Question about Onkyo DV-CP702 DVD Player
Onkyo DV-CP702 will not load dvd's
It will load a cd but will not load a dvd
  • billferry196
    billferry196 Jan 22, 2013
    I read page 46 of the manual about reseting the player pressed and held stop 10 seconds, reset came up on screen and nothing changed, then I held stop and pressed stand-by and reset the player and it's playing dvd's again. Ran my lens cleaner to top it off and the player is working perfectly again. I'm one happy dude!
ChadL777
  • 69 Answers
SOURCE: Shuts off after a loud sound
Hmmm...not sure but sounds like the vibration from the loud sound is causing the disk to jump. Not sure why that would power it off, but I think your thought to junk it sounds reasonable.
Posted on Dec 24, 2007
  • 4234 Answers
SOURCE: I have an Onkyo DV-CP702
The loading mechanism is out of timing and needs to be rebuilt. This is a fairly strightforward procedure if you have the manual as there is a sequence and alignment procedure for this. No parts are required in most cases. This unit should go to a service station. If you attempt this and are not aligned correctly, it is possible to damage the optics assembly.
Dan
Posted on Jul 02, 2008
SOURCE: Disk Error, CD only
It may not recognize the CD if it is a copy. try an original CD and see if it works.
Posted on Dec 01, 2008
rulds2008
  • 3866 Answers
SOURCE: Onkyo DV-SP405 DVD player says no disc
This woud be due to two things
1. laser
2. servo motor not spinning to the correct speeds i,e Bad motor
Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jun 11, 2009
  • 603 Answers
SOURCE: What should I do with my Onkyo DV-CP702 dvd player
Replace - you can't fix for less than $100.
New are under $50
Posted on Jan 05, 2010
Have lost the remote control to onkyo dv cp702. Would like to access the random option.
You can get a substitute remote (the original remote is no longer available) at
http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13118717212490&smodel=DVCP702&brand_pn=ONKYO_DVCP702
Let me know if you have any other problems or questions.Please rate this solution. Thanks.
Jul 28, 2011 | Onkyo DV-CP702 DVD Player
Displaying an error message "mecha
http://www.fixya.com/support/t4093524-onkyo_dvd_changer_display_reads_mecha
http://www.fixya.com/support/t1119443-onkyo_dv0_cp702_error_mecha_err
These may help you.
May 07, 2011 | Onkyo DV-CP702 DVD Player
My onkyo dvd player is reading mechna err
This is usually caused by a broken tooth on one of the cam gears. While relatively inexpensive for the parts, the unit must be rebuilt in the correct order and alignment. This is not a DIY repair. It is possible that the unit is just confused and out of timing. Try unplugging it for 5-10 minutes. Plug it back in and see if it resets. While I doubt it will, it is worth a try. If not, then the unit should be serviced. Figure on $60-$75 for the repair.
Dan
Apr 16, 2010 | Onkyo DV-CP702 DVD Player
We cannot get a disc out of a DVD player Onkyo CP702?
What is the model number of your DVD player?
Nov 30, 2008 | Onkyo TX-SR605 Receiver
I have an Onkyo DV-CP702 and it keeps saying I have a mechanical error. I thought a disc was stuck, so I followed your tips and took off the top and indeed, there were 2 discs stuck. I took them out, but...
Dan
Jul 02, 2008 | Onkyo Televison & Video
DVDs presumed stuck and the player won't eject
Hi, If you feel comfortable opening the unit, then you may remove the top cover normally held by 2 - 4 screws. The tray should be visible and most units have a locking bar right at the center to hold the discs down. Removing this (2 screws normally, 1 at each end of the bar) would expose fully the tray with the 2 discs on top. Remove the discs and put the locking bar back with the screws. You can test the unit without the top cover. Please be reminded about safety precaution when working with active/live units and laser equipment. Power it up and check if the "mech err" still shows. If not you're set to cover it up, otherwise, your probably better off seeking the services of a qualified technician. This is a generic method which normally should apply to most CD/DVD units. Good luck and kind regards.
Aug 19, 2007 | Onkyo DV-CP702 DVD Player
DVD/TV Problem with TX-LR552
Did you change your TV input to DVD as well?
Jul 26, 2017 | Onkyo TX-LR552 6.1 Channels Receiver
Onkyo DV-CP702 will not load any disks!
Look at page 46 of the manual for reset or initialzation.
Nov 17, 2006 | Onkyo DV-CP702 DVD Player
Onkyo DV-CP702 DVD Player Logo
46 people viewed this question
Top Onkyo Televison & Video Experts
Martin Murray
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
