Question about Xerox 8825 Copier
Low fuser oil - Xerox 8825 Copier
DSC224 printer displays low on fuser oil
There is a sensor that need to be cleaned if the code will not clear. I believe there is a black float that is part of the fuser bottle. If you swing out the oil bottle and look where the float would be... There is a sensor, clean the sensor and make sure it is plugged in correctly... Good Luck
May 22, 2012 | Gestetner DSc224 Copier
920 service error fuser
This problem (920 Fuser Error) occurs when the Fuser is below temperature while printing. The 920 error caused by low line voltage can sometimes be cleared by turning the machine off and on. You should replace the fusser and reassemble it.
You can also follow these steps:
Note that you do this on your own responsability.
Remove the fuser heater cable from the power supply (CN602). If there is no continuity in the heater wire, replace the fuser heater and thefuser oil coating roller. If there is no continuity in the thermostat, or it does not equal 240K Ohms at25 degrees C (room temperature), replace the fuser thermostat and the fuser oil coating roller. If the thermal fuse is open, just replace it.
If there is continuity, and the thermostat is good, only replace the power supply. If this doesn't fix the problem, replace the printer controller board.
May 17, 2011 | Lexmark E342n Laser Printer
How do I clear Fuser oil low message on Ricoh Aficio 1232C after refilling fuser oil bottle
At the machine. Press in this order. Clear all ( yellow button) then 107, then press and hold the pink stop button until the screen changes. You will see some icons that say Copy SP, Sytem SP.
Select Copy SP, if thats not available select System SP.
You will see several buttons. Select sp 7 Data Log, Then scroll to page 804 and select that. Then scroll to item 11. That is where you will select to clear the fuser oil count and reset it.
Jan 28, 2011 | Ricoh Aficio 1232C Color Copier
I installed a new fuser oil cartridge in my Docucolor 12. After about a week I found the oil was low again and we had only made a few hundred copies. When we pulled the unit away from the wall I found...
u need a new oil tank. this is the yellowy/brown plastic bit where the oil sits in. if not you might have a blockage in your oil system in the fuser itself causing it to spill out. if the oil is on the trays its more than likely the oil tank
Jun 18, 2009 | Xerox DocuColor 12 Printer
Error Code SC570 for copier Aficio 1224C
It could be covering the sensor. Clean the fuser oil sensor off and see if it goes away.
Dec 17, 2008 | Office Equipment & Supplies
Error 10186 docucolor 12
10-186 is a fuser problem.Check for jammed paper in fuser or low fuser oil.Might have bad fuser lamp or fuser thermal fuse.
Apr 23, 2008 | Xerox DocuColor 12 Color Copier
Changing Fuser Oil
I am glad that drichards gave me am an "atta boy" considering the fact that I could not have given a more thorough explanation.
Mar 19, 2008 | Office Equipment & Supplies
Resetting the fuser oil message
Well, all you need to do is fill the tank on the back right of the machine. The oil pump has to pump it up to the sensor in the fuser. It will eventually go out, or you will get an SC570 code.
Mar 04, 2008 | Office Equipment & Supplies
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
