Question about Nikon D2H Set Digital Camera
How can i make the picture number continuous with my nikon D2H?
With my nikon d2H, the picture number goes back to 001 everytime I change CF memory cards. how can i make the numbering continuous?
If you go into the menu settings you can choose wheather to let it run on and reset at 9999 or start again or name the new file.
Posted on Jan 27, 2009
Tip
Nikon offers Free Repairs on the D70, D2H, F55
Nikon has posted the following notice on its Support page for the D70 / D2H / F55 cameras:
" It has come to our attention that electronic components related to exposure control in some D70 cameras may, on rare occasions, fail.
Should you experience this problem with your D70 camera, Nikon will replace the associated components free of charge even if the camera’s warranty has already expired. We sincerely apologize for any inconvenience you may have suffered because of this problem."
To check if your camera has failed due this reason, please read the symptom description as follows:
How can I identify if my camera is faulty?
With a memory card inserted: The green memory card access lamp blinks continuously and camera does not respond to any controls.
With no memory card inserted: The camera will not turn on despite the battery indicator showing a fully charged battery.
How can I contact Nikon on-line?
You must be registered for Nikon support. Make sure that all your personal details are registered in full and are up to date, as these will be used if you return your product to us. You must also register your D70 and serial number.
1. Register for Nikon Support.
If you are not registered for Nikon Support, create a new account. If you already have an account, check that your personal details are up to date and that you have registered your product and serial number. To do this, login and click the ‘My Account’ tab, then click the ‘Profile’ sub-button. When finished, click the ‘Save’ button at the bottom of the page.
2. Submit your Question
Click the ‘Ask a Question’ tab near the top of the page and fill in the required fields, please add the words ‘D70 notice’ to the ‘Title’ field and add your comments to the ‘Question’ field.
When you have finished, click the ‘Submit Question Button’ and then you will be asked to click the ‘Finish Submitting Question’ button on the last page.
We will endeavour to answer your question as soon as possible.
NIKON Support:
http://nikoneurope-en.custhelp.com/cgi-bin/nikoneurope_en.cfg/php/enduser/std_alp.php?p_sid=yHTDQxQh
on Apr 06, 2010 | Cameras
Whenever I take a photo, or try to, my Nikon D2H focuses and refocuses without actually getting a clear photo and won't let me snap a shot. Is there a setting that may have gotten changed to create this...
Pmlemar,
It sounds like a problem with the auto focus. You can narrow this down with some different tests.
1) Try turning off auto focus and taking a picture. If that works then try
2) Another lens, see if you can duplicate the problem that way. If you can, you either have an auto focus, or lens communication problem. If you can't duplicate the problem with a second lens, then you know the lens you were using is the culprit.
Thank you.
Mar 22, 2011 | Nikon D2H Set Digital Camera
I was having troubles with my Nikon D2H as in it wouldn't take a picture. I then realized my memory card was full so I deleted a few photos and it worked fine. This afternoon I deleted all the photos from...
You and a few million others all delete their pictures from the memory card when you should be formatting. Formatting cleans the memory card surface of all data and makes it ready to accept new image/data. You said that the card used to hold over 100 + well it will again if you format. By deleting the picture not all of the information data is erased it leaves what I call a residue not much but still enough that over time it begins to take usable space for picture data. Then as you are finding out the life is shortened, well not life but available storage space. Here is a diagram of the format sequence cause you can see it and read it better then I can type it.
Format D2H memory
Have fun with that, if it were me I'd run 'er through a couple of times Cheers chat later
Jan 26, 2011 | Nikon Cameras
No images on Nikon D2H back monitor
I think this can be turned on and off in the settings menu
Nov 22, 2008 | Nikon D2H Set Digital Camera
NIKON D2H ERR FAULT
I had a D2H with a similar error. The camera started giving an 'ERR' message almost from new but from reading various posts from other users I assumed it was a 'known' idiosyncrasy of the D2H, the camera would create an underexposed first shot after turning on. A colleague has the same problem on his D2H, and there are numerous references to the same problem on the web. Your post points to a similar shutter issue. My shutter failed completely at around 65,000 actuations, well short of the advertised '150,000'. In addition, the horizontal Main Command Dial had also failed a short time before, and it had cost me £135GBP to have that repaired.
The problem is down to the shutter and unfortunately replacing the shutter costs £349GBP in the UK, quoted to me by the Nikon UK Service Department, in Kingston, in March 09.
As for Nikon repairing it under a 'goodwill' policy, you may have better luck than me if you live somewhere other than the UK. I told them to keep mine, as attempting to charge me for the repair was the last straw, it wasn’t worth me spending another £350 on a camera that hadn’t been reliable in the first place. I had been planning on getting a D3 in October/November but will now probably sell my Nikon gear and go over to Canon, as Nikon don’t seem too bothered about their professional user base, and I certainly won’t be paying £5,000 for a D3X.
Sep 25, 2008 | Nikon D2H Set Digital Camera
D2H NIKON
I see the same thing with my D100. Read here about the discussions on a D200 with the same issues: Photonet
Jul 01, 2008 | Nikon D2H Set Digital Camera
LCD screen 'flicker'
Try setting the video output option to NTSC (if it's on PAL). I know this sounds funny, but I have heard some rumblings about this option somehow creating a LCD flicker. If it doesn't work, I apologize in advance for wasting your time! My camera is on NTSC and I haven't seen any flicker on the file numbers on the LCD.
Sep 19, 2005 | Nikon D2H Set Digital Camera
Monitor is blank
Is there an internal battery that might need to be replaced?
Sep 14, 2005 | Nikon D2H Set Digital Camera
Seriously confused...
I was very confused too. I finally sold my S2 Pro in favor of a D2H just recently. It is indeed a fantastic camera. I worried that decision for many weeks over concern about going to 4 MP from the excellent output from the S2 Pro. In my shooting, I haven't been hampered by the lower pixel count at all. In fact, my images have improved markedly because the camera is SO accurate. It let's me get shots I never would have been able to get with the S2 Pro. I might have waited for the S3 if Fuji had indictated any substantial improvement in the body, AF and metering, but it looks like their focus is on the sensor, and the camera is going to remain a tool of the studio and wedding photographer rather than the outdoor shooter. The general concept of going to the D2H from the S2 Pro is by no means a no-brainer. A lot depends on what kind of photography you are going to do. But I can tell you that the output from the 4mp D2H is really excellent, and for me, the AF accuracy and speed is astonishing having used an S2 Pro for many thousands of images. The camera handling difference is absolutely night and day, and for me, I have found it vastly preferable to nail a 4 mp image rather than to miss several 6 mp images.
Sep 04, 2005 | Fuji FinePix S20 Pro Digital Camera
Nikon D2H Set Digital Camera Logo
82 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
