Question about HP Compaq Presario V2000 Notebook
DVD drive keeps on opening when starting
I have a Blue Laptop, when i start it the DVD drive will open then when i try to insert a disk to it the led will blink but it will only eject...
    President:
  • 2,692 Answers
If the boot priority in the BIOS setup screen is set to thr CD it  will open the cd door every time you boot looking for the BOOT cd.    It will not accept anything else, at that point except a boot cd since it hasn't found the operating system (windows) yet.    By "blue laptop" you mean "blue screen" DO a "Windows restore" or reinstall windows from the reinstall cd or Harddrive partision containing the restore files.
Posted on Jan 28, 2009
How do i open a disk drive to a acer aspire e touch
well it sounds to me like you are just trying to open the drive to insert a disk ? go to "computer" or "my computer" on the desktop, double click to open. you should see your hard drive "c" and cd/dvd drive "d" listed. right click the "d" drive, left click eject, voila. if you have more than one hard drive or a partitioned drive there might well be more drive letters but your cd/dvd drive will be marked as such. alternatively click "start", bottom left of desktop, click "computer" and once again you should see your drives listed. physically there should be , on the cd/dvd drive drawer itself a small button, push it once to open. failing all else, there should be a very small hole in the drive drawer, using say a paper clip or similar, insert into the small hole and push reasonably firmly, this should release the drawer manually and the drive will open. hope that helps. good luck.
May 11, 2014 | Acer Aspire 5315 Notebook
My DVD/CD-RW drive isn't recognized/ doesn't play disks.
It may be bad. Has the laptop been damaged? Dropped? Open Device Manager, DVD/CD Rom drives, is it listed? In Start Menu, Computer, Is it listed? Try re installing the DVD rom driver, the MS Vista 32bit drivers can be found here: http://www.dell.com/support/drivers/us/en/04/Product/vostro-a860
Feb 02, 2013 | Dell Vostro A860 Notebook
Create boot disk
Insert a blank diskette into the floppy drive. Click start click on computer you should see all of you drives.
Right-click on Drive A. You will see the option to format the drive.
Click on Format. Depending on your operating system, you will see an option that reads either "Create a system disk" or "Create a MS Dos system disk." Click the box next to this option.
Click the "Start" button to begin formatting the disk.
When completed, you will have a bootable floppy disk.
For CD Rom or DVD disks
Open the software that you use to burn or write files to the CD-rom or DVD drive.
Click on "Make a Data CD or DVD." Insert a blank CD-R or DVD-R disk into the drive.
Look for the option to "Make this disk bootable." You may have to scroll over the various icons displayed to find this option. Click on the option.
Burn the CD or DVD as usual. Once completed, this disk can be used to boot your computer.
hope this helps
Aug 22, 2012 | Seagate Computers & Internet
Hi My Acer 5542G laptop drive is not reading. Its making all the right noises but simply asks for a disk to be inserted even though there is a disk in the drive. The disks work on other computers.
Hi duane63,
Here are some things that you can try to get this problem resolved once and for all :
  1. Close all open applications on your computer and start a browser
  2. Click on the link (below) and hit "Run Now" to download the repair kit from Microsoft :
  3. After downloading, start the repair application.
  4. Restart your computer
Here's the link mentioned in step #2 :
MS Repair Kit
If the issue would continue after doing these steps, then it is clear that the drive needs to replaced.
I hope this helps, Thank for using FixYa.
Feb 16, 2011 | Acer (KV.16X04.007) DVD Drive
Sony DVD ROM will not open, light comes on and tries to open but will not. Other DVD works fine. What with the Sony DVD?
try to find a tiny hole on the drive( near LED or eject button) and insert a niddle or some kind of hard pin which can go inside of it push little bit hard (drive will open) , dont keep your drive empty if not in use put any useless DVD ROM in it so that it will get open when you want to use
Apr 24, 2010 | Sony CRX320EE-88B CD-RW/DVD-ROM Combo...
My DVD drive won't open - seems stuck
on the front of the dvd drive, there is a small pinhole that you will need to insert something the size of a safety pin and push inside and that should pop it open and you can pull it open the rest of the way. or you can also try "start/my computer/dvd drive/then rightclick on the dvd drive icon and click "eject". if its not reading disks as well, you can purchace a cleaning disk. the drive may be about ready to quit working so plan on a new one in the near future if possible. hope this helps!!
Jan 15, 2010 | Computers & Internet
Dvd won't open program
Does your dvd drive opens other dvd's if it does, that means your dvd has gone bad but if your dvd drive fails to play any dvd's than it's a problem with your dvd drive.
Best way to test it would be to insert a new empty dvd and see if your dvd drive opens it.
Jul 26, 2009 | Dell Computers & Internet
My DVD drive D works fine. Problem is with one particular CD.
this is a very common problem for all CD/DVD drives... sometimes.. there are CD-R DvD-R brands that will not work with your CD/DVD drive... its compatibility issues... another possibility is that the CD burning was bad.
Jul 03, 2009 | Memorex (32025638) (25 Pack) 16x DVD-R...
CD not being read from CD/DVD ROM Drive on Laptop
try to clean the cd drive lens with a lens cleaner...
Jan 30, 2009 | Dell Inspiron 6400 Notebook
PS2 disk tray keeps opening
try holding the disk drive after it closes for a few seconds and see if it stays closed or one of the drives gears could be stuck,loose,or broken.you might need to open it up.
Jul 05, 2007 | Sony Playstation 3 (PS3) Console
HP Compaq Presario V2000 Notebook Logo
106 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
