Windows defender not updating
Windows defender says: the program can't check for definition updates error found : code 0x80004002 my kaspersky is also not updating but i can access the netĀ  Is it a problem with the network connection?? but if it is then how can i access this webpage?? PLEASE HELP!! im confused over here!! :(
    Problem Solver:
  • 11 Answers
Reinstall defender
Posted on Feb 14, 2009
How do i fix error ox800106ba
Hi Anon,
The 0x800106ba error may occur after Windows Defender is updated due to the computer's inability to update the Windows Defender firewall. It may not have applicable permissions needed for the update, or it may not have the files necessary for updating itself.
The Fix
Set Windows Defender to Automatic - You can set the Windows Defender service to Automatic, Disabled or Manual. Setting it to automatic might solve the problem. Follow these steps:
  1. Click Start > type services in the Search box > click Services in the Programs list.
  2. If you are asked for a Password before you continue, then enter the password > click Continue.
  3. Double-click Windows Defender, and click Automatic in the start-up box > click OK.
Uninstall and reinstall Windows Defender - If the first procedure did not help resolve the problem, try un-installing and then reinstalling Windows Defender. Due to the fact that Windows Defender is a Windows component, we will use AppWiz to un-install it from the computer. Follow these steps:
  1. Press Windows Key + R > type appwiz.cpl > Press Enter
  2. Click Windows Defender > click Remove
  3. Follow the prompts to uninstall Windows Defender
Let me know how you go!
Feb 12, 2015 | Microsoft Windows Defender
Tip
Windows Defender 0x800106ba Service Error on Automatic Startup
Some times even when the Windows Defender service is set to automatic you still might see the Error below and even when you have tried this site http://support.microsoft.com/kb/931849 which tells you to remove the program and then use the windows installer cleanup utility form HERE and start again you still get the same error
This is a method is bit drastic I suggest that first you update manually the definitions from HERE then download my Windows Defender FIX from my Public SKYDRIVE then restart you PC it should now fix the above error it will re-register all the DLLs that are needed to allow the error to go
on May 01, 2010 | Microsoft Windows XP Professional
I using a kaspersky 2011 antivirus and its showing yellow exclamation mark on kaspersky icon. please help me how to solve this problem
Usually the yellow exclamation mark means you need to update the program's AV definitions.
Just run the update tool within the program, this should get rid of the symbol.
Mar 18, 2011 | Kaspersky Labs Kaspersky Anti-Hacker...
Unable to download vista service pack 2 from website. As soon as i click enter system shutdowns What should i do? As i using Genuine Vista premium edition
The first thing you might try is if you have auto-updates on for Windows, turn it off. Start>control panel> and either security center (WinXP) or Windows Updates, if you're running Vista. In the windows update window, in the left menu is a selection called 'Change Settings'. Click on this to turn updates off and on and to control how updates are handled.
Is your system shutting down only then? You may have a virus or other nasty. If you have an antivirus program installed please update the definitions and run a virus scan. If you don't have a current antivirus program installed download Antivir here . After you download it drop the download window into your task bar by select the _ in the upper right corner of the window. If you have another antivirus installed but the subscription has run out and you can no longer update it, remove it by going to start>control panel>add/remove programs (XP) or Programs and Features in Vista. Allow the list to populate and then uninstall the antivirus program. Also, in Vista you must disable 'Windows Defender' before installing Antivir. Start>control panel>Windows Defender> and scroll down to where it says, "use Windows Defender". Deselect that setting and that should turn it off. At any rate Antivir will alert you that's Defender is on and will give you instructions as to how to disable it. Upon successful install of Antivir it will automatically update the virus definitions and then initiate a virus scan.
You can also download and install Malwarebytes and run a quick scan. Malwarbytes can be found here: http://filehippo.com/download_malwarebytes_anti_malware/
Once you've installed the program it should automatically launch and then do a database update. If it doesn't update on the tabs the third tab is 'update'. You can manually update the database from there. This program is pretty intuitive and easy to use. Just do a quick scan which is selected by default. You will probably have to let the program reboot to clean anything it's found at load up of the system.
Please let me know if this helps. If not we can try to find another solution.
Feb 16, 2011 | Dell Inspiron 1525 Notebook
Black.lst is missing or corrupted
Hii
this is most common error u get wid Kaspersky, all u have to do is, re-install Kaspersky and run an update, the new updates have fixed this error, u will not get this once u have re-installed and updated it with latest updates.
Hope it helps u
Good Day
Sep 11, 2009 | Kaspersky Labs Internet Security Version...
Connection problem for some programs
it's possible that windows defender is interfering with the functions of you software.
turn windows defender off and see if you still have the problem.
go to control panel and open windows defender and turn off real-time protection
if this helps please leave a vote in fixya..thanks
May 18, 2009 | Microsoft Computers & Internet
Unable to check for updates with Windows Vista Home Premiun, SP1, 32 bits, error code 80244019 for Windiws Update and 0x80244019 for Windows Defender, last update instaled Jan/01/09
I've been having the same error when I try to run Windows update on a Vista Ultimate machine setup for use with our SBS 2003 server running ISA 2004.
The Solution that I found is this.
When you setup Vista for use with a domain it creates the following regkey with a subkey etc ( policy ) that sets Vista to look for a WSUS server.
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate]
"WUServer"="http://serversbs"
"WUStatusServer"="http://serversbs"
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU]
"NoAutoUpdate"=dword:00000000
"AUOptions"=dword:00000004
"ScheduledInstallDay"=dword:00000000
"ScheduledInstallTime"=dword:00000003
"NoAutoRebootWithLoggedOnUsers"=dword:00000001
"RescheduleWaitTime"=dword:00000001
"UseWUServer"=dword:00000001
When I deleted this key and rebooted my PC windows update was working.
Hope this was somehow usefull
source: http://www.vistax64.com/vista-general/3421-windows-update-error-code-80244019-a.html
Good luck
Feb 23, 2009 | Microsoft Windows Vista Home Premium with...
Message: "File black.lst is missing or corrupted"
Your problem is likely related to a bad update from Kaspersky - it happens once in a while and will likely be fixed on their next update.
Jan 07, 2009 | Kaspersky Labs Internet Security Version...
Problem Installing Printer Driver for Canon MP460
1) relax
2) prove to install nod32 from this site www.nod32.com is a powerful antivirus work very well.
after you have make, please reinstall the driver from this site.
3) http://software.canon-europe.com/products/0010394.asp
Thanks
Sergio
Mar 01, 2008 | Computers & Internet
Computers & Internet Logo
263 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
