Question about Hotpoint Refrigerators
Ffa71 high temp light on and unit makes funny gurgling noise
MY FFA71 FRIDGE FREEZER IS MAKING A STRANGE GURGLING NOISE AND THE HIGH TEMPERATURE RED LIGH IS ILLUMINATED
tborn6
  • 700 Answers
SOURCE: fridge has just started making loud noise and temp too high
sound like that you have a ice build up thats hitting your fan blade. Take and do a manual defrost on the frig side and be extra careful removing the cover in the back because there's 11 screws that have to come out before trying to remove the back poanel. Also if theres stillo ice in there what happens is that when you try to pull the back panel off it breaks off the stryrofam that samsung used for the air paths to cool the frig. so be extra carefull removing theses and if oyu do tear any and the airflow is not going the corect way you will drive yourself bonkers always defrosting htis unit. so heed my warning on this particular unit. its a great unit if you can psture what has to happen for the air flow to be correct. also put all of the screw back in correctly on the panel too. don't skip any because then the air flow is compromised. Good Luck and don't forget to rate the answer please. Haooy Neew Year!!!
Posted on Jan 01, 2009
lojacksdad
  • 121 Answers
SOURCE: unit has stopped cooling and freezing also making gurgling noise
it sounds like the frezzer fan stoped and what your hereing is the freon coming in
Posted on Apr 17, 2009
SOURCE: Hotpoint FFA71 fridge and freezer suddenly stopped working
Sounds as though the compressor has stopped working. It feeds both compartments with control from a printed circuit above the top door.Where all your red lights are ablaze! (This can be replaced by removing the 2 screws and "clicking" out the small panel) Check that the compressor is running at the bottom rear of the fridge/freezer before anything else.
Posted on Jul 11, 2009
heatman101
  • 43501 Answers
SOURCE: Hi I have a FFa71
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jan 16, 2011
judyc1114
  • 3 Answers
SOURCE: dometic fridge making gurgling sound and is not cooling
try these troubleshooting tips: http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&ved=0CJsBEBYwAw&url=http%3A%2F%2Fgasrefrigeration.net%2Fdom_techdata%2FMAN_SM.PDF&ei=H7XYT8CAC8fM2AW3toWkDw&usg=AFQjCNEKU8qIO1JVVcOyK2K2qnoe3nx3tg&sig2=ZoYjGVFzL9U2DXomAzt-QQ
Posted on Jun 13, 2012
I have an 11 cf upright freezer. it has been running most of the time or at least make a noise. and I just defrosted it. and its still doing the same thing. any comments?
Good Afternoon friend, thank you for your post!
I see that your Frigidaire freezer is making noise and you have recently defrosted it, but your freezer is still making the noise. Your freezer will make certain noises which are normal operating noises for the freezer.
The compressor is a high efficiency so you may hear it during start up and while running. Additionally, refrigerant circulating through your freezer can make a tapping sound or even a gurgling noise. I hope this has been helpful. -Matt
Sep 26, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
What is the gurgling noise in engine 2005 nissan quest
More info needed. Is the temp gauge reading high, coolant leaking, cooling fan working?
Aug 22, 2014 | 2005 Nissan Quest
Dometic fridge making gurgling sound and is not cooling
Jun 13, 2012 | Dometic Refrigerators
Hi There We have bought a second hand FFA71
If the refrigerator was not demonstrated as functional when purchased, you may have bought a dud.
Aug 03, 2017 | Refrigerators
Hi I have a FFa71 fridge freezer and the freezer is too warm, the high temperature light is on and the fridge seems to be getting frosty, I cant hear the fan any more.
Refrigerator
heatman101
Jan 16, 2011 | Hotpoint Refrigerators
"High wind" sound following defrost.
Freon running through the feon lines can make some odd noises, usually a gurgling or higher pitched noise. If your freezer works fine with no more strange noises, then don't worry about it. If you have temperature problems or continue to have abnormal noises, then see if your freezer has the 5 year sealed system warrantee that most freezers have. If it does, and it is under 5 years, then call Frigidaire to come out to check it out for free. If it is out of warrantee you will need to live with it or replace the freezer, since a freon sealed system repair is very high. Good Luck, Appliance Specialists
Feb 04, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Jun 30, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Unit has stopped cooling and freezing also making gurgling noise
Apr 17, 2009 | Refrigerators
Fridge freezer not cooling
buy a new freezer and never go near it with a screwdriver try unplugging it to remove ice
Mar 12, 2009 | Freezers
Hotpoint ffA71
ffa71 fridge and freezer warm and food defrosted. red light is on. Back of freezer making normal noise. Help.
Aug 27, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Open Questions:
Refrigerators Logo
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
