Question about Hunter Dryers
1995 Hunter Fan/Light Remote control FCC IN2TX01, Model UC 7848, Freq 302.5 - red light does not appear when we try to turn on light and fails to turn on light, does work on fan? what do you recom
Red light does not appear when we try to turn on light and fails to turn on light, does work on fan. What do you recommend. Thank you Home depot does not carry this "old" remote control.
4 Suggested Answers
ynogami21
  • 670 Answers
SOURCE: My Hunter Remote FCC IN2TX01
hi there,
Maybe you can try doing these steps:
1. Adjusting the dip switches:
Each fan/remote combination is set to work on a specific frequency, much like tuning in a specifc radio station. Some fans allow you to set this frequency by means of a set of small switches called "dip switches". There is one set located inside the remote, and the other set would be position on the fan, with the remote receiver electronics. This would be either on top of the motor, or inside the switch housing or ceiling canopy. These switches "tune" the remote and fan (received) to the same "station" and therefore must be set to the same setting. If a fan is not responding to the remote you can check to make sure that the switches are set to the same setting in both locations, and/or try a different setting. They are also useful if you have two remote fans, you will want to be sure each fan is set different so the remotes do not interfere. Lastly, if some other wireless device is interfering with the fan (causing it to turn on and off seemingly at random) such as a garage door opener or cordless phone, you can try a different setting on the dip switches.
2. Universal remotes:
If your fan remote is lost or broken, many suppliers, offer a universal remote designed to work with the majority of different remote operated ceiling fans. Many are also universal for operating televions etc so you can control all your leisure and comfort devices from one unit.
3. Replacement parts:
Unfortunately, outside of Universal remotes, general replacement parts are not available for remote control systems. Your best bet is to contact the manufacturer.
3a. Repair:
Also unforunately, most problems with remote controls cannot be repaired outside of what is suggested above. If you have problems, contact the manufacturer, perhaps the fan is under warranty, or parts are available. Otherwise chances are the fan will stay broken.
4. Add-on remote kits
Some fan remote systems are not built into the fan, they were an option added by the installer at an additional cost. Usually they consist of a remote receiver wired to the fan inside the ceiling canopy, and the fan will still have a pullchain that is not used. If this is the case then the receiver can be removed and replaced with another remote/receiver kit, or the fan can be operated as standard with the 3 speed pullchain.
If all else fails:
contact hunter and see if a replacement remote is available:
here's the website:
http://www.huntershoponline.com/cc_contactus.asp
here's the phone number and office hours:
1-800-893-9330 Monday - Friday
8am - 8pm ES
Posted on Jun 12, 2011
  • 198 Answers
SOURCE: I have a 3 terminal electrical connector dryer and
Most dryers are set up for 3 terminals, white is always common, green is ground. You can change the recepticle to a 3 wire or just connect the green wire to cabinet ground on the dryer
Posted on Jan 02, 2010
heatman101
  • 43501 Answers
SOURCE: Having problems with a 4 year old DPGT750EC2ww
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
Posted on Jun 25, 2010
How do I repair a Hunter Ceiling Fan thats blades won't spin?
The remote receiver could have failed partially so only light control works.
May 26, 2015 | Hunter Dryers
Remote will not turn on fan. A ll I get is a click.Light works fine
How i fixed my Hunter #28096 remote controlled ceiling fan, started not controlling the light, then later the fan quit also. Start by testing the remote buttons, see this post... http://www.fixya.com/support/t11813083-cp9430r Cp9430r Fixya
May 30, 2014 | Hunter Ceiling Fan Light Remote Control
Hunter ceiling fan model 23285-420 w/remote control...worked fine for about a year then lights would start flashing when turned on. Changed remote control and receiver with no change. Eliminated the...
The problem is not your remote on the fan. It is the light kit. We have the same problem and our electrician diagnosed it as the light kit. This problem started just out of warranty, of course, and we are now purchasing a new light kit to fix the problem.
Jan 28, 2012 | Hunter Ceiling Fans Individual...
We got 4 HUNTER ceilin fans in one room. Model 27185-060 with remote FCC ID:IN2TX11 Two of them are runing clocwise another two in opsite side Wat can we do to run all in one direction?
Your Hunter ceiling fan is equipped with a small switch that changes the spin of the blades from clockwise to counter-clockwise. Regardless of the make or model of your ceiling fan, this switch is typically located on the center motor housing where the fan blades are attached. good-day!
Aug 19, 2011 | Hunter 52" Ceiling Fan With Light And...
I installed a Hunter On"Off fan and light control model 27157 on a Hunter Augusta fan model 21338. I tested the remote control and the fan and light on, however, after a period of time, the fan turns on...
Most likely this is caused by radio interference from some other device nearby. Try changing the "channel" by changing the dip switches on both devices and make sure they match. :)
Mar 27, 2010 | Hunter 27185 Remote Control
Fan with remote won't work with wall switch. I
I just recently purchased a hunter ceiling fan w/light and remote. Had it installed and wall switch would not work, only remote. I contacted Hunter company directly about this problem and I was told that they redesigned their fans with remotes so that only the remote works for turning off power to fan. The person who made that made that BRILLIANT change should be fired. So to those of you who own a newer hunter an product with a remote ne your wall switch will not work tat s te reason why.
Jul 14, 2009 | Hunter Ceiling Fan Light Remote Control
Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Jun 16, 2007 | Hunter Ceiling Fan Control Switch
Dryers Logo
134 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
