Question about Husqvarna 224L 4 Cyc Gas Trimmer
Husqvarna 224l 4 cycle trimmer also for edge trimming ?
Can I turn this 4 cycle trimmer sideways for edge trimming
  • 42 Answers
SOURCE: Husqvarna 324LDx 4 cycle string trimmer. Have
Probably needs a carb kit, check main jet and main fuel inlet jet, is the spark crisp, fat and powerful, try running it with a borrowed coil as this may have an intermittent fault. Is fuel cap breather working or blocked, these small carbs are very sensitive. Make sure all is well with gaskets and diagrahms. Good luck the Yeti
Posted on May 17, 2009
suzukiracing
  • 200 Answers
SOURCE: Husqvarna vs Echo gas weed trimmers...needing your opinion.
They are very reliable brands stihl is a very good brand also.
Posted on Jul 19, 2010
  • 252 Answers
SOURCE: the trimmer head stopped turning What could be wrong
here is web site for parts
http://www.partstree.com/parts/?lc=husqvarna&mn=225+L+%281994-06%29
almost sounds like the driving drum engagement end has rounded off or the end of drive shaft broke off at either end , or the gear head end is broken / damaged
have a look at the splines on the output shaft on the gear head , check the plate that engages those splines too
physicaly take off the tube / shaft assy from power head and check drum and clutch rotating , check drive shaft end (s)
if ok refit tube / shaft assy ( make sure engaged properly)
tighten mount bolts - remove gear head from end of shaft, start motor and run see if shaft turns ok with some rev s if so
problem is in the gear head
check out website good site
cheers paul hope it helps
Posted on Aug 02, 2010
SOURCE: I just recieved a
The Husqvarna 128LD trimmer does accept attachments; however it does not accept Husqvarna attachments.
The 128LD is designed to accept only lower consumer quality "Expand-It", "EZ Link", and "TrimmerPlus" attachments; which includes those from Ryobi, Toro, Troy-Bilt, Craftsman, John Deere, Homelite, and Poulan. It uses a different connector head than the Husqvarna attachments. Husqvarna currently does not even list it on their website. Husqvarna's only information on the 128LD is buried at http://husqvarna2.custhelp.com/app/answers/detail/a_id/603 .
Having a more reliable Husqvarna power head is great, however Husqvarna and Lowes should be upfront that the 128LD is not supported by Husqvarna's higher grade attachments.The 128LDX; which does accept Husqvarna attachments and is available through dealer's, is the same price as the LD.
Posted on Apr 27, 2011
philwalker78
  • 608 Answers
SOURCE: Just bought a brand new Husqvarna 224L
Hi, take it back to the dealer as the powered or gear box have not been fitted correctly. The noise you can hear is most likely the clutch drive grinding on the drive shaft. Hope this helps, regards Phil.
Posted on Jul 21, 2011
How much oil and what type of oil should I use in the trimmer?
You use no oil,use regular unleaded gas only,on 4-Cycle engine use gas,2-Cycle engines use the oil- gas mixture,your's is better cause you just need gas.I use Husq's too.
Apr 13, 2016 | Husqvarna 224L 25cc 4-Cycle Straight Shaft...
Low power, runs rough, hard to start.
replace the fuel lines,ethanol kills them,then they leak air
Jul 04, 2015 | Husqvarna 224l Gas Powered Line Trimmer, 4...
How much oil does a husqvarna 224l use
The manual does not call for a specific volume of oil. Make sure to check the level using the dip stick and make sure the oil level is approximately half way up the dip stick. If oil is needed, SAE10W40 is recommended.
Sep 01, 2014 | Husqvarna 224l Gas Powered Line Trimmer, 4...
How to change cutting head on 224l trimmer
www.husqvarna.com/asia/support/contact-husqvarna
1 (800) 487-5951
Jun 17, 2014 | husqvarna"" ls 2 cycle oil"
How to restring a husqvarna 224L
To remove the head to restring, push in the bumper cap/side tabs on the strimmer head, the top should then just pull off exposing the inner spool.
Jul 24, 2012 | Husqvarna Weed Trimmer 224 L 4-stroke Line...
Set idle 224L
page 19 of the manual found here : http://www.husqvarna.com/ddoc/HUSO/HUSO2009_USen/HUSO2009_USen__115138729.pdf
Jul 08, 2012 | Husqvarna 224L
Set idle 224L
Standard carb settings on the Walbro carb are 2&1/4 turns out anticlockwise from fully wound in on bith H and L tuning screws.
Jul 08, 2012 | Husqvarna Garden
Owners manual husqvarna 224l how to read oil level on 4 cycle
oil level.? Although its a 4 cycle it uses standard 1:50 2 stroke mix. No engine oil.!
Jun 11, 2011 | Husqvarna Garden
Husqvarna 224L 4 Cyc Gas Trimmer Logo
94 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
