Question about BenQ FP71E 17" LCD Monitor
BENQ FP737S Monitor shows "No Signal Detected" on startup
In the last 2 days, this has been an intermittent fault on startup. Sometimes the monitor starts up Windows as usual when the computer and monitor are turned on and on other occasions the monitor just shows "no Signal Detected" (same happens if you turn the monitor off and on again at that stage). No changes have been made to the computer.
  • john_bennett Jan 30, 2009
    It was the computer, not the monitor or lead.
First problem could be the hdmi cable you are using is loose or broken.second, the display mode you selected was wrong, try to go to desktop and right click and choose nvdia control panel and choose the nview display mode to use,select the only use one display(single)and apply.
Posted on Jan 27, 2009
~Hello! My monitor dispays picture, but the picture isnt like it should be. Instead of normal colours it displays gray stripes, red is shown as yellow, windows 7 startup icon is in black box ect. When...
Hey, have you bene able to try another monitor and see if its the same thing?
Check andmake sure that all of your cables are tight and secure. If they are then you probably have a bad video card. they are fairly easy to replace:
Jul 15, 2011 | BenQ FP737S-D 17" LCD Monitor
How to troubleshoot my my benq t52wa that shows no signal detected
If the monitor is showing you a "no signal" message, it's almost certainly working fine. There's no video coming in from the computer, and that's likely where the problem is. Try another monitor first. It's possible yours isn't recognizing the input signal, but it's unlikely. I've only seen that happen twice I can remember. Chances are that another monitor will say "no signal" as well. Either the computer isn't starting up, or the video isn't working.
If you hear all the sounds of a normal startup (usually a single beep when the motherboard finishes power-on tests, hard drive activity shown by the front panel indicator, and finally the Windows startup sound through your speakers), then the video circuitry is bad. If the video is integrated onto the motherboard, you can install a replacement video card in an open expansion slot. If you already have a separate video card you can replace it.
If the computer isn't starting, you need to suspect memory, the motherboard, power supply or processor. You might also have a bad hard drive, optical drive or other device connected which is preventing startup. Begin by unplugging everything except the main parts: memory, processor and fan, power supply and (if used) video card. If the system starts up, you can identify the bad part by reconnecting them one at a time until the problem comes back. If the system still doesn't start with the minimum hardware, part substitution is how you'll figure out which is responsible.
It can be frustrating, but you'll get the thing going. Good luck, and thanks for using Fixya!
Oct 08, 2010 | BenQ FP737S-D 17" LCD Monitor
My computer is on but nothing is on the monitor, how do I firstly test if the problem is the monitor?
first you have to disconnect the vga cable then power on the monitor then it will show "no signal check the signal cable " massage if massage comes on screen then monitor is ok if no msassage then monitor is faulty
Mar 12, 2010 | BenQ FP737S-D 17" LCD Monitor
Power light on no screen shown
unplug from pc, turn on monitor. if there is a 'no signal' or any image displayed on the screen then the problem is not the monitor..
Nov 15, 2009 | BenQ FP737S-D 17" LCD Monitor
No signal detected
Check all of your cables - VGA / DVI mainly in the back of the monitor and the back of the PC.
Jun 09, 2009 | BenQ FP737S-D 17" LCD Monitor
Benq 19' LCD Screen 3 yrs old- no signal detected on brand new PC
Have a look at the back of your computer.
See if there is more than 1 video port.
If there are 2 ports try plugging the monitor into the other port....
Sometimes motherboards have internal video cards, in this case the video port is in among the USB ports, sound and mike sockets etc.
Look for a video port away from all those other things.
Apr 26, 2009 | BenQ FP71E 17" LCD Monitor
BenQ FP737-D 17 Monitor
Hey... what you need it a new backlight inverter, your old one it busted...
Sep 14, 2008 | BenQ FP737S-D 17" LCD Monitor
BenQ fp737 monitor
Disconnect the signal cable from CPU and power on.You should get a BenQ Blue screen.
If no Display,Problem is definitely monitor related ie monitor has a hardware defect most probably the power/invertor board has a few blown components.
If you are technically able,you can dismantle monitor and check components on the Invertor board which you may find on my other posts.
Please reply if you need more help.Please rate this solution.
Thanks.
Samir
Aug 25, 2008 | BenQ FP737S-D 17" LCD Monitor
Benq fp737s monitor failure
try resoldering the joints on c826 &c824 near the 4 yellow transformers in the power supply.
hope this helps
kevin numbnuts07
May 28, 2008 | BenQ FP737S-D 17" LCD Monitor
LCD monitor went blank
Which model is it?Does power led remain on?
Samir
Jan 22, 2008 | BenQ FP737S-D 17" LCD Monitor
BenQ FP71E 17" LCD Monitor Logo
1,469 people viewed this question
Top BenQ Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Matthew Spark
Matthew Spark
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
