Question about Garden
Mtd 18hp riding mower rear wheel won't come off to change tire
lester482529
  • 226 Answers
SOURCE: Mtd mower will not move forward or backward.rear
OPPISITE MOVEMENT IS STANDARD W/OUT TENSION,SOUNDS LIKE TRANS IS GOING OUT.HOW OLDIS YOUR MOWER?
Posted on May 31, 2009
panilling9
  • 284 Answers
SOURCE: Need to remove rear wheels to replace tires on MTD riding mower.
most likely rust has taken over
find some liquid wrench or pb blaster and spray the axles liberally and let it penetrate the axles and wheel hubs where the axle goes through.
use a 2x4 and a hammer to tap against the wheel hub to try to move it down the axle then tap in back on to try to free it up as the penetrating oil works in, spin the wheel and tap in different areas of it
the worst case cenario would be to use a torch and heat the axle and hub up and drive it off, but it sounds as though you are moving it some and with some patience they eventually should come off
when you put them back be sure to coat the axle with some grease and do not forget to reinstall the key stock in each wheel, if they have it
the bolt in the center of the axle is all you need to remove and note where the washers came from and where they go back.
hope this helps you some
Posted on Jun 14, 2009
  • 89 Answers
SOURCE: Removed bolt but still can't remove rear wheel on
they sometimes are very haed to get off some wheels have two holes on the rim you have to use a gear puller
Posted on Nov 05, 2009
SOURCE: 18hp craftsman riding mower model#917.255913. won't turn left!
I have had this problem for the longest time. I replaced the secondary gear twice. Helped for a brief period and now won't turn left again. Replaced the steering shaft and worked for a brief period. Back to no left turns once again. The issue is with the secondary gear and bearings (plastic) which is only a temporary fix. What I had done was welded a piece of steel to the bottom of the steering shaft eliminating the secondary gear connecting directly to the tie rod for the steering. Works perfect now.
Posted on Jun 01, 2010
rycgl
  • 1545 Answers
SOURCE: 1997 MTD Riding Mower 18hp 42"cut. Drive belt
I wish to tell dwhandys that this is a great answer, and a great solution. You surely know how to work!
Posted on Sep 11, 2011
Testimonial: "dwhandys hit the nail on the head... the guy is great. "
Mtd removing rear wheels from axel
Be very carefull, if you pull the wheels hard enough the half shaft will pop the circlip on the inside of the gearbox and come away with the wheel, this will then require a gearbox strip down, leave it soaking in penetrating oil and try again.
Jul 11, 2012 | Yard Man Yardman Riding Lawn Mower 38in...
Dynamark / Noma riding mower Mod# A38120910, SER# 149606, Code 0025M. how to get rear tires off?
i change the tires with the wheel on the mower if they don't slide off with the bolt or clip removed
Jul 02, 2012 | Garden
How to get rear wheel off
if it doesn't come off due to rust holding the wheel to the shaft and your trying to change the tire just change the tire with the wheel on the mower it's not as hard as it soulds
May 20, 2012 | Garden
How do you remove the rear wheels on a ranch king plus 18 hp 46 inch cut
if the don't come off after removing either the bolt or clip and you need to change a bad tire just change the tire on the axle jack up the one side as high as you can not as hard as getting the wheel off
May 04, 2012 | Mtd Garden
Sep 03, 2011 | Yard Machines Garden
WHERE CAN i DOWNLOAD A OWNER'S/USER'S MANUAL FOR AN MTD YARDMASTER 18HP RIDING MOWER
finding the website for MTD and/or AYP would be a place to start. google is there, use it.
Mar 16, 2011 | Garden
18hp kohler engine (grasshopper) won't start. Single click from starter/solenoid when key turned. Battery new/charged.
I have a duetz-allis mower with 18hp. kohler eng. won't start, have new seloniod, new circuit breaker, getting fire to switch & out. Still won'tstart
Aug 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Jun 14, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
To whoever i have a 46'' 18hp riding lawn mower
You can find it here... http://manuals.mtdproducts.com/mtd/public/list.jsp You will have to enter the model and serial number that should be under the seat.
Jun 13, 2009 | Garden
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
