Question about Gb Electrical 100 Amp GE Load Center
Wireing diagram for schult homes
I need a wireig diagram for a Schultz mobile home
2 Suggested Answers
  • 16 Answers
SOURCE: Have a 1990 Schult Mobile Home and can't find an
If you have been in touch with the mobile home company for a wiring schematic with no results, the best thing for you to do is purchase from your local hardware store, a 120 volt electrical tester which shouldn't cost you more than $5.00. At this point, turn off all of the breakers and turn them back on one at a time. After you turn on each one, check each room lights and outlets to find out what each breaker turns on. After checking each room, turn the breaker back off and turn on the next. As you verify each outlet, make a physical note of the location for each.
I hope this information has been useful.
Posted on Oct 12, 2010
I need a wiring diagram for connection of a 3-wire plug to my home panel - Square D, 240V, 200amp service panel.
We need to know what you are connecting. IF you are putting in a 220 outlet for stove, dryer etc. Are you in a mobile home?
Feb 20, 2016 | Square Electrical Supplies
Need wiring diagram for a 1974 Fleetwood Glenbrock mobile home
FIXYA DOESN'T HAVE ANY WIRING DIAGRAMS, SORRY.
Jul 09, 2012 | Cars & Trucks
I just bought a 10 yr. old Schult mobile home and after moving it to a new lot, I have no hot water. The heater is an Intertherm. I checked incoming voltage and it is ~120v, and the plate says 240v. My...
The incoming voltage should be 220-240. Check voltage across terminal that power supply is hooked to.Each incoming leg should read 120 to ground and 240 across . Check to see that thermostat is turned up to highest setting,usually 140 degrees,and check reset button to make sure it stays in in position. If you push reset in and it pops right back out you probably have a bad element. Check elements by going across terminals when you know element should be on.Hope this helps you. Thanks
Dec 19, 2010 | Water Heaters
I need a wiring diagram for workroom attached to mobile home, flourescent lighting with switch and wall recepticals with 20 amp breaker at panel inside mobile home
If you cant wire 120 volt connections, then it might be best to call somebody. Nobody on this site wants to be responsible for killing another human being.
Nov 01, 2010 | Garden
Have a 1990 Schult Mobile Home and can't find an electrical wiring schematic for it
Sep 02, 2010 | Gb Electrical 100 Amp GE Load Center
Where can I find a wiring diagram for a interrherm
Hi; Call Your local mobile home supply house and they can tell You how to or fax You the Info. Also the equipment will have the wiring diagrams glued to the inside covers of the outdoor unit as well the indoor unit cover. Power down the indoor unit before removing the indoor electrical cover for the schematics. Do You not have a user or install manual. Call your local mobile home supply house they can often help.. Be care full You get more bees with honey so be very nize...alpharome416
Feb 19, 2010 | Intertherm P3RA-036K Air Conditioner
Gb Electrical 100 Amp GE Load Center Logo
32 people viewed this question
Top Gb Electrical Electrical Supplies Experts
ken skalski
Are you a Gb Electrical Electrical Supply Expert? Answer questions, earn points and help others
