    It was suggested to me when the head unit turns on it goes over +12v reset threshold and that if the stereo is designed to treat a loaded CD on master reset as an error, it would likely eject.
    Since the problem occurred which was a good nine months ago I have had the alternator tested and have put in a new car battery.
    I think it is unlikely to be a fault with the way the unit is wired to the car. I have done it to the way the manual says to and the CD player had been working well for a number of years prior. I have checked for loose wires.
    I hope this helps more for a solution.
    Adam.
  • Larry Tezekjian
    Larry Tezekjian May 11, 2010
    In my 29 years in the industry I can honestly say I have NEVER seen that!! Can yu tell me how it's wired? I know how it SHOUD e wired. Hit me bac.
    Larry T
    Winona Lake, IN
    http://www.cybersoundsaudio.com/cybersou...
    Scholar:
  • 116 Answers
Hi Adam,
Since you've been trying things for so long, you may not mind another, unless you've tried it already.You'll need someone to help you.
Try using a volt meter on the main power to the changer. (If the changer is din mowered only, this can't be done) and when toy power up the head unit by ignition or other method, read the voltage on the main power wire (yellow?). Tell me what it shows. Also, the "turn on" wire for the unit is usully in with the data cable to the unit, and won't be able to check that.
Also try to read BOTH the acc AND the power wire on the head unit while turning on.
When you read the voltges, make sure that you use the ground ON THE CHASSIS of the componant that you are checking. "Maybe" you have a voltage variance like you said d to a weak ground at one of the units? I'm just troubleshooting as I would if you had brought it to me. Let me know again. Thanks.
** Note- Have you actually reset bothe the head unit and changer?
Larry T
Winona Lak, IN
Posted on Feb 04, 2009
Blaupunkt cd5 changer does not have an eject button how do i retrieve my cd's?
If it has a magazine, you'll have to remove it. Some magazines push in to latch and you can push to unlatch and pop out
Sep 18, 2012 | Blaupunkt IDC-A09 5-Disc CD Changer
JVC won't eject my CD!
Turn radio off Push and hold the eject button Turn radio on while holding the eject button.
This is the force eject sequence
Apr 05, 2010 | JVC AM FM CD DET FACE CAR STEREO
Blaupunkt CD Changer CDC-A08 - Cartridge eject problem
I am waiting for a reply from the Authorised Blaupunkt Service Agent for a solution to this problem &
shall let you know when it is solved. As per my telcon with him it is an alignment problem of the
Cartridge carrier, but he will have to look at the Unit later, when he is free.
Mar 22, 2009 | Blaupunkt CDC-A08 10-Disc CD Changer
Pioneer DEH-2150 : CD Ejection switches off the Stereo
hi rolls
when there is no CD in unit hold the source button to turn unit to actual on position (when you insert a CD is it self guided once you push it to a certain point or does it just self guide instantly) if you sort of push it in a bit and unit turns on its because the pioneer function says to itself i need to be on so it will play for you but once you eject the CD the unit says time to turn off the solution i recommended should solve this if not let me know and ill figure out another step
hope i was able to help
Feb 14, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Peugeot 307 04 plate
just disconect leads on cd changer should reset
Dec 06, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Blaupunkt IDC A09
Hi, do you have the IDC A09 PSA or just the IDC A09?
Nov 23, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Blaupunkt IDC-A09 5-Disc CD... Problem:
Ok guys thius it how it works.
Blaupunkt supply a repair kit for this unit, this basically is a fix. but only works for 8 out of 10units.
its a pain to fit too.
you have to replace the 3 spindle guides and arms. the part number is : 8619001490 there a reall complicated thing to fit.
i am looking to get a install guide sorted. and will soon be selling the kits on my website
www.carradiospares.co.uk
Regards
Mark
Blue ICE
Jan 18, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Unable to eject cd magizine. Error 2
power off. open the cd changer unit. look for the motor that, when turning, performs the eject mechanism. now turn this motor by hand in the proper direction until cassette is fully ejected.
Jul 22, 2007 | Clarion DC625 6-Disc CD Changer
Cd-changer Blaupunkt IDC-A09
The solution is to disconnect the head unit and the cd changer from each other and from the car itself, leave it for ten minutes. reconnect and turn the ignition on but not the car itself, enter radio code if has one and all should work.
Sep 24, 2006 | Blaupunkt IDC-A09 5-Disc CD Changer
Blaupunkt Louisiana DJ32 Cassette Player Logo
159 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
