Question about Sony KP-51WS500 51" Rear Projection Television
Sony KP-51WS500 Blinks/Flashes 6 Times
I have a Sony rear projection TV and the power light blinks 6 times. I read the repair/schematic manual and it says that it is a Low B OCP/OVP problem and the cause is ? +5 line is overloaded. (A, B Boards) ? +5 line is shorted. (A, B Boards) Well now that i know that is the problem how do i fix it!!! Do the A/B boards need to be replaced or should i try lower the color voltage settings on the TV?? I am totally clueless as to what to do and I cannot afford $600 to fix this tv! Someone please help!!!
  • Robert Tinner Jul 25, 2007
    I replaced the A board and still no go.. The 'B' board looks like its brand new, no scorch marks, broken solder, popped caps nothing. If anyone has any clue what it would be please let me know, this is getting really expensive.
  • 41 Answers
Nspect the bottom of these boards for cold solder joints with a magnifier & resolder suspect pins, also check the capacitors on the board, if they are little silver smd type look for yellowish liquid to be present around one or several of them, you need to replace, either of the above could be your solution.
Posted on Jul 22, 2007
51ws500 sony shuts down and standby light flashes 8 times
Eight blinks points to an audio output problem. The unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Hope that helps.
Feb 20, 2011 | Sony KP-51WS500 51" Rear Projection...
I have a sony 50". in the power button, a red
i have a sony 57". in the power button, a red blinking light blinks 11 times.
KDP57W5655
Nov 28, 2010 | Sony KP-51WS500 51" Rear Projection...
TV will not come on. TV standby light blinks nine times continuously. TV is Sony KP-51WS520
Nine Blinks- Replace D6116 and D6301 on the "G" board, do not solder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative).
Mike
Apr 16, 2009 | Sony KP-51WS500 51" Rear Projection...
You need to call a Sony service center for this problem. It will cost you less in the long run.
KP-51WS500 Flashing 6 Times
Well, it's DEFINITELY the High Voltage power supply is DEAD! Won't start up...or goes into OVERVOLTAGE SHUTDOWN....
Most of the time it's overvoltage problems...
The KEY to knowing which one is actually occurring is the amount of time it takes before the 6 blinks occur...
A DEAD HV circuit takes a lot of time, while the OVERVOLTAGE will take less than 40 seconds for it to register the 6 blink code....
In this case (overvoltage) replacing the HV oscillator/regulator IC is mandatory...
A dead HV circuit could be anything in the HV circuit, from the Regulator IC to the HV splitter...
It's really wiser to consult a TV technician on this....
Mar 25, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony Wega stanby light blinks 5 or 6 times
When a Sony TV flashes five times, that means that there is an AKB circuit fault.
Six blinks is also a fault related to video problems, and regards a fault concerning the digital board and the Jungle IC (the main CPU).
This means that there is something wrong with the video.
Try first unplugging power for few hours, if that does not work, call a technician, as several IC and components must be tested and eventually replaced.
Nov 22, 2008 | Sony KP-51WS520 51" Rear Projection...
Sony KP-51WS500 will not turn on
I believe the problem is either in the G board ( power supply) or the D Board ( high voltage) as the 3 blinks indicate the G board, and 7 indicates the D board and 6 indicates the +5 line a and b boards. So with that many codes its most likely the G board (power supply) You can get a new replacement G board at the following link which comes with free tech support to help you plug the baord in which is very easy. Its listed under the Sony parts category and its the A-1316-566-A sony G board, Here is the link.
http://servicemanuals.vstore.ca/
Aug 12, 2008 | Sony KP-51WS500 51" Rear Projection...
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Powers on then right back of light flashes 8 times
i have a sony wide screen projection tv KP-51WS500 Red stand by light on flashs no picture
Mar 10, 2008 | Sony KP-51WS500 51" Rear Projection...
2002 sony projection screen tv kp-51ws500
the set has a bad tube Don't spend any more money on it
Mar 03, 2007 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
440 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
