Ip address unknown - Computers & Internet
Jetdirect ex default ip
Usually it it set to pick up IP from DHCP/BootP.
If someone had assigned a fixed IP and it is now unknown. It is better to reset the print server to factory default by pushing the little reset button,
Then check you DHCP server for the newly assigned IP address.
You will need a version of HP Jetadmin or HP webjetadmin to configure this print server
May 13, 2014 | HP JetDirect EX Plus Print Server
Ip address unknown
If you need your IP address, Try this: http://whatismyipaddress.com/
Jan 21, 2013 | Computers & Internet
I need to either block certain ip or mac addresses or only allow a select few. how can i do this.
Well, when it comes to ip addresses, you must either turn off dhcp (which automatically gives out ip addresses to devices joining the network) and assign static ip addresses to each individual device on the network, or simply decrease the number of ip addresses your router's dhcp gives out by narrowing the dhcp range. Blocking ip addresses is an ineffective way of preventing access to the network. MAC Address filtering, on the other hand, is much more secure. Usually this is locating under Wireless - MAC Filter in the router's configuration page. When you get to the menu, you usually have the option of making an allow or deny list. If you are having problems with unknown devices, I would go with allow only option, and enter each of your device's MAC addresses. The one main problem is that you will have to do this every time a new device is added to the network, but it makes the network much more secure.
Sep 21, 2010 | Arris SURFboard SBG900 Wireless Router...
Ihave internet connection but I keep getting a unknow error message on my ip phone when i try to boot it up? IT reads http:1 http://192.168.42.2 411/x 46x grade.scr HTTP 1-1 then TFPT unknown...
The phone is doing what it is supposed to do. If the phone gets to discover, then shows the phone systems IP address...
"Discover 192.168.42.1"
That means that the phone can not see the call server. Talk to the network admin
Aug 26, 2010 | Avaya 5610 IP Phone
I cant get acces to my Modem or Wifi using "192.168.0.1? Help
May be 192.168.0.1 is not the address to configure that router.
Start, Run, CMD to open a command prompt:
Type the following command:
IPCONFIG /ALL
Right click in the command window and choose Select All, then hit Enter.
example results.
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Adamprince>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Adamprinces
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : VIA Rhine III Fast Ethernet Adapter
Physical Address. . . . . . . . . : 00-0A-48-08-24-52
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.1.6
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.254
DHCP Server . . . . . . . . . . . : 192.168.1.254
DNS Servers . . . . . . . . . . . : 202.27.184.3
Lease Obtained. . . . . . . . . . : Tuesday, 24 August 2010 5:35:33 p.m.
Lease Expires . . . . . . . . . . : Wednesday, 25 August 2010 5:35:33 p.m.
____________________________________________________
The address to configure that router is 192.168.1.254
Aug 26, 2010 | Computers & Internet
Hi there, i just had telstra install a Cisco 857w router. i am trying to setup the wrieless and am having no luck, i am not very computer literate so i may need to explained in very simple...
Need to setup the wireless on your 877W or 857w. use the following sample.. obviously update the SSID and wpa-psk key.
bridge irb
bridge 1 protocol ieee
bridge 1 route ip
interface Dot11Radio0
no ip address
bridge-group 1
no shut
broadcast-key change 60
encryption mode ciphers tkip
ssid MYSSID
max-associations 10
authentication open
authentication key-management wpa
no guest-mode
wpa-psk ascii mywpapskpwd
world-mode dot11d country AU outdoor
speed basic-1.0 basic-2.0 basic-5.5 basic-6.0 basic-9.0 basic-11.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
channel 2452
station-role root
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
ip virtual-reassembly
ip tcp adjust-mss 1400
bridge-group 1
hold-queue 100 out
interface BVI1
ip address 10.0.0.3 255.255.255.0
ip nat inside
Jun 09, 2009 | Computers & Internet
Can't get an IP address over time.
Ok I have guessed a couple of things. Here goes.
the version of software 12.4 (3g) is very old
I think that you have DHCP configured on the AP
the cisco site lists loads of issues regarding DHCP and memory leaks in numerous guises with not only your IOS version but newer versions too.
the reason why I have homed in on this is that you say that the unit works for about a week then essentially stops until you reboot the AP. (I guess that you do this by power cycling not by issuing the reload command) in the short term you have fixed the problem.
I would suggest that you upgrade the IOS to something newer. the current version listed is 12.4(22)T if it's of any help.
lastly as you know when the system actually goes wrong. You are able to issue the reload command with additional settings so it could reload @ X date and time if NTP is configured or you can specify a time duration in minutes if preferred.
I can't think of anything else I afraid.
Nov 04, 2008 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Unknown address
Install Network Manager in your and install . When you install this software then you go to networkingmap there you will get ipaddress of your print server
Apr 18, 2008 | D-Link DP 301U (DP-301U) Print Server
4690 Issues
You have to manually enter the callserver IP address (CLAN card). The 4690 are not in the 46xxsettings file.
Mar 27, 2008 | Avaya For Communication Manager4690 IP...
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
