Question about Motorola Mobility RAZR V3
Phone rings but can't answer
Hi, I had my Razr for about a year and half and suddenly, it will ring but I can't answer the call. Neither opening the phone nor pressing the green button works. (I can make calls, however.) Does anyone have an idea of what could be wrong? Thanks.
  • 147 Answers
Your Buttons are Corrupt,Your phone is Locked up.Get a clean toothbrush and some Denatured alcahol and make sure to pull the Battery before starting and clean all the creases and let Dry for 30 min,PS it drys quicker on a Fan,Put the battery Back in and Try it Let me Know ttech
Posted on Jul 20, 2007
SOURCE:
Local calls not going to answering machine. Long distance OK, showing name and ph#s. Local calls do not give name, phone #, and I get an open line after one ring. I cannot monitor my phone calls. I have...
Sometimes telemarketing robocallers will be programmed for "one ring" response. If no answer, they move on to the next one. Your answering machine probably can be programmed to respond after a number of rings. The one ring programming relieves the telemarketing robocallers from talking to a machine.
Mar 05, 2018 | Panasonic KX-TG1034PK Quad Cordless Phone
Dropped it - put battery back in. Works for outgoing calls but only vibrates, does NOT RING for incoming calls. Checked Settings--> Ring Styles and changed to Loud (still doesn't ring) and back to Vibe...
You dont hear tones after you dropped it.
This is because the speaker connection may be disconnected due to sudden ****.
You need to contact your authorized motorola service centre to fix this problem.this is a very small problem so no need to worry.
Thank you
Aug 08, 2010 | Motorola Mobility RAZR V3
Rings twice then goes straight to missed call had this phone for a couple of years no problems until lately i have not altered anything but last few days it only rings twice before going to missed call i...
Try removing the battery from the phone for 10 seconds and after that restart the phone. If the problem persists then ask an expert to help restore
Jun 05, 2010 | Motorola Mobility RAZR V3
My phone rings a half a ring then stops. The
you more than likely have "short rings" turned on, in the options of that phone. you'll have to go into the options menu, and look for setting that pertain to ringing and / or rings or ring length.....DON'T change DTMF tones though, that'll get annoying, as thats what you hear when you are calling someone else. hope this helps.
Sep 21, 2009 | Panasonic KX-T7633 Corded Phone
I am able to call but can't hear the other persons phone ringing, busy, voicemail or if anyone answers, there is no sound. The same if someone calls me, it rings, I try to answer & nothing. I can send...
well the ringing is from another speaker that works as a loudspeaker/ handsfree on your phone
as a preliminary check try connecting a headset and answer the phone if you can hear the other party then the problem is with the earpeice, you might want to get it repaired
Jul 22, 2009 | Motorola Mobility RAZR V3
Razr phone backlight stays on while charging
hi,
  dis is common in razr and samsung higher models...d backilight ll glow when u put d mobile on charge...i have a samsung d840 metallic series phone, d backlight glows througout d charging period..my friend has a razr and in tat also it glows when it is charged...so its common in razr and samsung..nothin harm to d mobile because of this....
good luck
Jul 04, 2008 | Motorola Mobility RAZR V3
Razr v3 will not ring
Me too. No sounds when ringing, just vibe.
May 18, 2008 | Motorola Mobility RAZR V3
Razr troubleshooting
none of the keys work and key pad is not locked. Recieved phone last night worked fine. Today I can only answer calls and only by flipping phone open.
Nov 22, 2007 | Motorola Mobility RAZR V3
In vibrate mode, phone continues to vibrate after being answered
The phone is in "vibe then ring" mode.
Go to tools then ring styles using the "-" at the top center of the keypad. It will be set to vibe then ring, press "change" alter the style to vibe, vibe then ring, silent, loud or whatever you like. That is also where you find what ringtone is used for the ring.
Oct 30, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
