Question about Belkin F5X007 XM Radio Receiver
BelkBF5X007in XM radio boom box
Unit not working, antannae signal on roady xt shows recieving signal.....pulled roady out of the dock, and replaced it again with no luck. Is there a way to pull the unit apart and check the connection between the plug in dock and the radio itself? Is there a repair shop in the Portland, Oregon area that will service this unit? [email protected]
  • 3 more comments
  • Bill Hanson Jul 20, 2007
    Tried cleaning.....I think it may need to be opened up and looked at. Maybe the dock connector in the boom box is bad. Any way to open it up and get a replacement part? When I wiggle the xm roady it will make a noise from the boom box....no music or signal, more like a humming sound with a click or two.....kind of like a short or something.
  • Bill Hanson Jul 22, 2007
    DO not use the Boombox with the Roady XT until you get an aftermarket adapter from Belkin. The Boombox was manufactured with a defect in the connector....and it will ruin your Roady XT. Call Belkin or Delphi for more info.
    Belkin 1*800-2Belkin
    Delphi 1*877*463-3574
    Be very careful or you will soon be shopping for a new Roady XT!!
    Try contacting Delphi as well
  • Trohaden Jun 12, 2008
    My Belkin has done same thing, want to open it to see if something in the connector is damaged or come loose. Can't find any postings. Disappointed, a $100 unit stopped working after 4 months of use.
  • DR. BUTTFUCKER
    DR. BUTTFUCKER Oct 19, 2018
    I do the same thing when somebody wiggles my dock
Loved the Belkin until it ruined my Roady XT- now a speaker is blown. Love XM but customer service IS THE WORST!!!!! Completely clueless! Any info on new Delphi Premier Soundsystem? Thanks.
Posted on Sep 18, 2007
  • anon18 Feb 15, 2011
    I had the same problem with an Onyx and this boombox. The Onyx doesn't need an adaptor, unlike the Roady. Anyway it stopped playing sound so I have to buy another one or see if I have a home stereo dock.
  • 147 Answers
Check your Conns both on Radio and docking Bay make sure Nothing Got on them .Clean them with alchol and Swab Good luck ttech
Posted on Jul 20, 2007
SOURCE:
I continually loose my reception on my xm roady xt, i wiggle it around and then it works again, and so on. do i have a bad base unit and do they wear out over time. [email protected]
You need to resolder your antenna port on the dock connector. It's a really easy repair, all you need is a fine tip soldering iron. The antenna jack is on the right of the dock connector, it has 1 middle pin and 1 n-shaped pin that leads to 2 pads on the PCB. Your middle pin most likely has a cracked joint.
Dec 28, 2010 | Delphi Roady XT XM Radio Receiver
Roady XT works fine on Boom Box/Will not transmit to car antenna/will not show "set frequency" on menu,,
Cannot have anything plugged into the audio output/audio jack, or it shuts off the FM Frequency modulator.
Sep 05, 2010 | Delphi Roady XT XM Radio Receiver
Overheats and cuts off
check the antenna and see if its grounded out anywhere, like if its chaffed and grouned to the car somewhere. If not try turning on the unit outside of the car or using it in the home dock, if it does the same thing its a problem with your unit or car dock
Feb 21, 2009 | Delphi Roady XT XM Radio Receiver
Roady xt Antenna Problems
when it reads antenna it means there something wrong with either the connection or the antenna itself, it could be the location of the antenna or the antenna is going bad. if there is no obstructions on the car blocking the antenna i would advise purchasing a new antenna. you can get one at http://shopdelphi.com/consumers/satradio/xpressrc/
Feb 07, 2009 | Delphi Roady XT XM Radio Receiver
XM Roady is non functional
turn ignition on and disconnect your car battery then leave it on until its done loading if it still there then call xm and have then send an update good luck....
Dec 30, 2008 | XM Radio Dual XMP7000 Auto In-Dash CD...
Great signal, so sound
My XM Boombox is also white and it is a Belkin. The folks at Delphi told me the receiver in the boombox is screwed up which over time also screws up the Delphi receiver. Belkin is sending me a new boombox and Delphi is sending me a new Roady XT.
Mar 01, 2008 | Delphi Roady XT XM Radio Receiver
No FM Frequency option
I had the same problem with all three of my Roady XTs. I posted a video with directions for solving the problem on YouTube:
http://www.youtube.com/watch?v=BGMWf0aUTjw
Basically, you just need to have the antenna unplugged when you power up, and push menu right away, then select. Not sure why, but it worked on all of my Roady XTs. On the oldest one I had to push menu more than once. Good luck!
Sep 24, 2007 | Delphi Roady XT XM Radio Receiver
URGENT Belkin F5X007*****Please Read!!!******
same thing happened to me and I had to take the radio back to Walmart...
Jul 22, 2007 | Belkin F5X007 XM Radio Receiver
Roady XT periodic errors
The pins get easily damaged when switching from the car dock to the Belkin boom box. I have to constintly squeeze very ******* the top of the xt in order for it to make contact. Belkin will send you a plastic alignment fixture but it is too late. It still does the same thing.
Jun 18, 2007 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT Quit Working
Chances are it's not picking up the XM signal. First, contact XM to resend your setup. if that doesn't work check your antenna connections.
Oct 31, 2006 | Delphi Roady XT XM Radio Receiver
Belkin F5X007 XM Radio Receiver Logo
534 people viewed this question
Top Belkin Audio Players & Recorders Experts
Perry Mellott
Perry Mellott
PickyPrick
Tom Chichester
Are you a Belkin Audio Player and Recorder Expert? Answer questions, earn points and help others
